Discuss
Loud clicking noise during the spin cycle
 in
Washer Repair
Our washer will agitate normally but will produce a loud clicking noise during the spin cycle. The machine will begin
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Loud clicking noise during the spin cycle
  #1 (permalink)
Old 12-10-2017, 04:11 PM
Junior Member
thekidseateverything is on a distinguished road
Default Loud clicking noise during the spin cycle
Model Number: 11023032100   Brand: Kenmore   Age: 5 - 10 years
Our washer will agitate normally but will produce a loud clicking noise during the spin cycle. The machine will begin the spin cycle but will not advance to the high speed spin. When this happens, the lights in our kitchen will dim in time with the clicking noise. What I've done so far:
-Removed and cleaned the pump after draining the water
-Removed the housing and reconnected the lid switch so that I could operate the spin cycle
-I visibly observed an arc inside the motor that corresponds with the clicking sound
-Pulled the motor and tested resistance across all terminals - all normal
-Pulled the motor switch and tested it for continuity in the open and closed position on all terminals - all normal
I'm fairly certain its the motor but I get sick thinking that I may be wasting $250 by ordering a new motor when it may be something else. Is it possible to replace the centrifugal switch? Or test it?
Please help.
Related Models
Kenmore 11023032100 WASHER
Kenmore 11023032101 AUTOMATIC WASHER
Kenmore 11023032102 AUTOMATIC WASHER
Kenmore 11023034100 WASHER
Kenmore 11023034101 AUTOMATIC WASHER
Kenmore 11023034102 AUTOMATIC WASHER
Kenmore 11023036100 WASHER
Kenmore 11023036101 AUTOMATIC WASHER
Kenmore 11023036102 AUTOMATIC WASHER
Kenmore 11023652200 AUTOMATIC WASHER
Kenmore 11023662200 AUTOMATIC WASHER
Kenmore 11023692200 AUTOMATIC WASHER
Kenmore 11023712200 AUTOMATIC WASHER
Kenmore 11023722200 AUTOMATIC WASHER
Kenmore 11023732200 AUTOMATIC WASHER
Kenmore 11023812100 AUTOMATIC WASHER
Kenmore 11023822100 AUTOMATIC WASHER
Kenmore 11023832100 AUTOMATIC WASHER
Kenmore 11023902200 AUTOMATIC WASHER
Kenmore 11023902201 AUTOMATIC WASHER
Kenmore 11023904200 AUTOMATIC WASHER
Kenmore 11023904201 AUTOMATIC WASHER
Kenmore 11023912100 AUTOMATIC WASHER
Kenmore 11023912101 AUTOMATIC WASHER
Kenmore 11023912102 AUTOMATIC WASHER
Kenmore 11023922200 AUTOMATIC WASHER
Kenmore 11023922201 AUTOMATIC WASHER
Kenmore 11023924200 AUTOMATIC WASHER
Kenmore 11023924201 AUTOMATIC WASHER
Kenmore 11023932200 WASHER
Kenmore 11023934200 WASHER
Kenmore 11024032301 AUTOMATIC WASHER
Kenmore 11024036301 AUTOMATIC WASHER
Kenmore 11024042301 AUTOMATIC WASHER
Kenmore 11024052300 AUTOMATIC WASHER
Kenmore 11024054300 AUTOMATIC WASHER
Kenmore 11024056300 AUTOMATIC WASHER
Kenmore 11024082200 AUTOMATIC WASHER
Kenmore 11024084200 AUTOMATIC WASHER
Kenmore 11024086200 AUTOMATIC WASHER
Kenmore 11024292300 AUTOMATIC WASHER
Kenmore 11024294300 AUTOMATIC WASHER
Kenmore 11024422300 AUTOMATIC WASHER
Kenmore 11024432300 AUTOMATIC WASHER
Kenmore 11024442300 AUTOMATIC WASHER
Kenmore 11024622300 AUTOMATIC WASHER
Kenmore 11024632300 AUTOMATIC WASHER
