Discuss
Frigidaire E43 and E45
 in
Washer Repair
I have a Frigidaire Affinity ATF7000FS0 that I bought in 2007. Lately it just decides to stop mid cycle for
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire E43 and E45
  #1 (permalink)
Old 10-16-2017, 04:35 PM
Junior Member
vjsaab is on a distinguished road
Unhappy Frigidaire E43 and E45
Model Number: ATF7000FS0   Brand: Frigidaire   Age: 5 - 10 years
Lately it just decides to stop mid cycle for no apparent rhyme or reason. I'll start a load - doesn't matter what setting. Sometimes it will run the entire cycle. Sometimes it will stop immediately. Most of the time I come back and the door lock light is solid but the door is not locked. I'll open it up and there is still water in it. I cleaned out the pump filter and inspected the propeller in the pump. It seems okay. I took out the lock switch and tested it with a multimeter. I believe it is supposed to have 1500 ohms. Mine is consistently 1229 ohms. I watched some videos saying anything under 1500 ohms needs to be replaced. Some say it is fine.
In diagnostic mode it has pulled codes E45 then it pulled an E43 and then it pulled an E45 again which is a communication error. It says replace the control board. Which control board? The main control board? The Motor Control board? I think there are two main control boards?
My questions are:
If my door switch is reading 1229 ohms instead of 1500 does that mean it is faulty? What part number would that be?
If not, which control board do I need to replace? What part number would that be?
Related Models
Frigidaire ATF7000FS0 Frigidaire/washer
Frigidaire ATF7000FS1 WASHER
Frigidaire ATF8000FE0 WASHER
Frigidaire ATF8000FE1 WASHER
Frigidaire ATF8000FE2 WASHER
Frigidaire ATF8000FG0 WASHER
Frigidaire ATF8000FG1 WASHER
Frigidaire ATF8000FS0 WASHER
Frigidaire ATF8000FS1 WASHER
Frigidaire ATF8000FS2 WASHER
Frigidaire ATFB6000ES0 Frigidaire/washer
Frigidaire ATFB6000ES1 Frigidaire/washer
Frigidaire ATFB6000FS0 Frigidaire/washer
Frigidaire ATFB6700FS0 WASHER
Frigidaire ATFB7000EG0 Frigidaire/washer
Frigidaire ATFB7000EP0 Frigidaire/washer
Frigidaire ATFB7000ES0 Frigidaire/washer
Frigidaire ATFB7000ES1 Frigidaire/washer
Frigidaire ATG130NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG130NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG130NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG130NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG130NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG130NLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG130NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG130NLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG150NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG150NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG150NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG150NLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170NCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170NCD2 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170NCW0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG170NCW1 Wwh(v7) / Top Mount Refrigerator
Frigidaire ATG170NCW2 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170NLD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170NLD2 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG170NLW1 Wwh(v8) / Top Mount Refrigerator
Frigidaire ATG170NLW2 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170VNCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170VNCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG170VNCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170VNCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG170VNLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170VNLD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG170VNLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG170VNLW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG173NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG173NCD1 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG173NCW0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG173NCW1 Wwh(v7) / Top Mount Refrigerator
Frigidaire ATG173NLD0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG173NLD1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG173NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG173NLW1 Wwh(v8) / Top Mount Refrigerator
Frigidaire ATG175NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG175NCD1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG175NCW0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG175NCW1 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG175NLD0 Wwh(v5) / Top Mount Refrigerator
Frigidaire ATG175NLW0 Wwh(v6) / Top Mount Refrigerator
Frigidaire ATG180VNCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG180VNCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG180VNLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG180VNLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATG185NCD0 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG185NCD1 Wwh(v1) / Top Mount Refrigerator
Frigidaire ATG185NCW0 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG185NCW1 Wwh(v2) / Top Mount Refrigerator
Frigidaire ATG185NLD0 Wwh(v3) / Top Mount Refrigerator
Frigidaire ATG185NLW0 Wwh(v4) / Top Mount Refrigerator
Frigidaire ATL/ATN130BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL/ATN130HK1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL/ATN130WK1 Frg(v3) / Top Mount Refrigerator
General Electric ATL04LAA1 Room air conditioner
General Electric ATL05LAB1 Room air conditioner
Frigidaire ATL130BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130BL0 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL130HK1 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL130WK1 Frg(v5) / Top Mount Refrigerator
Frigidaire ATL130WKW1 Wwh(v11) / Top Mount Refrigerator
Frigidaire ATL130WL0 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150BK2 Frg(v3) / Top Mount Refrigerator
Frigidaire ATL150HK2 Frg(v2) / Top Mount Refrigerator
Frigidaire ATL150WK2 Tap(v7) / Top Mount Refrigerator
Frigidaire ATL150WKD2 Gib(v15) / Top Mount Refrigerator
Frigidaire ATL152BK0 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL152BK1 Frg(v1) / Top Mount Refrigerator
Frigidaire ATL152HK0 Frg(v0) / Top Mount Refrigerator
Frigidaire ATL152WK0 Gib(v12) / Top Mount Refrigerator
Frigidaire ATL152WK1 Frg(v2) / Top Mount Refrigerator
General Electric ATM04LAA1 Room air conditioner
General Electric ATM04LAA2 Room air conditioner
General Electric ATM04LBA1 Room air conditioner
General Electric ATM05LAB1 Room air conditioner
General Electric ATM05LAB2 Room air conditioner
General Electric ATM06LAC1 Room air conditioner
General Electric ATM06LAC2 Room air conditioner
General Electric ATM06LBC1 Room air conditioner
Frigidaire ATN130BK1 Frg(v2) / Top Mount Refrigerator
Frigidaire ATN130BK1-23 Tap(v20) / Top Mount Refrigerator
Frigidaire ATN130BK2 Frg(v1) / Top Mount Refrigerator
Frigidaire ATN130BL0 Frg(v3) / Top Mount Refrigerator
Frigidaire ATN130HK1 Frg(v4) / Top Mount Refrigerator
Frigidaire ATN130HK2 Frg(v2) / Top Mount Refrigerator
Frigidaire ATN130HKJ1 Kel(v28) / Top Mount Refrigerator
Frigidaire ATN130WK1 Frg(v6) / Top Mount Refrigerator
Frigidaire ATN130WK1-00 Tap(v24) / Top Mount Refrigerator
Frigidaire ATN130WK2 Frg(v3) / Top Mount Refrigerator
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
FRIGIDAIRE FDB2410LDC1 Frigidaire/dishwa mlender Dishwasher Repair 1 12-31-2010 11:52 AM
