Discuss
Out of Balance fault when not wobbling
 in
Washer Repair
Approx 5 year old Whirlpool Cabrio. Had to replace bearings. That process took awhile but went OK. Diagnostic check ok.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Out of Balance fault when not wobbling
  #1 (permalink)
Old 01-21-2018, 10:39 AM
PCS PCS is offline
Junior Member
PCS is on a distinguished road
Default Out of Balance fault when not wobbling
Model Number: WTW8900BC0   Brand: Whirlpool   Age: 1 - 5 years
Approx 5 year old Whirlpool Cabrio. Had to replace bearings. That process took awhile but went OK. Diagnostic check ok. Washed 4 loads OK. Now get “Out of Balance” fault every cycle. BUT, neither the machine nor drum are wobbling around very much. Well within what should be ok. How does it detect out of balance? Any suggestions?
I’ve checked springs, precisely leveled it, run spin test (which it does great at). No luck.
Planning on taking apart to bearings then putting back together.
BTW, sounds great and turns easily with the new bearings and shaft.
The machine also has a glass lid, so I can see in and I do not notice much wobble.
Related Models
Bosch WTZ1170
Bosch WTZ1210
Roper WU0800B UNDERCOUNTER DISHWASHER
Roper WU0800XX0 Dishwasher
Roper WU0800XX1 UNDERCOUNTER DISHWASHER
Maytag WU100 DISHWASHER- UNDERCOUNTER
Maytag WU1000 DISHWASHER- UNDERCOUNTER
Roper WU1000X0 Dishwasher
Roper WU1000X1 Dishwasher
Roper WU1000X4 Dishwasher
Roper WU1000X5 Dishwasher
Roper WU1000X6 Dishwasher
Roper WU1000X7 Dishwasher
Roper WU1000X8 Dishwasher
Roper WU1000Y0 UNDERCOUNTER DISHWASHER
Roper WU1000Y1 UNDERCOUNTER DISHWASHER
Maytag WU1004 DISHWASHER- UNDERCOUNTER
Maytag WU1005 DISHWASHER- UNDERCOUNTER
Maytag WU101 DISHWASHER- UNDERCOUNTER
Maytag WU103 DISHWASHER- UNDERCOUNTER
Maytag WU104 DISHWASHER- UNDERCOUNTER
Maytag WU180 DISHWASHER- UNDERCOUNTER
Roper WU1800XX0 Dishwasher
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 DISHWASHER- UNDERCOUNTER
Maytag WU200 DISHWASHER- UNDERCOUNTER
Maytag WU201 DISHWASHER- UNDERCOUNTER
Maytag WU202 DISHWASHER- UNDERCOUNTER
Maytag WU203 DISHWASHER- UNDERCOUNTER
Maytag WU204 DISHWASHER- UNDERCOUNTER
Maytag WU282 DISHWASHER- UNDERCOUNTER
Maytag WU284 DISHWASHER- UNDERCOUNTER
Maytag WU285 DISHWASHER- UNDERCOUNTER
Maytag WU300 DISHWASHER- UNDERCOUNTER
Roper WU3000V0 Dishwasher
Roper WU3000V1 Dishwasher
Roper WU3000V2 Dishwasher
Roper WU3000V3 Dishwasher
Roper WU3000X0 Dishwasher
Roper WU3000X1 Dishwasher
Roper WU3000X2 Dishwasher
Roper WU3000X3 Dishwasher
Roper WU3000X4 Dishwasher
Roper WU3000X5 Dishwasher
Roper WU3000X6 Dishwasher
Roper WU3000Y0 DISHWASHER
Roper WU3000Y1 UNDERCOUNTER DISHWASHER
Roper WU3006V0 Dishwasher
Roper WU3006V1 Dishwasher
Roper WU3006V2 Dishwasher
Roper WU3006V3 Dishwasher
Roper WU3006X0 Dishwasher
