Discuss
Stacked Maytag/Neptune Washer not spinning
 in
Washer Repair
Hello all, We have stacked Maytag washer/dryer unit at our dormitory facility, and the washer is not spinning out the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Stacked Maytag/Neptune Washer not spinning
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 10-24-2017, 01:26 PM
Junior Member
Building and Grounds is on a distinguished road
Default Stacked Maytag/Neptune Washer not spinning
Model Number: MLE2000AYW   Brand: Maytag   Age: 5 - 10 years
Hello all,
We have stacked Maytag washer/dryer unit at our dormitory facility, and the washer is not spinning out the water. It's a real mystery at this point.
Here's what we checked so far, based on info from previous posts.
The door-lock light goes on during the rinse and spin cycles, and I have checked the circuit board and R11 looks fine, and no other components on the board looked burned out.
I vac-ed out all the dust and checked a lot of the connectors, which also look fine to me.
I also checked the switch on the very bottom of the washer, and it does cut the circuit when the button is depressed.
I reached back and checked the belt which feels tight and in tact.
However it also seems like the water is not draining properly, so I disconnected the drain hose and used a wet vac to vac out the water, which was a lot left over at the end of the cycle. Even still, the following cycle still not spin and it seems like water is left in the washer because I hear it when I rotate the drum.
Any help you can provide will be much appreciated! Thank you and hope you're having a great day.
Related Models
Maytag MLE2000AYW STACKED LAUNDRY- ELE
Maytag MLE2000AZW STACKED LAUNDRY- ELE
Maytag MLE23MNAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE23MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE23MNFYW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE23PDAUW MAYTAG LAUNDRY MANUAL (DRYER ELE)
Maytag MLE23PDAYQ MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PDFUW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDFZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PDHZW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PRAYW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLE23PRFYW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE23PRFZW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLE24PDAGW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAYW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAZW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PDAZW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PNAGW0 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PRAYW1 COMMERCIAL ELECTRIC DRYER
Maytag MLE24PRAZW0 COMMERCIAL ELECTRIC DRYER
Frigidaire MLF303PGDA Frg(v1) / Gas Range
Frigidaire MLF303PGDC Frg(v1) / Gas Range
Frigidaire MLF303PGDD Frg(v2) / Gas Range
Frigidaire MLF303PGWA Frg(v2) / Gas Range
Frigidaire MLF303PGWC Frg(v3) / Gas Range
Frigidaire MLF303PGWD Frg(v4) / Gas Range
Frigidaire MLF311SGDA Frg(v1) / Gas Range
Frigidaire MLF311SGDC Frg(v1) / Gas Range
Frigidaire MLF311SGDD Frg(v1) / Gas Range
Frigidaire MLF311SGWA Frg(v2) / Gas Range
Frigidaire MLF311SGWC Frg(v2) / Gas Range
Frigidaire MLF311SGWD Frg(v2) / Gas Range
Maytag MLG15MNAEW MANUAL, PARTS (DRYER GAS)
Maytag MLG15MNAGW MANUAL, PARTS (DRYER GAS)
Maytag MLG15MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAEW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLG15PDAWA MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAWQ MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAXA MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAXQ MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDAXW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDBGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG15PDCXA MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDCXQ MANUAL, PARTS (DRYER GAS)
Maytag MLG15PDCXW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PRAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG15PRAXW MANUAL, PARTS (DRYER GAS)
Maytag MLG19PDAEW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PDAGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PDAWW MANUAL, PARTS (DRYER ELE)
Maytag MLG19PDAXW MANUAL, PARTS (DRYER ELE)
Maytag MLG19PDBGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG19PDCXQ MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PDCXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PDDGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PDDWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PDSAW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PNAWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PNDWW COMMERCIAL LAUNDRY (DRYER ELE)
Maytag MLG19PRAWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PRAXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG19PRDWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG2000AWW STACKED LAUNDRY- GAS
Maytag MLG2000AXW STACKED LAUNDRY- GAS
Maytag MLG23MNAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG23MNFWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLG23PDAWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDAYQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDFGW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PDFWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDFXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHGW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHWW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PDHXW MAYTAG LAUNDRY (DRYER ELE)
Maytag MLG23PRAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PRFWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG23PRFXW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG24PDAGW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAWW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAWW1 COMMERCIAL GAS DRYER
Maytag MLG24PDAXW0 COMMERCIAL GAS DRYER
Maytag MLG24PDAXW1 COMMERCIAL GAS DRYER
Maytag MLG24PNAGW0 COMMERCIAL GAS DRYER
Maytag MLG24PRAWW0 COMMERCIAL GAS DRYER
Maytag MLG24PRAWW1 COMMERCIAL GAS DRYER
Maytag MLG31PCAWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCAWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCAWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWQ MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG31PCBWW MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG32PDAWA MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDAWW MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWA MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWQ MANUAL, PARTS (DRYER GAS)
Maytag MLG32PDBWS MAYTAG LAUNDRY (DRYER GAS)
Maytag MLG32PDBWW MANUAL, PARTS (DRYER GAS)
Maytag MLG33PDAWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDAWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDSWS MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLG33PDSWW MAYTAG COMMERCIAL LAUNDRY (DRYER GAS)
Maytag MLI7000AAW SMALL APPLIANCES
Maytag MLI7500AAW SMALL APPLIANCES
Admiral MLR1100AJQ RANGE- F/S STD GAS
Admiral MLR1100AJW RANGE- F/S STD GAS
Admiral MLR1110AJQ RANGE- F/S STD GAS
Admiral MLR1110AJW RANGE- F/S STD GAS
Admiral MLR1415AJQ RANGE- F/S STD GAS
Admiral MLR1415AJS RANGE- F/S STD GAS
Admiral MLR1415AJW RANGE- F/S STD GAS
  #2 (permalink)
Old 10-24-2017, 01:32 PM
Junior Member
Default
I also left the bottom cover off during the cycle so I could see what is happening, and it seems like the drum is rotating at various times, but it is never ramping up to full spin speed at any point.
Thanks again in advance for any help on this one.
  #3 (permalink)
Old 10-25-2017, 12:31 PM
Junior Member
Default
Update: ran the machine with the door open, and the drum rotates a few times in one direction, then changes direction, and repeats this a couple of times before bypassing the spin cycle alltogether. Maybe it is something to do with the initertia ballance switch, but i hear it it hard to get to on the stacked units. any ideas?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag neptune washer spinning problem bradob Washer Repair 0 12-18-2014 08:00 PM
Maytag Neptune not spinning, new parts and all! poppasquirrel Washer Repair 2 11-25-2014 01:59 PM
Neptune Stacked Washer / Dryer Will not Spin acsicsila Washer Repair 1 06-13-2011 09:04 AM
Neptune stacked washer bearing going bad? Shogun Washer Repair 1 07-26-2010 10:04 AM
Maytag neptune washer-stop spinning superandy Washer Repair 1 06-26-2009 12:06 AM
