Discuss
burned pump motor contacts and small wire connector
 in
Washer Repair
I have a Maytag MA5500BWW washer with the nd code and its not draining. I disconnected the pump, which looked
Appliance Repair Forum > Appliance Repair Help > Washer Repair » burned pump motor contacts and small wire connector
  #1 (permalink)
Old 10-14-2017, 12:18 PM
Junior Member
jon parts pro 15 is on a distinguished road
Default burned pump motor contacts and small wire connector
Model Number: MA5500BWW   Brand: Maytag   Age: More than 10 years
I have a Maytag MA5500BWW washer with the nd code and its not draining. I disconnected the pump, which looked fine, but found the small wire contacts to be burned on both the pump and the wire connector, see photo. I assume I need both the small wire harness and the pump? Other than the nd code the washer appears to function fine so I suspect the main board is OK. What are the part numbers for both parts and has anyone else experienced this same problem, and then made a successful repair?
Related Models
Admiral MA5C-3 MWAVE- CNTRTP / STAND ALONE
Admiral MA5C-6 MWAVE- CNTRTP / STAND ALONE
Amana MA8800 WASHER-TOP LOADING
Frigidaire MAC053P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire MAC053P7A2 Wwh(v0) / Room Air Conditioner
Frigidaire MAC063P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire MAC073P7A1 Wwh(v1) / Room Air Conditioner
Frigidaire MAC083P7A1 Wwh(v1) / Room Air Conditioner
Whirlpool MACM052XK1 AIR CONDITIONER
Whirlpool MACM102XL0 AIR CONDITIONER
Whirlpool MACM122XK1 AIR CONDITIONER
Whirlpool MACM122XP0 AIR CONDITIONER
Whirlpool MACM124XK1 AIR CONDITIONER
Whirlpool MACM124XP0 AIR CONDITIONER
Whirlpool MACQ122XK1 AIR CONDITIONER
Whirlpool MACQ122XP0 AIR CONDITIONER
Whirlpool MACQ124XK1 AIR CONDITIONER
Whirlpool MACQ124XP0 AIR CONDITIONER
Whirlpool MACQ184XL1 AIR CONDITIONER
Whirlpool MACQ184XP1 AIR CONDITIONER
Whirlpool MACQ244XL1 AIR CONDITIONER
Whirlpool MACQ244XP0 AIR CONDITIONER
Maytag MAF18MC1 MANUAL, PARTS (WASHER)
Maytag MAF18MC4AL MAYTAG LAUNDRY (WASHER)
Maytag MAF18MC4AS MAYTAG LAUNDRY (WASHER)
Maytag MAF18MC4AW MAYTAG LAUNDRY (WASHER)
Maytag MAF18MC4VL MAYTAG LAUNDRY (WASHER)
Maytag MAF18MC4VS MAYTAG LAUNDRY (WASHER)
Maytag MAF18MC4VW MAYTAG LAUNDRY (WASHER)
Maytag MAF18MN1 MANUAL, PARTS (WASHER)
Maytag MAF18PC2 MANUAL, PARTS (WASHER)
Maytag MAF18PN1 MANUAL, PARTS (WASHER)
Maytag MAF18PN2 MANUAL, PARTS (WASHER)
Maytag MAF25MC3 MANUAL, PARTS (WASHER)
Maytag MAF25MC4TL MANUAL, PARTS (WASHER)
Maytag MAF25MC4TS MANUAL, PARTS (WASHER)
Maytag MAF25MC4TW MANUAL, PARTS (WASHER)
Maytag MAF25MC4VL MANUAL, PARTS (WASHER)
Maytag MAF25MC4VS MANUAL, PARTS (WASHER)
Maytag MAF25MC4VW MANUAL, PARTS (WASHER)
Maytag MAF25MN3 MANUAL, PARTS (WASHER)
Maytag MAF25PC2 MANUAL, PARTS (WASHER)
Maytag MAF25PN3 MANUAL, PARTS (WASHER)
Maytag MAF35MC1 MANUAL, PARTS (WASHER)
Maytag MAF35MC4TL MAYATG LAUNDRY (WASHER)
Maytag MAF35MC4TS MAYATG LAUNDRY (WASHER)
Maytag MAF35MC4TW MAYATG LAUNDRY (WASHER)
Maytag MAF35MC4VL MAYATG LAUNDRY (WASHER)
Maytag MAF35MC4VS MAYATG LAUNDRY (WASHER)
Maytag MAF35MC4VW MAYATG LAUNDRY (WASHER)
Maytag MAF35MN1 MANUAL, PARTS (WASHER)
Maytag MAF35PC2 MANUAL, PARTS (WASHER)
Maytag MAF35PN1 MANUAL, PARTS (WASHER)
Maytag MAF35PN2 MANUAL, PARTS (WASHER)
Maytag MAF35PNA MANUAL, PARTS (WASHER)
Maytag MAF50MC1 MANUAL, PARTS (WASHER)
Maytag MAF50MC2 MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAF50MC4TL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAF50MC4TS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAF50MC4TW WASHER-TOP LOADING