Roper WU3006X1 DISHWASHER
Roper WU3006X2 Dishwasher
Roper WU3006X3 Dishwasher
Roper WU3006X4 Dishwasher
Roper WU3006X5 Dishwasher
Roper WU3006X6 Dishwasher
Roper WU3006Y0 UNDERCOUNTER DISHWASHER
Roper WU3006Y1 UNDERCOUNTER DISHWASHER
Roper WU300X2 Dishwasher
Maytag WU301 DISHWASHER- UNDERCOUNTER
Maytag WU302 DISHWASHER- UNDERCOUNTER
Maytag WU303 DISHWASHER- UNDERCOUNTER
Maytag WU304 DISHWASHER- UNDERCOUNTER
Roper WU3050Y0 UNDERCOUNTER DISHWASHER
Roper WU3050Y1 UNDERCOUNTER DISHWASHER
Roper WU3056Y0 UNDERCOUNTER DISHWASHER
Roper WU3056Y1 UNDERCOUNTER DISHWASHER
Maytag WU400 DISHWASHER- UNDERCOUNTER
Maytag WU401 DISHWASHER- UNDERCOUNTER
Maytag WU404 DISHWASHER- UNDERCOUNTER
Roper WU4300B0 DISHWASHER
Roper WU4300B1 UNDERCOUNTER DISHWASHER
Roper WU4300Y0 Dishwasher
Roper WU4300Y1 Dishwasher
Roper WU4300Y2 Dishwasher
Roper WU4300Y3 Dishwasher
Roper WU4300Y4 Dishwasher
Roper WU4400V0 Dishwasher
Roper WU4400V1 Dishwasher
Roper WU4400V2 Dishwasher
Roper WU4400V3 Dishwasher
Roper WU4400X0 Dishwasher
Roper WU4400X1 Dishwasher
Roper WU4400X2 Dishwasher
Roper WU4406V1 Dishwasher
Roper WU4406V3 Dishwasher
Roper WU4500B0 UNDERCOUNTER DISHWASHER
Roper WU4500B1 UNDERCOUNTER DISHWASHER
Roper WU4500Y0 Dishwasher
Roper WU4500Y1 Dishwasher
Roper WU4500Y2 Dishwasher
Roper WU4500Y3 Dishwasher
Maytag WU482 DISHWASHER- UNDERCOUNTER
Maytag WU484 DISHWASHER- UNDERCOUNTER
Maytag WU490 DISHWASHER- UNDERCOUNTER
Maytag WU494 DISHWASHER- UNDERCOUNTER
Maytag WU500 DISHWASHER- UNDERCOUNTER
Maytag WU501 DISHWASHER- UNDERCOUNTER
Maytag WU502 DISHWASHER- UNDERCOUNTER
Maytag WU504 DISHWASHER- UNDERCOUNTER
Roper WU5650V0 Dishwasher
Roper WU5650V1 Dishwasher
Roper WU5650V2 Dishwasher
Roper WU5650X0 Dishwasher
Roper WU5650X1 Dishwasher
Roper WU5650X2 Dishwasher
Roper WU5750B0 DISHWASHER
Roper WU5750B1 UNDERCOUNTER DISHWASHER
Roper WU5750Y0 Dishwasher
Roper WU5750Y1 Dishwasher
Roper WU5750Y2 Dishwasher
Roper WU5750Y3 Dishwasher
Roper WU5755B0 UNDERCOUNTER DISHWASHER
  #2 (permalink)
Old 01-21-2018, 11:18 AM
PCS PCS is offline
Junior Member
Default
Also, it has a glass top, so I can see in and verify that it is not wobbling much.
  #3 (permalink)
Old 01-22-2018, 02:16 PM
PCS PCS is offline
Junior Member
Default
I think I found it. Bolt holding the rotor on was loose. I put more thread locker on and tightened. Held through a test run and two loads so far.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Tub Wobbling dorifuto.boi Washer Repair 0 10-12-2016 05:57 AM
Washer wobbling violently in spin cycle eepagazeepa Washer Repair 9 01-29-2014 12:39 AM
Changed snuber and springs, but still wobbling! DrkSdeOTM Washer Repair 0 09-04-2011 08:12 PM
tub wobbling hitting panal rodbedell Washer Repair 1 01-10-2011 11:15 AM
Washer Wobbling When Spins shirleytemple Washer Repair 4 02-01-2010 04:55 PM
