Discuss
top loading Maytag, won't spin or drain
 in
Washer Repair
I was wondering if anyone can assist in diagnosing the problem with my maytag washer, it is a top loading
Appliance Repair Forum > Appliance Repair Help > Washer Repair » top loading Maytag, won't spin or drain
  #1 (permalink)
Old 01-07-2018, 11:12 AM
Junior Member
scottfr is on a distinguished road
Default top loading Maytag, won't spin or drain
Model Number: SAV4655EWW   Brand: Maytag   Age: 5 - 10 years
I was wondering if anyone can assist in diagnosing the problem with my maytag washer, it is a top loading Maytag, model number SAV4655EWW
The washer won't spin or drain. It will go to the end of the wash cycle with a tub full of water. After the wash cycle completes, (without draining or spinning) the tub left full of water. I am able to get it to spin and drain by restarting a spin cycle, it will then drain and spin. However, after successfully draining, if I start a brand new cycle, the cycle ends again with the tub full of water.
Please note, that the the machine DOES cycle through the stages, only it does not drain and spin. As stated above, I can get it to drain by going back to the spin cycle and re-starting it from there. Another way I found to get it to drain and spin is that if it is middle of the what would be a spin cycle, if I open and close the lid, the washer will then drain and spin one time, for that cycle.
Any assistance would be appreciated.
Related Models
Maytag SAV4655EWW WASHER-TOP LOADING
Maytag SAV4710AWW WASHER-TOP LOADING
Maytag SAV505DAWQ WASHER-TOP LOADING
Maytag SAV505DAWW WASHER-TOP LOADING
Maytag SAV515DAWW WASHER-TOP LOADING
Maytag SAV515DEWW WASHER-TOP LOADING
Maytag SAV5300AWW WASHER-TOP LOADING
Maytag SAV5401AWW WASHER-TOP LOADING
Maytag SAV5600AWW WASHER-TOP LOADING
Maytag SAV5701AWQ WASHER-TOP LOADING
Maytag SAV5701AWW WASHER-TOP LOADING
Maytag SAV5710AWW WASHER-TOP LOADING
Maytag SAV571EEWW WASHER-TOP LOADING
Maytag SAV5910AWW WASHER-TOP LOADING
Maytag SAV5910EWW WASHER-TOP LOADING
Maytag SAW25K3S WASHER-TOP LOADING
Whirlpool SAWB600HQ0 AUTOMATIC WASHER
Whirlpool SAWB600JQ0 WASHER
Whirlpool SAWB600JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800HQ0 AUTOMATIC WASHER
Whirlpool SAWS800JQ0 WASHER
Whirlpool SAWS800JQ1 WASHER - DIRECT DRIVE
Whirlpool SAWS800JQ2 WASHER
Whirlpool SAWS800MQ0 AUTOMATIC WASHER
Whirlpool SAWS900HQ0 WASHER
Whirlpool SAWS900JQ0 WASHER - DIRECT DRIVE
Whirlpool SAWS900MQ0 AUTOMATIC WASHER
Whirlpool SAWX650JQ0 WASHER
Whirlpool SAWX650MQ0 AUTOMATIC WASHER
Whirlpool SAWX650MQ2 AUTOMATIC WASHER
Whirlpool SB1000SKN0 BUILT-IN GAS OVEN
Whirlpool SB100PEDB0 24" GAS BUILT-IN OVEN STANDARD CLEAN
Whirlpool SB100PEDB1 24" GAS BUILT-IN STANDARD CLEAN OVEN
Whirlpool SB100PEDB2 24" GAS BUILT-IN-OVEN STANDARD CLEAN
Whirlpool SB100PEDB4 GAS RANGE AND OVEN
Whirlpool SB100PEDB5 24" GAS SLIDE-IN RANGE
Whirlpool SB100PEK1 BUILT-IN GAS OVEN
Whirlpool SB100PER0 Range (gas)*
Whirlpool SB100PES0 Range (gas)*
Whirlpool SB100PES1 Range (gas)*
Whirlpool SB100PES2 Range (gas)*
Whirlpool SB100PES3 Range (gas)*
Whirlpool SB100PES4 GAS RANGES & OVENS
Whirlpool SB100PSK0 BUILT-IN GAS OVEN
Whirlpool SB100PSK1 BUILT-IN GAS OVEN
Whirlpool SB100PSR0 Range (gas)*
Whirlpool SB100PSR1 Range (gas)*
Whirlpool SB130PEDB0 24" GAS BUILT-IN OVEN CONTINUOUS CLEAN
Whirlpool SB130PEDB1 24" GAS BUILT-IN CONTINUOUS CLEAN OVEN
Whirlpool SB130PEDB2 24" GAS BUILT-IN-OVEN CONTINUOUS CLEAN
Whirlpool SB130PEK0 BUILT-IN GAS OVEN
Whirlpool SB130PER1 Range (gas)*
Whirlpool SB130PER2 Range (gas)*
Whirlpool SB130PER3 Range (gas)*
Whirlpool SB130PER4 GAS BUILT-IN OVEN
