Discuss
new timer only allows hot water in cottons regular heavy dial position
 in
Washer Repair
I ordered and got a replacement timer from parts pros last July 2009. Replacement timer only allows hot water to
Appliance Repair Forum > Appliance Repair Help > Washer Repair » new timer only allows hot water in cottons regular heavy dial position
  #1 (permalink)
Old 11-04-2009, 04:05 PM
oldergewasher oldergewasher is offline
Junior Member
oldergewasher is on a distinguished road
Default new timer only allows hot water in cottons regular heavy dial position
Model Number: wcxr1070t2ww   Brand: GE   Age: More than 10 years
Replacement timer only allows hot water to enter machine when
cycle knob is set to "cottons regular-'heavy.'" dial position. (temp switch always set to hot wash, cold rinse position.)
No hot water is admitted when dial is set to 'medium' or 'light soil'
positions.
No hot water is admitted when dial is set to any "permanent press"
position.
I checked wiring diagram and observed that timer plug contacts 4 and 5 need to be closed (current flowing) in order for hot water to be admitted.
I disassembled timer and inspected the big wheel with the cams on it.
The cam in position to cause the connection between contacts 4 and 5
is only in long enough to work in the "cotton regular-heavy" dial position.
I reordered another timer which arrived 11-04-2009.
I thought the July timer had a special purpose cam wheel which was shipped to me in error.
To be cautious, I did not install today's timer. I checked this timer with an ohm-meter between connector terminals 4 and 5.
The ohmmeter only measured zero ohms (current flowing) when cycle dial was in the same position described above. cottons regular-heavy
(speculation on my part in the sentence below. )
GE used a timer subcontractor named Kingston. Did someone recently
mandate a new "energy saving" cam wheel be used ? I do not wish to
have a limit on when I can and can not get hot (also warm) water.
thanks
Related Models
General Electric WCXR1070T2WW Washer
General Electric WCXR1070T3AA Washer
General Electric WCXR1070T3WW Washer
General Electric WCXR1070T4AA Washer
General Electric WCXR1070T4WW Washer
General Electric WCXR1070T5AA Washer
General Electric WCXR1070T5WW Washer
General Electric WCXR1070T8AA Washer
General Electric WCXR1070T8WW Washer
General Electric WCXR1070TAAA Washer
General Electric WCXR1070TAWW Washer
General Electric WCXR1070TBAA Washer
General Electric WCXR1070TBWW Washer
Magic Chef WCZ1050 Washer - Top Loading
Magic Chef WCZ1050AM Washer - Top Loading
Magic Chef WCZ1050W Washer - Top Loading
Thermador WD24
Thermador WD24N
Thermador WD24NS
Thermador WD24NW
Thermador WD24QB
Thermador WD24QPRS
Thermador WD24QS
Thermador WD24QW
Thermador WD24S
Thermador WD24W
Thermador WD24WC
Thermador WD27QB
Thermador WD27QPRS
Thermador WD27QS
Thermador WD27QW
Frigidaire WD300J Wwh(v1) / Disposer
Frigidaire WD301J Wwh(v2) / Disposer
Thermador WD30XB
Thermador WD30XP
Thermador WD30XS
Thermador WD30XW
Frigidaire WD350M Wwh(v3) / Disposer
Frigidaire WD500J Wwh(v3) / Disposer
Frigidaire WD550J Wwh(v1) / Disposer
Frigidaire WD551J Wwh(v2) / Disposer
Frigidaire WD750J Wwh(v3) / Disposer
Frigidaire WD850J Wwh(v1) / Disposer
White Westinghouse WDB11NRDB0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDB1 White Westinghouse/dishwasher
White Westinghouse WDB11NRDB2 White Westinghouse/dishwasher
White Westinghouse WDB11NRDQ0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS0 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS1 White Westinghouse/dishwasher
White Westinghouse WDB11NRDS2 White Westinghouse/dishwasher
Frigidaire WDB212GBD0 Wwh(v2) / 24 " Built - in Dishwasher
Frigidaire WDB212GBW0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB212RBM0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB222RBR0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB632RBR0 Wwh(v1) / 24 " Built - in Dishwasher
