Discuss
Default Maytag Norge style starts agitating in spin cycle
 in
Washer Repair
So my trusty 12 year old washer has developed an issue with the spin cycle. Yesterday, after spinning most of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Default Maytag Norge style starts agitating in spin cycle
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 11-01-2017, 08:13 PM
Junior Member
thefisch is on a distinguished road
Default Default Maytag Norge style starts agitating in spin cycle
Model Number: mav9657eww   Brand: Maytag   Age: More than 10 years
So my trusty 12 year old washer has developed an issue with the spin cycle. Yesterday, after spinning most of the water out of two prior loads, the final load resulted in clothes that were still wet and needed to be wrung out. Clearly the spin cycle didn't work. The load was rather small so it wasn't overloaded. Trying the spin cycle again didn't seem to remove any more water after several more minutes.
I removed the front panel and raised the top to view operation. The wash/agitation cycle seems to work fine - agitation is normal with good suds and splash. When it comes time to spin, the motor reverses direction and the inner basket and transmission begin to spin clockwise (from above) as one, the agitator starts to spin along too, and the drain pump is engaged. As the spinning increases in speed, the water drains out just fine - mini level takes about 20 seconds to fully drain. The speed gets fast enough that the holes in the inner basket and the splines on the agitator assembly start to blur as they spin. However, after about a minute in spin mode both the inner tub and transmission housing slow down and stop. The agitator assembly slows too and then begins to agitate back and forth like during the wash cycle (note there is no change in direction of the motor). The motor and drain pump continue to run as they normally would in the clockwise direction. There is no audible change in sound when the tub starts to slow and stop.
Looking under the unit during the spin cycle (when basket is spinning and after it slows and stops), the belt and transmission pulley continue to turn without any signs of belt slippage or change in speed. But the transmission pulley is no longer spinning the transmission housing above it. It is almost like they've become disconnected somehow after a minute and the tranny starts to run in the other direction like during a wash cycle. If I raise the lid to stop the motor and then lower it to restart, the basket doesn't move and the agitator shifts back and forth again. The only way to get the basket and transmission to start spinning again is to first go run the wash/rinse cycle again where the motor is running in the other direction. Then when the spin cycle begins, the motor reverses direction, the basket/tranny.agitator will spin, the water will drain, and after about a minute the basket/tranny stops again and the agitator assembly agitates. For some reason the spinning gives up after a minute.
I have read the advice for washers that don't spin and the thrust bearing kit is suggested. However, in those cases it wasn't clear to me that their washers would begin to spin and then stop. So I am sharing that detail in case it matters.
With the washer off, I inspected the tranny pulley. No matter which direction I turn the pulley by hand, the inner basket does not turn. I removed the dust cap and inspected the reference cam arrow. When I rotate the pulley CCW (as viewed from below) the arrow does move and stops about a quarter inch inside the min hub reference. So it is between the min and max.
I can attach photos and video it that helps. At first I hoped it was just the thrust bearing but am worried it might be the transmission.
Thanks in advance for the advice.
Related Models
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
Maytag MBF2254HEW14 REFRIGERATOR
Maytag MBF2254HEW4 REFRIGERATOR
Maytag MBF2255KEB REF - BOTTOM MOUNTS
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
starts agitating immediately and soaks after spin muzcuk Washer Repair 0 12-24-2016 12:47 PM
Maytag Washer starts and stops during spin cycle but completes cycle jtt21 Washer Repair 8 06-01-2013 04:24 PM
Maytag style top loading washer will not spin or agitate Mike442 Washer Repair 1 05-12-2012 08:49 PM
Kenmore Washer 1102982 starts cycle by agitating shengnes Washer Repair 5 10-11-2010 07:04 AM
spin cycle starts slows starts grhodes Washer Repair 0 12-18-2007 02:50 AM
