Discuss
Washer water leak and freeze on sensing mode
 in
Washer Repair
The machine is a Bravos x. It is leaking water right below the drum. After some time, it started also
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer water leak and freeze on sensing mode
  #1 (permalink)
Old 10-09-2017, 11:50 AM
Junior Member
JoeOfCola is on a distinguished road
Default Washer water leak and freeze on sensing mode
Model Number: MVWX500XW2   Brand: Maytag   Age: 1 - 5 years
After some time, it started also not straining the clothes well, they come out too wet.
Then it started stopping after the wash, and squeeling a bit.
It drains the water fine, so the pump is ok.
It is the rust color, and the leak, and the getting stuck in sensing, that is the problem.
If the seal is broken, could it do all these things?
Or, what it the diagnosis?
I plan on buying this: Whirlpool W10324647 Tub Seal - AppliancePartsPros.com
And hoping you can tell me if there's anything else i may need to buy at once. Or, is it the wrong part.
thank you for a very helpful site with DIY videos!
Related Models
Maytag MVWX550XW0 AUTOMATIC WASHER
Maytag MVWX600XW0 AUTOMATIC WASHER
Maytag MVWX700XL0 AUTOMATIC WASHER
Maytag MVWX700XW0 AUTOMATIC WASHER
Whirlpool MW1000XP0 Microwaves*
Whirlpool MW1000XP1 Microwaves*
Whirlpool MW1000XS0 MICROWAVE
Whirlpool MW1000XS1 Microwaves*
Whirlpool MW1000XW0 Microwaves*
 MW1030BA MWAVE- CNTRTP / STAND ALONE
 MW1030SB MWAVE- CNTRTP / STAND ALONE
 MW1030SB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1030WA MWAVE- CNTRTP / STAND ALONE
 MW1040BC MWAVE- CNTRTP / STAND ALONE
 MW1040BC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1040WC MWAVE- CNTRTP / STAND ALONE
 MW1040WC/XAA MWAVE- CNTRTP / STAND ALONE
 MW1080STA MWAVE- CNTRTP / STAND ALONE
 MW1135WB MWAVE- CNTRTP / STAND ALONE
 MW1135WB/XAA MWAVE- CNTRTP / STAND ALONE
 MW1150WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1200XP0 Microwaves*
Whirlpool MW1200XP1 Microwaves*
Whirlpool MW1200XS0 Microwaves*
Whirlpool MW1200XS1 MICROWAVE
Whirlpool MW1200XW0 Microwaves*
Whirlpool MW120EXP0 Microwaves*
 MW1245BB MWAVE- CNTRTP / STAND ALONE
Whirlpool MW1500XP0 Microwaves*
Whirlpool MW1500XP1 Microwaves*
Whirlpool MW1500XS0 Microwaves*
Whirlpool MW1500XS1 Microwaves*
Whirlpool MW1500XW0 Microwaves*
Whirlpool MW1501XS1 Microwaves*
Whirlpool MW1501XW0 Microwaves*
Roper MW157 Microwave
Maytag MW29000TB0 LAUNDRY WORKSURFACE
Maytag MW29000TU0 LAUNDRY WORKSURFACE
Maytag MW29000TW0 LAUNDRY WORKSURFACE
Whirlpool MW3000XM0 Microwaves*
Whirlpool MW3000XM1 Microwaves*
Whirlpool MW3000XP0 Microwaves*
Whirlpool MW3000XP1 Microwaves*
Whirlpool MW3000XP2 Microwaves*
Whirlpool MW3200XM0 Microwave
Whirlpool MW3200XM1 Microwave
Whirlpool MW3200XP0 Microwave
Whirlpool MW3200XP1 Microwave
Whirlpool MW3200XP2 Microwave
Whirlpool MW3200XS0 Microwave
Whirlpool MW3200XW0 Microwave
Whirlpool MW3500XM0 Microwaves*
Whirlpool MW3500XM1 Microwaves*
Whirlpool MW3500XP1 Microwaves*
Whirlpool MW3500XP2 Microwaves*
Whirlpool MW3500XP3 Microwaves*
Whirlpool MW3500XS0 Microwaves*
Whirlpool MW3500XW0 Microwaves*
Whirlpool MW3520XP1 Microwaves*
Whirlpool MW3520XP2 Microwaves*
Whirlpool MW3520XP3 Microwaves*
Whirlpool MW352EXP1 Microwaves*
Whirlpool MW3600XS0 Microwaves*
Whirlpool MW3600XW0 Microwaves*
Whirlpool MW3600XW1 Microwaves*
Whirlpool MW3601XS0 Microwaves*
Whirlpool MW3601XW0 Microwaves*
Whirlpool MW3601XW1 Microwaves*
Amana MW41 MWAVE- CNTRTP / STAND ALONE
Amana MW42 MWAVE- CNTRTP / STAND ALONE
Amana MW43 MWAVE- CNTRTP / STAND ALONE
Amana MW500.000 COMMERCIAL MICROWAVES
 MW5380W MWAVE- CNTRTP / STAND ALONE
Roper MW557 Microwave
Roper MW5571 Microwaves
 MW5592W MWAVE- CNTRTP / STAND ALONE
 MW5592W/XAA MWAVE- CNTRTP / STAND ALONE
Amana MW56 MWAVE- CNTRTP / STAND ALONE
Amana MW57 MWAVE- CNTRTP / STAND ALONE
Amana MW58 MWAVE- CNTRTP / STAND ALONE
Amana MW600.000 COMMERCIAL MICROWAVES
 MW640BA MWAVE- CNTRTP / STAND ALONE
 MW640WA MWAVE- CNTRTP / STAND ALONE
Amana MW700.000 COMMERCIAL MICROWAVES
Amana MW72 MWAVE- CNTRTP / STAND ALONE
