Discuss
Maytag Bravos MCT stuck in sensing
 in
Washer Repair
Hello, Have a Maytag Bravos MCT washer, model# MVWX655DW1, that is sticking in the sensing mode. It will fill with
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Bravos MCT stuck in sensing
  #1 (permalink)
Old 01-12-2018, 10:14 PM
Junior Member
trusbos25 is on a distinguished road
Default Maytag Bravos MCT stuck in sensing
Model Number: MVWX655DW1   Brand: Maytag   Age: 1 - 5 years
Hello,
Have a Maytag Bravos MCT washer, model# MVWX655DW1, that is sticking in the sensing mode. It will fill with water and do the sensing turns maybe (3) times then water will stop and begins to hum, 30 seconds or so will go by and water will start to fill again with no sensing turns. This will go on for about 5-8 minutes then washer will drain, which takes another 8 -10 minutes to complete. Now normally it would fill with water and do the sensing turns for approximately 5 minutes and then start washing.
I have checked for error codes and get F8 E1 (no fill or too long to fill). It's definitely getting water. I have replaced the shift actuator already, thinking that since tub wasn't spinning that may have been it, to no avail. I ran the self diagnostic and all tests ran as good, water filled, drained, tub spun, lid locked all of it. Decided to remove the water lines and check the water inlet screens and they were clean. Checked continuity on jumpers from control panel to water valve(s) and they tested good. Removed pressure tube from control panel and blew through it and did hear a faint air movement (not sure if this is normal or not). Also, checked continuity on water valve solenoids, there was no continuity, cold or hot which is odd since the water flow is normal. Sort of at a loss at the moment, not sure if it would be water valve or something to do with the pressure hose not give correct pressure for water level or something else. I do not have hot water turned out to washer, never have, this unit was purchased February of 2016. Any ideas out there would be greatly appreciated.
Thanks,
Trusbos
Related Models
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Whirlpool MW8300XL0 Microwaves*
Whirlpool MW8300XL2 Microwaves*
Whirlpool MW8300XP0 Microwaves*
 MW830BA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW830EXP0 Microwaves*
 MW830WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8400XL0 Microwaves*
Whirlpool MW8400XL2 Microwaves*
Whirlpool MW8400XR0 Microwaves*
Whirlpool MW8400XS0 Microwaves*
Whirlpool MW8400XS1 Microwaves*
Whirlpool MW8400XS2 Microwaves*
Whirlpool MW8400XW0 Microwaves*
 MW840BC MWAVE- CNTRTP / STAND ALONE
 MW840BC/XAA MWAVE- CNTRTP / STAND ALONE
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Help! Maytag Bravos Stuck On Sensing machouse36 Washer Repair 0 04-12-2017 04:12 PM
Maytag Bravos Drive Shaft Stuck Buddman72 Washer Repair 0 01-23-2017 11:19 AM
Kenmore Stuck on sensing alecd09 Washer Repair 0 01-17-2017 01:09 PM
Maytag Bravoe Dry Runs, No Heat, Stuck On Sensing. Lamf77 Dryer Repair 0 02-20-2013 07:15 AM
Kenmore Elite stuck sensing cunukster Dishwasher Repair 0 10-05-2008 11:54 AM
