Discuss
LG Tromm front Load
 in
Washer Repair
I was having two issues, a te code and significant balance issue during high speed spin. I diagnosed and replaced
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG Tromm front Load
  #1 (permalink)
Old 01-09-2018, 09:30 AM
Junior Member
tcreed is on a distinguished road
Default LG Tromm front Load
Model Number: WM2487HWM   Brand: -other-   Age: 5 - 10 years
I was having two issues, a te code and significant balance issue during high speed spin. I diagnosed and replaced the thermistor (repair worked fine) and decided to replace the shock absorbers at the same time hoping it would take care of the balance problem. The shock absorber replacement didn't make a noticeable improvement.
If I run a cycle with nothing in the drum, there is no problem. If I put any clothes in, especially with something like towels, the vibration is pretty bad and loud. The bearings sound fine and there does not seem to be any wobble on the shaft.
If I pause the machine and redistribute the load, it's not so bad.
I figure it must be the spider or the tub itself, or possibly a bent shaft. Is there a way to troubleshoot the spider. If I go through the trouble of replacing the spider, should I go ahead and replace the bearings at the same time? Could it possibly be an issue with the 'load sensing' procedure that takes place at the beginning of the cycle?
Related Models
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS0 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS1 MICROWAVE OVEN 1.6 Cu. Ft.
Whirlpool WMH1164XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1164XWS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVB2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVQ0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVQ2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVS0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVS1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVS2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2175XVT0 Microwave Oven 1.7 Cu. Ft.
Whirlpool WMH2175XVT1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH2175XVT2 MICROWAVE OVEN 1.7 CU. FT.
Whirlpool WMH2205XVB0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVB1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ0 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVQ1 Microwave Oven/Hood 2.0 Cu. Ft.
Whirlpool WMH2205XVS0 Microwave Oven/Hood 2.0 Cu. Ft.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Lg tromm front load washer wont turn on after bearing change Davidmb4777 Washer Repair 0 08-27-2017 05:30 AM
LG Tromm Front Load Washer Spin Problems murrayboston Washer Repair 0 09-29-2014 09:17 PM
LG Tromm Front Load Dryer will not start techiegirl Dryer Repair 1 11-28-2013 04:03 AM
How to remove front cover LG Tromm jpstiles02 Dryer Repair 1 01-11-2010 04:05 AM