 MW730BB MWAVE- CNTRTP / STAND ALONE
 MW735WB MWAVE- CNTRTP / STAND ALONE
 MW735WB/XAA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW7400XW0 Microwaves*
Whirlpool MW7500XW0 Microwaves*
 MW7695GS MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8100XL0 MICROWAVE
Whirlpool MW8100XL1 MICROWAVE
Whirlpool MW8100XL2 MICROWAVE
Whirlpool MW8100XP0 MICROWAVE
Whirlpool MW8100XR0 MICROWAVE
Whirlpool MW8200XL0 Microwaves*
Whirlpool MW8200XL1 Microwaves*
Whirlpool MW8200XL2 Microwaves*
Whirlpool MW8200XP0 Microwaves*
Whirlpool MW8200XR0 Microwaves*
Whirlpool MW8300XL0 Microwaves*
Whirlpool MW8300XL2 Microwaves*
Whirlpool MW8300XP0 Microwaves*
 MW830BA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW830EXP0 Microwaves*
 MW830WA MWAVE- CNTRTP / STAND ALONE
Whirlpool MW8400XL0 Microwaves*
Whirlpool MW8400XL2 Microwaves*
Whirlpool MW8400XR0 Microwaves*
Whirlpool MW8400XS0 Microwaves*
Whirlpool MW8400XS1 Microwaves*
Whirlpool MW8400XS2 Microwaves*
Whirlpool MW8400XW0 Microwaves*
  #2 (permalink)
Old 10-11-2017, 06:50 AM
Senior Member
brobriffin is on a distinguished road
Default
To answer your question it might be that seal. If you are going to undertake this repair, why not disassemble to see where the leak actually is then purchase the part. If the leak is from the tub seal you will see signs of a water trail on top of the transmission running down the sides. If it is leaking thru the transmission you will see signs of water and rust near the shaft underneath the pulley and splutch.
  #3 (permalink)
Old 10-11-2017, 07:55 AM
Junior Member
Default
I will buy the wrench and take a look first surely.
There is already a rust color on the basket below and brown stains on the floor.
Could the seal cause that?
The machine still looks fairly new, no visible rust anywhere.
  #4 (permalink)
Old 10-11-2017, 12:29 PM
Senior Member
Default
The tub seal can cause that or a crack in the bottom of the tub, or it can be a seal leaking into the gearcase.
  #5 (permalink)
Old 10-12-2017, 03:52 AM
Junior Member
Default
Quote:
Thank you for your reply.
When you say 'a seal', is it a different seal in question or the same tub seal that may need change?
  #6 (permalink)
Old 10-12-2017, 05:24 AM
Senior Member
Default
No its part of the gearcase. A seal between the agitator drive shaft and the tub spin drive shaft.
  #7 (permalink)
Old 10-12-2017, 07:51 AM
Junior Member
Default
I will pull the tub out tonight or tomorrow.
How can I tell which seal it is?
  #8 (permalink)
Old 10-12-2017, 02:51 PM
Junior Member
Default
When I follow the video instructions on repair [linic (it won't let me post it) , i reach the place about the tub nut, that is different on my machine..
Any advice on how to proceed? and will the rest of the video be compatible with my model?
p.s. I could've sworn there was a video on your site where the Seal is listed for sale, but its not there now.
If you have a video for my model I'd appreciate it.
I haven't bought the seal, just waiting to see what is needed. But don't know how to proceed as mentioned above.
Thanks!
  #9 (permalink)
Old 10-12-2017, 03:08 PM
Senior Member
Default
https://www.youtube.com/watch?v=lUp0tS4P1Uk
  #10 (permalink)
Old 10-12-2017, 04:15 PM
Junior Member
Default
Thank you. Really appreciated.
The other video would have had me remove the belt, the bolt below, string...
In this one I'd have to only remove the wire harness, and the gear case entirely.
Only I am stuck at the bolts holding the gearcase... It doesn't specify which sockets to use, but 7/16 is slightly too large (on all of them, its not wear), and 3/8 is too small!!
Which socket to use?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer Stops during Sensing Mode gotimmygo89 Washer Repair 0 10-05-2015 08:12 AM
Washer won't get past 'sensing' mode, then shuts off. JohnQn Washer Repair 0 01-12-2015 12:52 PM
Maytag Centennial sits on sensing mode. nadroj186 Washer Repair 0 03-16-2013 12:46 PM
Stops at Sensing Mode Tom Whitlow Dishwasher Repair 2 07-17-2011 09:08 PM
