Discuss
1990's whirlpool top loading direct drive washer water temperature control
 in
Washer Repair
washer has water temp circuit board and a separate 8 postion water temp selector rotary switch. currently 3 wires are
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 1990's whirlpool top loading direct drive washer water temperature control
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 01-18-2018, 01:57 PM
Junior Member
jbox2324 is on a distinguished road
Default 1990's whirlpool top loading direct drive washer water temperature control
Model Number: 11092586210   Brand: Whirlpool   Age: More than 10 years
washer has water temp circuit board and a separate 8 postion water temp selector rotary switch. currently 3 wires are attached to it in a clip. washer has automatic settings on 4 postions on display on panel and 4 settings manually on same.settings dont respond all the way; no response at all on automatic. i do have hot, warm and cold water on 2 applicable and 1 non-applicable settings. my question is what switch with what harness plug should be with this set up for manual and auto circuit board control. thanks jb2324.
Related Models
Kenmore 11092586210 WASHER
Kenmore 11092586400 WASHER
Kenmore 11092586410 WASHER
Kenmore 11092587200 WASHER
Kenmore 11092587210 AUTOMATIC WASHER
Kenmore 11092587400 WASHER
Kenmore 11092587410 AUTOMATIC WASHER
Kenmore 11092588200 WASHER
Kenmore 11092588210 WASHER
Kenmore 11092588400 WASHER
Kenmore 11092588410 WASHER
Kenmore 11092590100 AUTOMATIC WASHER
Kenmore 11092590110 WASHER
Kenmore 11092590120 WASHER
Kenmore 11092590800 AUTOMATIC WASHER
Kenmore 11092590810 WASHER
Kenmore 11092590820 WASHER
Kenmore 11092591200 WASHER
Kenmore 11092591210 WASHER
Kenmore 11092591220 WASHER
Kenmore 11092591230 WASHER
Kenmore 11092591400 WASHER
Kenmore 11092591410 WASHER
Kenmore 11092591420 WASHER
Kenmore 11092591430 WASHER
Kenmore 11092592200 WASHER
Kenmore 11092592400 WASHER
Kenmore 11092593200 WASHER
Kenmore 11092593210 WASHER
Kenmore 11092593220 Residential Washers
Kenmore 11092593400 WASHER
Kenmore 11092593410 WASHER
Kenmore 11092593420 Residential Washers
Kenmore 11092595200 Residential Washers
Kenmore 11092595210 Residential Washers
Kenmore 11092595400 WASHER
Kenmore 11092595410 Residential Washers
Kenmore 11092595500 Residential Washers
Kenmore 11092595510 Residential Washers
Kenmore 11092596100 WASHER
Kenmore 11092597200 AUTOMATIC WASHER
Kenmore 11092597210 AUTOMATIC WASHER
Kenmore 11092597400 AUTOMATIC WASHER
Kenmore 11092597410 AUTOMATIC WASHER
Kenmore 11092598200 Residential Washers
Kenmore 11092598400 Residential Washers
Kenmore 11092599200 Residential Washers
Kenmore 11092599400 Residential Washers
Kenmore 11092599500 Residential Washers
Kenmore 11092822100 GAS DRYER
Kenmore 11092822101 GAS DRYER
Kenmore 11092822102 GAS DRYER
Kenmore 11092822103 RESIDENTIAL DRYER
Kenmore 11092824100 GAS DRYER
Kenmore 11092824101 GAS DRYER
Kenmore 11092824102 GAS DRYER
Kenmore 11092824103 RESIDENTIAL DRYER
Kenmore 11092826100 GAS DRYER
Kenmore 11092826101 GAS DRYER
Kenmore 11092826102 GAS DRYER
Kenmore 11092826103 RESIDENTIAL DRYER
Kenmore 11092832100 DRYER
Kenmore 11092834100 DRYER
Kenmore 11092836100 DRYER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094762300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094821300 GAS DRYER
Kenmore 11094821301 RESIDENTIAL DRYER
Kenmore 11094831300 GAS DRYER
Kenmore 11094831301 RESIDENTIAL DRYER
Kenmore 11094832200 GAS DRYER
Kenmore 11094832201 GAS DRYER
Kenmore 11094834200 GAS DRYER
Kenmore 11094834201 GAS DRYER
Kenmore 11094836200 GAS DRYER
Kenmore 11094836201 GAS DRYER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11094962300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094964300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094966300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094972300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094974300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094976300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11095081400 RESIDENTIAL DRYER
Kenmore 11095081401 DRYER
Kenmore 11095081402 RESIDENTIAL DRYER
Kenmore 11095087400 DRYER
Kenmore 11095087401 DRYER GAS
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Washer direct drive ndozois Washer Repair 2 11-08-2017 03:54 PM
Whirlpool direct drive washer won't spin sarcza Washer Repair 1 03-07-2012 11:40 AM
replacing drive coupleing on Whirlpool direct drive washer bbuck222 Washer Repair 2 08-06-2009 07:34 AM
Reparing top loading direct drive washer model kevflory Washer Repair 1 06-03-2009 01:20 AM
Whirlpool Direct-Drive Washer Won't Run Dave Bishop Washer Repair 2 03-11-2009 08:40 AM