Kenmore 11024642300 AUTOMATIC WASHER
Kenmore 11024652300 AUTOMATIC WASHER
Kenmore 11024662300 AUTOMATIC WASHER
Kenmore 11024692300 AUTOMATIC WASHER
Kenmore 11024712300 AUTOMATIC WASHER
Kenmore 11024722300 AUTOMATIC WASHER
Kenmore 11024732300 AUTOMATIC WASHER
Kenmore 11024812200 AUTOMATIC WASHER
Kenmore 11024812201 AUTOMATIC WASHER
Kenmore 11024822200 AUTOMATIC WASHER
Kenmore 11024822201 AUTOMATIC WASHER
Kenmore 11024832200 AUTOMATIC WASHER
Kenmore 11024832201 AUTOMATIC WASHER
Kenmore 11024852300 AUTOMATIC WASHER
Kenmore 11024862300 AUTOMATIC WASHER
Kenmore 11024872300 AUTOMATIC WASHER
Kenmore 11024892300 AUTOMATIC
Kenmore 11024894300 AUTOMATIC
Kenmore 11024902200 AUTOMATIC WASHER
Kenmore 11024902201 AUTOMATIC WASHER
Kenmore 11024902202 AUTOMATIC WASHER
Kenmore 11024904200 AUTOMATIC WASHER
Kenmore 11024904201 AUTOMATIC WASHER
Kenmore 11024904202 AUTOMATIC WASHER
Kenmore 11024922200 AUTOMATIC WASHER
Kenmore 11024922201 AUTOMATIC WASHER
Kenmore 11024922202 AUTOMATIC WASHER
Kenmore 11024924200 AUTOMATIC WASHER
Kenmore 11024924201 AUTOMATIC WASHER
Kenmore 11024924202 AUTOMATIC WASHER
Kenmore 11024932200 AUTOMATIC WASHER
Kenmore 11024932201 AUTOMATIC WASHER
Kenmore 11024932202 AUTOMATIC WASHER
Kenmore 11024934200 AUTOMATIC WASHER
Kenmore 11024934201 AUTOMATIC WASHER
Kenmore 11024934202 AUTOMATIC WASHER
Kenmore 11024942300 AUTOMATIC WASHER
Kenmore 11024942301 RESIDENTIAL WASHER
Kenmore 11024944300 AUTOMATIC WASHER
Kenmore 11024944301 RESIDENTIAL WASHER
Kenmore 11024946300 AUTOMATIC WASHER
Kenmore 11024946301 RESIDENTIAL WASHER
Kenmore 11024952300 AUTOMATIC WASHER
Kenmore 11024952301 RESIDENTIAL WASHER
Kenmore 11024954300 AUTOMATIC WASHER
Kenmore 11024954301 RESIDENTIAL WASHER
Kenmore 11024956300 AUTOMATIC WASHER
Kenmore 11024956301 RESIDENTIAL WASHER
Kenmore 11024962300 AUTOMATIC WASHER
Kenmore 11024962301 RESIDENTIAL WASHER
Kenmore 11024964300 AUTOMATIC WASHER
Kenmore 11024964301 RESIDENTIAL WASHER
Kenmore 11024966300 AUTOMATIC WASHER
Kenmore 11024966301 RESIDENTIAL WASHER
Kenmore 11024972300 AUTOMATIC WASHER
Kenmore 11024974300 AUTOMATIC WASHER
Kenmore 11024982300 AUTOMATIC WASHER
Kenmore 11024992300 AUTOMATIC WASHER
Kenmore 11024994300 AUTOMATIC WASHER
Kenmore 11024996300 AUTOMATIC WASHER
Kenmore 11025062500 WASHER
Kenmore 11025064500 WASHER
Kenmore 11025066500 WASHER
Kenmore 11025292500 WASHER
Kenmore 11025292501 WASHER
Kenmore 11025292502 RESIDENTIAL WASHER
Kenmore 11025292503 RESIDENTIAL WASHER
Kenmore 11025294500 WASHER
Kenmore 11025294501 WASHER
Kenmore 11025294502 RESIDENTIAL WASHER
Kenmore 11025294503 RESIDENTIAL WASHER
Kenmore 11025832400 RESIDENTIAL WASHER
Kenmore 11025842400 AUTOMATIC WASHER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Clicking noise during spin cycle lineman6464 Washer Repair 1 10-31-2011 05:34 PM
GE-loud clicking noise while trying to spin Gerald Crowe Washer Repair 1 04-22-2011 03:52 PM
Washer makes a loud clicking noise on spin cycle pattihanni Washer Repair 0 05-02-2009 09:40 AM
Load clicking noise before spin cycle carriew Washer Repair 0 04-08-2009 08:22 AM
Clicking noise going into spin cycle jedvorak Washer Repair 1 01-05-2009 07:30 AM
