Discuss
Timer not triggering spin cycle automatically
 in
Washer Repair
Hi, my washing machine is not triggering the spin cycle automatically. When I use Normal or Perm Press to start
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Timer not triggering spin cycle automatically
  #1 (permalink)
Old 11-02-2017, 08:00 AM
Junior Member
syrist is on a distinguished road
Default Timer not triggering spin cycle automatically
Model Number: 700 (W10140919 A)   Brand: Kenmore   Age: 1 - 5 years
When I use Normal or Perm Press to start the machine... the timer moves as normal but when it reaches the spin cycle, it just keeps on agitating until the timer reaches off and stops. When I go back to the machine, the clothes are just sitting in dirty water.
At this point, the only way to start the spin/drain cycle is by manually rotating the switch to that position and starting the machine. It then spins/drains like normal.
So basically... the spin cycle won't trigger automatically but can be manually triggered. Is this a problem with the timer?
The lid switch seems fine because when I manually trigger the spin cycle and then lift the lid, the spinning stops.
Model: 110.28782700
Type: 111-01
Serial: CU4940094
Thanks,
-Pete
Related Models
Amana 7000.000 MWAVE - FAMILY SIZE (60 HZ)
Frigidaire 7001-80A ELECTRIC DRYER
Frigidaire 7007-80C ELECTRIC DRYER
Frigidaire 7007-80D ELECTRIC DRYER
Frigidaire 7007-80E ELECTRIC DRYER
Frigidaire 7007-87C ELECTRIC DRYER
Frigidaire 7007-87D ELECTRIC DRYER
Frigidaire 7007-87E ELECTRIC DRYER
Frigidaire 7007B ELECTRIC DRYER
Hoover 701
Hardwick 70131 RANGE- F/S STD GAS
Hardwick 70138 RANGE- F/S STD GAS
Maytag 701C DRYER- GAS
Hardwick 70231 RANGE- F/S STD GAS
Hardwick 70238 RANGE- F/S STD GAS
Hoover 704
Hoover 704-01
Hoover 705
Hoover 706
Hoover 707
Amana 7096 MWAVE - FAMILY SIZE (60 HZ)
Maytag 70C DRYER- GAS
Hoover 711
Amana 7121.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 714
Amana 7154.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 716
Amana 7160.000 MWAVE - FAMILY SIZE (60 HZ)
Hoover 719
Amana 7190.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 7190.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 7196 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 7198772780 Microwave Domestic
Kenmore 7198842780 MICROWAVE OVEN
Frigidaire 72-2547-00-01 Tap(v1) / Gas Range
Frigidaire 72-2547-00-02 Tap(v4) / Gas Range
Frigidaire 72-2547-00-03 Tap(v7) / Gas Range
Frigidaire 72-2547-00-04 Tap(v1) / Gas Range
Frigidaire 72-2547-00-05 Tap(v4) / Gas Range
Frigidaire 72-2547-00-06 Tap(v7) / Gas Range
Frigidaire 72-2547-00-07 Tap(v1) / Gas Range
Frigidaire 72-2547-00-08 Tap(v1) / Gas Range
Frigidaire 72-2547-00-09 Tap(v1) / Gas Range
Frigidaire 72-2547-23-01 Tap(v2) / Gas Range
Frigidaire 72-2547-23-02 Tap(v5) / Gas Range
Frigidaire 72-2547-23-03 Tap(v8) / Gas Range
Frigidaire 72-2547-23-04 Tap(v2) / Gas Range
Frigidaire 72-2547-23-05 Tap(v5) / Gas Range
Frigidaire 72-2547-23-06 Tap(v8) / Gas Range
Frigidaire 72-2547-23-07 Tap(v2) / Gas Range
Frigidaire 72-2547-23-08 Tap(v2) / Gas Range
Frigidaire 72-2547-23-09 Tap(v2) / Gas Range
Frigidaire 72-2547-66-01 Tap(v3) / Gas Range
Frigidaire 72-2547-66-02 Tap(v6) / Gas Range
Frigidaire 72-2547-66-03 Tap(v9) / Gas Range
Frigidaire 72-2547-66-04 Tap(v3) / Gas Range
Frigidaire 72-2547-66-05 Tap(v6) / Gas Range
Frigidaire 72-2547-66-06 Tap(v9) / Gas Range
Frigidaire 72-2547-66-07 Tap(v3) / Gas Range