Whirlpool SB130PER5 24" GAS BUILT-IN OVEN ELECTRONIC IGNITION CONTINUOUS CLEAN OVEN
Whirlpool SB130PERW0 Range (gas)*
Whirlpool SB130PSK0 BUILT-IN GAS OVEN
Whirlpool SB160PEDB0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDB2 24" BUILT-IN-OVEN
Whirlpool SB160PEDB4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ0 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ1 24" BUILT-IN GAS OVEN
Whirlpool SB160PEDQ2 24" BUILT-IN-OVEN
Whirlpool SB160PEDQ4 24" BUILT-IN GAS OVEN
Whirlpool SB160PEEB1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEB2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEB5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEB6 BUILT-IN GAS OVEN
Whirlpool SB160PEEB7 BUILT-IN GAS OVEN
Whirlpool SB160PEEB8 BUILT-IN GAS OVEN
Whirlpool SB160PEEB9 BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ1 24" GAS BUILT-IN OVEN
Whirlpool SB160PEEQ2 24" BUILT-IN OVEN, GAS
Whirlpool SB160PEEQ5 24" BUILT-IN-OVEN GAS
Whirlpool SB160PEEQ6 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ7 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ8 BUILT-IN GAS OVEN
Whirlpool SB160PEEQ9 BUILT-IN OVEN, GAS
Whirlpool SB160PEXB0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ0 BUILT IN GAS OVEN
Whirlpool SB160PEXQ1 BUILT IN GAS OVEN
Amana SB21VE REF - SXS/I&W
Amana SB21VPSE REF - SXS/I&W
Amana SB21VW REF - SXS/I&W
Thermador SB2B
Amana SB520K REF - SXS/I&W
Amana SB520SW REF - SXS/I&W
Amana SB520TW REF - SXS/I&W
Amana SBC24FX0 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FX5 RANGE - ELECTRIC STD DELAWARE
Amana SBC24FXOW RANGE - ELECTRIC STD DELAWARE
Amana SBC26CK RANGE - ELECTRIC STD DELAWARE
Amana SBD20H REF - SXS/I&W
Amana SBD20J Ref - SXS/I&W
Amana SBD20K REF - SXS/I&W
Amana SBD20M REF - SXS/I&W
Amana SBD20MW REF - SXS/I&W
Amana SBD20NE REF - SXS/I&W
Amana SBD20NW REF - SXS/I&W
Amana SBD20Q2E REF - SXS/I&W
Amana SBD20Q2W REF - SXS/I&W
Amana SBD20S4E REF - SXS/I&W
Amana SBD20S4L REF - SXS/I&W
Amana SBD20S4W REF - SXS/I&W
Amana SBD20TPE REF - SXS/I&W
  #2 (permalink)
Old 01-07-2018, 03:38 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
It could be your lid switch. Try opening and closing the lid the next time it stops. It might be bent or going bad internally. part no. 16
Parts for Maytag SAV4655EWW: Top and Door Switch Parts - AppliancePartsPros.com
  #3 (permalink)
Old 01-07-2018, 06:03 PM
Junior Member
Default
Thank you!
  #4 (permalink)
Old 01-28-2018, 10:37 AM
Junior Member
Default
unfortunately that did not resolve the problem. Any other possible recommendations?
Thanks in advance!
Regards,
Scott
  #5 (permalink)
Old 02-03-2018, 09:32 AM
Junior Member
Default
Unfortunately that did not resolve the problem. Would you recommend anything else?
Thanks,
Scott
  #6 (permalink)
Old 02-04-2018, 03:59 AM
ThatGuy's Avatar
Expert
APP Volunteer
Default
The next time it doesn't spin don't touch lid or anything else.
Reach over and grab the timer knob without pulling or pushing it in. Push it up, then to the right, then down, and then to the left.
If the motor comes on, the timer has bad contacts inside and will need to be replaced.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag top-loading Washer won't agitate, spin or drain coastalhousewife Washer Repair 1 07-02-2015 04:20 PM
GE Front Loading Washer Won't Drain or Spin gblotter Washer Repair 1 02-08-2013 10:24 PM
Maytag style top loading washer will not spin or agitate Mike442 Washer Repair 1 05-12-2012 08:49 PM
Frigidaire Gallery top loading washer doesn't drain or spin owkaye Washer Repair 1 03-19-2012 04:20 AM
Maytag Atlantis top loading washer doesn't spin out water ramchaza Washer Repair 2 03-22-2010 09:47 AM
