Discuss
Kenmore Series 90 Washer Agitates Clockwise
 in
Washer Repair
Our Kenmore Series 90 washer drains and spins normally. However, when it agitates, the lower section only moves in a
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 90 Washer Agitates Clockwise
  #1 (permalink)
Old 10-30-2017, 09:02 PM
Junior Member
tomgf is on a distinguished road
Default Kenmore Series 90 Washer Agitates Clockwise
Model Number: 11020902990   Brand: Kenmore   Age: More than 10 years
Our Kenmore Series 90 washer drains and spins normally. However, when it agitates, the lower section only moves in a clockwise direction, even when pressing down on the agitator assembly.
I have replaced the drive coupler several times over the years and the lid switch was replaced a couple of years ago. The transmission was rebuilt about two and a half years ago.
What should I check as a possible cause?
Thanks!
Related Models
Kenmore 11020902990 AUTOMATIC WASHER
Kenmore 11020902991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020904990 AUTOMATIC WASHER
Kenmore 11020904991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020907990 AUTOMATIC WASHER
Kenmore 11020907991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020912990 AUTOMATIC WASHER
Kenmore 11020912991 WASHER
Kenmore 11020922990 AUTOMATIC WASHER
Kenmore 11020922991 WASHER
Kenmore 11020924990 AUTOMATIC WASHER
Kenmore 11020924991 WASHER
Kenmore 11020927990 AUTOMATIC WASHER
Kenmore 11020932990 AUTOMATIC WASHER
Kenmore 11020932991 AUTOMATIC WASHER
Kenmore 11020932992 AUTOMATIC WASHER
Kenmore 11020932993 WASHER
Kenmore 11020932994 WASHER
Kenmore 11020936990 AUTOMATIC WASHER
Kenmore 11020936991 AUTOMATIC WASHER
Kenmore 11020936992 AUTOMATIC WASHER
Kenmore 11020936993 WASHER
Kenmore 11020936994 WASHER
Kenmore 11020942990 AUTOMATIC WASHER
Kenmore 11020942991 AUTOMATIC WASHER
Kenmore 11020942992 AUTOMATIC WASHER
Kenmore 11020942993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020942994 WASHER
Kenmore 11020952990 AUTOMATIC WASHER
Kenmore 11020952991 AUTOMATIC WASHER
Kenmore 11020952992 AUTOMATIC WASHER
Kenmore 11020952993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020952994 WASHER
Kenmore 11020954992 AUTOMATIC WASHER
Kenmore 11020954993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020954994 WASHER
Kenmore 11020956990 AUTOMATIC WASHER
Kenmore 11020956991 AUTOMATIC WASHER
Kenmore 11020956992 AUTOMATIC WASHER
Kenmore 11020956993 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11020956994 WASHER
Kenmore 11020957990 AUTOMATIC WASHER
Kenmore 11020957991 AUTOMATIC WASHER
Kenmore 11020957992 AUTOMATIC WASHER
Kenmore 11020972990 WASHER
Kenmore 11020972991 WASHER
Kenmore 11020972992 WASHER
Kenmore 11020972993 WASHER
Kenmore 11020982990 WASHER
Kenmore 11020982991 WASHER
Kenmore 11020982992 WASHER
Kenmore 11020982993 WASHER
Kenmore 11020992990 WASHER
Kenmore 11020992991 WASHER
Kenmore 11020992992 WASHER
Kenmore 11020992993 WASHER
Kenmore 11020994991 WASHER
Kenmore 11020994992 WASHER
Kenmore 11020994993 WASHER
Kenmore 11020996991 WASHER
Kenmore 11020996992 WASHER
Kenmore 11020996993 WASHER
Kenmore 11020997990 WASHER
Kenmore 11020997991 WASHER
Kenmore 11020997992 WASHER
Kenmore 11021062000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021062001 WASHER
Kenmore 11021064000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021064001 WASHER
Kenmore 11021066000 AUTOMACTIC WASHER, COMPACT A/W
Kenmore 11021066001 WASHER
Kenmore 11021082000 WASHER
Kenmore 11021082001 WASHER
Kenmore 11021084000 WASHER
Kenmore 11021084001 WASHER
Kenmore 11021086000 WASHER
Kenmore 11021086001 WASHER
Kenmore 11021102010 AUTOMATIC WASHER
Kenmore 11021102011 AUTOMATIC WASHER
Kenmore 11021112010 AUTOMATIC WASHER
Kenmore 11021112011 AUTOMATIC WASHER
Kenmore 11021182010 AUTOMATIC WASHER
Kenmore 11021182011 AUTOMATIC WASHER
Kenmore 11021202010 AUTOMATIC WASHER
Kenmore 11021202011 AUTOMATIC WASHER
Kenmore 11021252110 AUTOMATIC WASHER
Kenmore 11021292010 AUTOMATIC WASHER
Kenmore 11021292011 AUTOMATIC WASHER
Kenmore 11021302010 AUTOMATIC WASHER
Kenmore 11021302011 AUTOMATIC WASHER
Kenmore 11021352110 AUTOMATIC WASHER
Kenmore 11021392010 AUTOMATIC WASHER
Kenmore 11021392011 AUTOMATIC WASHER
Kenmore 11021392012 AUTOMATIC WASHER
Kenmore 11021882000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021882001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884000 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021884001 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11021892000 WASHER
Kenmore 11021894000 WASHER
Kenmore 11022032100 WASHER
Kenmore 11022032101 WASHER
Kenmore 11022032102 AUTOMATIC WASHER
Kenmore 11022036100 WASHER
Kenmore 11022036101 WASHER
Kenmore 11022036102 AUTOMATIC WASHER
Kenmore 11022042100 WASHER
Kenmore 11022042101 WASHER
Kenmore 11022042102 AUTOMATIC
Kenmore 11022052100 WASHER
Kenmore 11022052101 WASHER
Kenmore 11022052102 AUTOMATIC WASHER
Kenmore 11022054100 WASHER
Kenmore 11022054101 WASHER
Kenmore 11022054102 AUTOMATIC WASHER
Kenmore 11022056100 WASHER
Kenmore 11022056101 WASHER
Kenmore 11022056102 AUTOMATIC WASHER
Kenmore 11022062100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11022062101 WASHER
  #2 (permalink)
Old 10-31-2017, 06:29 AM
Senior Member
brobriffin is on a distinguished road
Default
When you press down on the agitator and it's only spinning clockwise, can you feel if its trying to turn counter clockwise? It might then be an issue with the transmission. or
Can you spin the lower section by hand at all in either direction? If so the lower section of the agitator has splines that fit over the drive shaft, they may be wearing out or the 7/16 bolt may be loose holding in place.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore 70 series washer agitates but does not spin tismichael Washer Repair 9 11-16-2013 04:48 PM
Estate washer only agitates in clockwise direction pbrooks259 Washer Repair 1 08-24-2013 05:25 PM
Kenmore 90 plus series washer won't spin, barely agitates, will drain & makes noise Maryland Mom Washer Repair 3 08-24-2012 04:32 PM
kenmore 90 series washer agitates fine barely spins vbnitro2010 Washer Repair 3 08-13-2010 07:37 AM
Kenmore 90 series washer agitates, drains but it Won't SPiN ! selcukbey Washer Repair 3 05-19-2008 11:27 AM
