Discuss
complicated request
 in
Washer Repair
i have possibly two issues that are intertwined.. I will try to be brief. I find a puddle of water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » complicated request
  #1 (permalink)
Old 01-06-2018, 07:35 AM
Junior Member
tbonham27 is on a distinguished road
Default complicated request
Model Number: mavt834AAW   Brand: Maytag   Age: 5 - 10 years
I find a puddle of water in my garage and track it back to my laundry closet, water under machine.. I am sick, I unplug it and close the valves because the hard wood is already ruined. not massive amounts of water. just pooling underneath. after a day and a half sick in bed I see that the puddle in the garage has increased by atleast 50 percent (about 9 sq ft not including the supply trail.
### we were winding down a 96 hour streak of below freezing temps and the supply and drain for the machine is opposite the garage area which is not insulate and neither was the stud run housing my plumbing. so obviously a potential cause.
not being able to recreate a inoperable drain I took the machine apart to look for leak or cause visually with no luck. I filled the drum with water and it held with zero leaks from drum to pump to drain spout
the only noticeable mechanical issue I could find was that with belt on or off the drum would easily spin from the bottom in both directions but from the top just a few inches before freezing up either way.
I am asking for thoughts on the repair as well as thoughts whether the water is somehow related to a failed hub or bearing. is it possible the water sloshed from the tub and flooded the inside? what should I buy or what should I look for.. the freezing plumbing scenario is possible but I doubt it was affected considering it wasn't on an exterior wall and my equipment in the garage was not affected. ie pressure wash lawn mower ect. thanks in advance
Related Models
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Maytag MBF2255KEB11 REFRIGERATOR
Maytag MBF2255KEQ REF - BOTTOM MOUNTS
Maytag MBF2255KEQ11 REFRIGERATOR
Maytag MBF2255KEW REF - BOTTOM MOUNTS
Maytag MBF2255KEW11 REFRIGERATOR
Maytag MBF2256HEB REF - BOTTOM MOUNTS
Maytag MBF2256HEQ REF - BOTTOM MOUNTS
Maytag MBF2256HES REF - BOTTOM MOUNTS
Maytag MBF2256HEW REF - BOTTOM MOUNTS
Maytag MBF2256KEB REF - BOTTOM MOUNTS
Maytag MBF2256KEB11 REFRIGERATOR
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Complicated Repair Advantium TxDan Microwave Repair 0 03-19-2017 07:07 PM
Simple fix just got complicated...help? claytong Washer Repair 1 06-24-2014 07:08 AM
Complicated repair story - help? lapete95 Washer Repair 1 07-19-2011 06:16 AM
Over the Range Microwave blew a fuze...Complicated abayomi Microwave Repair 1 01-27-2009 01:46 PM