Frigidaire WDB632RBS0 Wwh(v2) / 24 " Built - in Dishwasher
White Westinghouse WDB635RBQ0 White Westinghouse/dishwasher
White Westinghouse WDB635RBS0 White Westinghouse/dishwasher
Frigidaire WDB662RBR0 Wwh(v1) / 24 " Built - in Dishwasher
White Westinghouse WDB745REB0 White Westinghouse/dishwasher
White Westinghouse WDB745REB1 White Westinghouse/dishwasher
White Westinghouse WDB745REB2 White Westinghouse/dishwasher
White Westinghouse WDB745RES0 White Westinghouse/dishwasher
White Westinghouse WDB745RES1 White Westinghouse/dishwasher
White Westinghouse WDB745RES2 White Westinghouse/dishwasher
White Westinghouse WDB954MBS0 White Westinghouse/dishwasher
White Westinghouse WDB956MBC0 White Westinghouse/dishwasher
Frigidaire WDCLL0 Frg(v6) / 27 " Washer
Frigidaire WDCLW0 Frg(v5) / 27 " Washer
Frigidaire WDDH3 Frg(v3) / Top Load Washer
Frigidaire WDDL2 Frg(v13) / Top Loading Washer
Frigidaire WDDL3 Frg(v2) / Top Load Washer
Frigidaire WDDW2 Frg(v14) / Top Loading Washer
Frigidaire WDDW3 Frg(v1) / Top Load Washer
Frigidaire WDE116REW0 Wwh(v0) / Dryer
Frigidaire WDE213RHS0 Wwh(v0) / Dryer
Frigidaire WDE216RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE216RBD1 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE216RBD2 Wwh(v1) / Electric Dryer
Frigidaire WDE216RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE216RBW1 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE216RBW2 Wwh(v2) / Electric Dryer
Whirlpool WDE32202
Frigidaire WDE336RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE336RBD1 Wwh(v3) / 27 " Electric Dryer
Frigidaire WDE336RBD2 Wwh(v3) / Electric Dryer
Frigidaire WDE336RBS0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE336RBS1 Wwh(v4) / 27 " Electric Dryer
Frigidaire WDE336RBS2 Wwh(v0) / Electric Dryer
Frigidaire WDE336RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE336RBW1 Wwh(v5) / 27 " Electric Dryer
Frigidaire WDE336RBW2 Wwh(v4) / Electric Dryer
Frigidaire WDE336RED1 Wwh(v1) / Dryer
Frigidaire WDE336RES0 Wwh(v0) / Dryer
Frigidaire WDE336RES1 Wwh(v0) / Dryer
Frigidaire WDE336REW0 Wwh(v0) / Free Standing Dryer
Frigidaire WDE336REW1 Wwh(v2) / Dryer
Frigidaire WDE436RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE436RBD1 Wwh(v6) / 27 " Electric Dryer
Frigidaire WDE436RBD2 Wwh(v1) / Electric Dryer
Frigidaire WDE436RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE436RBW1 Wwh(v7) / 27 " Electric Dryer
Frigidaire WDE436RBW2 Wwh(v2) / Electric Dryer
Frigidaire WDE446JBS1 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE546RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE546RBD1 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE546RBD2 Wwh(v3) / Electric Dryer
Frigidaire WDE546RBS0 Wwh(v0) / Gas Dryer
Frigidaire WDE546RBS1 Wwh(v0) / Electric Dryer
Frigidaire WDE546RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE546RBW1 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE546RBW2 Wwh(v4) / Electric Dryer
Frigidaire WDE546RFS0 Wwh(v0) / Dryer
Frigidaire WDE547PBS0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDE646RBSD0 Wwh(v4) / 27 " Electric Dryer
Frigidaire WDE646RBSW0 Wwh(v3) / 27 " Electric Dryer
Frigidaire WDE846RBD0 Wwh(v2) / 27 " Electric Dryer
Frigidaire WDE846RBW0 Wwh(v1) / 27 " Electric Dryer
Frigidaire WDG216RBD0 Wwh(v4) / 27 " Gas Dryer
Frigidaire WDG216RBD1 Wwh(v1) / 27 " Gas Dryer
  #2 (permalink)
Old 11-05-2009, 04:50 AM
Junior Member
Default i ordered wrong part
post removed
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Dishwasher timer dial sticky Vuvuzela Dishwasher Repair 0 09-28-2009 10:35 AM
How long to dry a load of cottons resloan Dryer Repair 3 08-03-2009 02:43 PM
Water overflows when heavy loads are washed slgusta Washer Repair 1 12-29-2008 09:36 PM
Timer dial removal Tom C Washer Repair 3 08-15-2008 02:19 PM
Washer loads water then stops on regular/perm press OK/Timer? JillD Washer Repair 0 07-07-2008 10:52 PM