Maytag MAF50MC4VL MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAF50MC4VS MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAF50MC4VW WASHER-TOP LOADING
Maytag MAF50MN1 MANUAL, PARTS (WASHER)
Maytag MAF50MN2 MAYTAG COMMERCIAL LAUNDRY (WASHER)
Maytag MAF50PC2 MANUAL, PARTS (WASHER)
Maytag MAF50PN1 MANUAL, PARTS (WASHER)
Maytag MAF50PN2 MANUAL, PARTS (WASHER)
Maytag MAF50PNA MANUAL, PARTS (WASHER)
Maytag MAF50PNAL WASHER-TOP LOADING
Maytag MAF50PNAS WASHER-TOP LOADING
Maytag MAF50PNAW WASHER-TOP LOADING
Maytag MAF80PNAVS MANUAL, PARTS (WASHER)
Maytag MAH14PDAAL MANUAL, PARTS (WASHER)
Maytag MAH14PDAAQ MANUAL, PARTS (WASHER)
Maytag MAH14PDAAW MANUAL, PARTS (WASHER)
Maytag MAH14PDABL MANUAL, PARTS (WASHER)
Maytag MAH14PDABW MANUAL, PARTS (WASHER)
Maytag MAH14PDAEW MANUAL, PARTS (WASHER)
Maytag MAH14PDAGW MANUAL, PARTS (WASHER)
Maytag MAH14PDBAW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDBEW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDBGW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDCBQ MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDCBW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDDWW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PDSAW MANUAL, PARTS (WASHER)
Maytag MAH14PNAEW MANUAL, PARTS (WASHER)
Maytag MAH14PNAGW MANUAL, PARTS (WASHER)
Maytag MAH14PNAWW MANUAL, PARTS (WASHER)
Maytag MAH14PNBAW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNBEW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNBGW MAYTAG LAUNDRY (WASHER)
Maytag MAH14PNSAW MANUAL, PARTS (WASHER)
Maytag MAH14PRAWW MANUAL, PARTS (WASHER)
Maytag MAH14PSAAW MANUAL, PARTS (WASHER)
Maytag MAH20PDA3W MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDAWQ MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDCXQ MAYTAG LAUNDRY (WASHER)
Maytag MAH20PDCXW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PNAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PRAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PRDWW MAYTAG LAUNDRY (WASHER)
Maytag MAH20PSAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDA3W MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAWQ MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDCXQ MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDCXW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PDD3W LAUNDRY PRODUCT (WASHER)
Maytag MAH21PDDGW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDWQ LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDWW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PDDXW LAUNDRY PRODUCTS (WASHER)
Maytag MAH21PNAGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNAWW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNDGW MAYTAG LAUNDRY (WASHER)
Maytag MAH21PNDWW LAUNDRY PRODUCTS (WASHER)
File Type: jpg burned pump connector on MAH5500BWW .jpg (65.3 KB, 4 views)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Bosch Axxiss washer broken wire on motor wire connector plug essorjsmith Washer Repair 2 03-05-2017 02:57 PM
Wire to heating element burned (short wire) bolero680 Dryer Repair 0 11-26-2016 07:02 AM
Ignitor Wire Connector km4hr Heating, Ventilation, and Air Conditioning (HVAC) 1 12-04-2013 08:42 PM
Won't move, smell of burned wire/hot motor paulnvi Washer Repair 1 09-02-2011 02:35 AM
cannot remove solder-less wire connector on TS rock304 Dishwasher Repair 1 06-03-2011 10:17 AM