Frigidaire 72-2547-66-08 Tap(v3) / Gas Range
Frigidaire 72-2547-66-09 Tap(v3) / Gas Range
Tappan 72-3651-00 RANGE
Frigidaire 72-3651-00-01 Tap(v1) / Gas Range
Frigidaire 72-3651-00-02 Tap(v1) / Gas Range
Frigidaire 72-3651-00-03 Tap(v3) / Gas Range
Frigidaire 72-3651-00-04 Tap(v1) / Gas Range
Frigidaire 72-3651-00-05 Tap(v1) / Gas Range
Frigidaire 72-3651-00-06 Tap(v1) / Gas Range
Frigidaire 72-3651-00-07 Tap(v2) / Gas Range
Frigidaire 72-3651-00-08 Tap(v1) / Gas Range
Tappan 72-3651-01 RANGE
Frigidaire 72-3651-23-01 Tap(v2) / Gas Range
Frigidaire 72-3651-23-02 Tap(v2) / Gas Range
Frigidaire 72-3651-23-03 Tap(v4) / Gas Range
Frigidaire 72-3651-23-04 Tap(v2) / Gas Range
Frigidaire 72-3651-23-05 Tap(v2) / Gas Range
Frigidaire 72-3651-23-06 Tap(v3) / Gas Range
Frigidaire 72-3651-23-07 Tap(v4) / Gas Range
Frigidaire 72-3651-23-08 Tap(v2) / Gas Range
Frigidaire 72-3657-00-01 Tap(v1) / Gas Range
Frigidaire 72-3657-00-02 Tap(v4) / Gas Range
Frigidaire 72-3657-00-03 Tap(v1) / Gas Range
Frigidaire 72-3657-00-04 Tap(v4) / Gas Range
Frigidaire 72-3657-00-05 Tap(v1) / Gas Range
Frigidaire 72-3657-00-06 Tap(v7) / Gas Range
Frigidaire 72-3657-00-07 Tap(v1) / Gas Range
Frigidaire 72-3657-00-08 Tap(v1) / Gas Range
Frigidaire 72-3657-00-09 Tap(v7) / Gas Range
Frigidaire 72-3657-00-10 Tap(v1) / Gas Range
Frigidaire 72-3657-00-11 Tap(v4) / Gas Range
Frigidaire 72-3657-00-12 Tap(v7) / Gas Range
Frigidaire 72-3657-00-13 Tap(v1) / Gas Range
Frigidaire 72-3657-23-01 Tap(v2) / Gas Range
Frigidaire 72-3657-23-02 Tap(v5) / Gas Range
Frigidaire 72-3657-23-03 Tap(v2) / Gas Range
Frigidaire 72-3657-23-04 Tap(v5) / Gas Range
Frigidaire 72-3657-23-05 Tap(v2) / Gas Range
Frigidaire 72-3657-23-06 Tap(v8) / Gas Range
Frigidaire 72-3657-23-07 Tap(v2) / Gas Range
Frigidaire 72-3657-23-08 Tap(v2) / Gas Range
Frigidaire 72-3657-23-09 Tap(v8) / Gas Range
Frigidaire 72-3657-23-10 Tap(v2) / Gas Range
Frigidaire 72-3657-23-11 Tap(v5) / Gas Range
Frigidaire 72-3657-23-12 Tap(v8) / Gas Range
Frigidaire 72-3657-23-13 Tap(v2) / Gas Range
Frigidaire 72-3657-66-01 Tap(v3) / Gas Range
Frigidaire 72-3657-66-02 Tap(v6) / Gas Range
Frigidaire 72-3657-66-03 Tap(v3) / Gas Range
Frigidaire 72-3657-66-04 Tap(v6) / Gas Range
Frigidaire 72-3657-66-05 Tap(v3) / Gas Range
Frigidaire 72-3657-66-06 Tap(v9) / Gas Range
Frigidaire 72-3657-66-07 Tap(v3) / Gas Range
Frigidaire 72-3657-66-08 Tap(v3) / Gas Range
Frigidaire 72-3657-66-09 Tap(v9) / Gas Range
Frigidaire 72-3657-66-10 Tap(v3) / Gas Range
Frigidaire 72-3657-66-11 Tap(v6) / Gas Range
Frigidaire 72-3657-66-12 Tap(v9) / Gas Range
Frigidaire 72-3657-66-13 Tap(v3) / Gas Range
Frigidaire 72-3662-00-01 Tap(v1) / Gas Range
Frigidaire 72-3662-23-01 Tap(v2) / Gas Range
  #2 (permalink)
Old 11-18-2017, 04:59 AM
Junior Member
Default
I took and chance and bought a new timer from ******** and it fixed the problem. The rince/drain cycle now activates automatically like it should.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool timer won't engage automatically Thalwandi Washer Repair 1 11-11-2011 06:54 PM
Timer is going to Rinse and Spin automatically. Mohiddin Washer Repair 0 06-27-2011 08:15 PM
Dryer won't automatically stop on timer msirota Dryer Repair 1 03-21-2011 03:49 AM
Whirlpool washer won't automatically switch from wash cycle to rinse cycle WEED Washer Repair 2 07-21-2010 08:49 AM
Maytag timer doesn't advance to Spin automatically John Burgess Washer Repair 1 07-23-2009 03:34 PM
