Discuss
Testing A Whirpool Shift Actuator
 in
Washer Repair
I have an older Whirlpool Heavy Duty that stops mid-cycle. I will have to manually advance the timer 2-4 clicks
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Testing A Whirpool Shift Actuator
  #1 (permalink)
Old 10-02-2017, 06:03 AM
Junior Member
generalxgenitals is on a distinguished road
Default Testing A Whirpool Shift Actuator
Model Number: LA5550XTW0   Brand: Whirlpool   Age: More than 10 years
I have an older Whirlpool Heavy Duty that stops mid-cycle. I will have to manually advance the timer 2-4 clicks in order to get the cycle to begin again. When it does finish, it seems the clothes are more damp than intended. This leads me to believe the machine is failing to go into a sort of "High Spin" mode. I have continuity-checked the lid switch, which is fully functional. This problem occurs on multiple cycles, which leads me to believe it is not the timer. My current suspicion is the shift actuator, but before I purchase a part, I was hoping to get a second opinion and a method with which to test the shift actuator. Any help is appreciated, thanks!
Related Models
Whirlpool LA5550XTW0
Whirlpool LA5558XSW0
Whirlpool LA5558XTF0
Whirlpool LA5558XTF1
Whirlpool LA5558XTG0
Whirlpool LA5558XTG1
Whirlpool LA5558XTG2
Whirlpool LA5558XTM0
Whirlpool LA5558XTM1
Whirlpool LA5558XTN0
Whirlpool LA5558XTN1
Whirlpool LA5558XTN2
Whirlpool LA5558XTW0
Whirlpool LA5558XTW1
Whirlpool LA5558XTW2
Whirlpool LA5570XPW3
Whirlpool LA5570XPW4
Whirlpool LA5570XPW5
Whirlpool LA5578XSW0
Whirlpool LA5578XSW1
Whirlpool LA5578XSW2
Whirlpool LA5578XTF0
Whirlpool LA5578XTF1
Whirlpool LA5578XTG0
Whirlpool LA5578XTG1
Whirlpool LA5578XTM0
Whirlpool LA5578XTM1
Whirlpool LA5578XTN0
Whirlpool LA5578XTN1
Whirlpool LA5578XTW0
Whirlpool LA5578XTW1
Whirlpool LA5580XKW1
Whirlpool LA5580XMW0
Whirlpool LA5580XMW1
Whirlpool LA5580XPW0
Whirlpool LA5580XPW1
Whirlpool LA5580XSF1 AUTOMATIC WASHER
Whirlpool LA5580XSF2 AUTOMATIC WASHER
Whirlpool LA5580XSF3 AUTOMATIC WASHER
Whirlpool LA5580XSG1 AUTOMATIC WASHER
Whirlpool LA5580XSG2 AUTOMATIC WASHER
Whirlpool LA5580XSG3 AUTOMATIC WASHER
Whirlpool LA5580XSM1 AUTOMATIC WASHER
Whirlpool LA5580XSM2 AUTOMATIC WASHER
Whirlpool LA5580XSM3 AUTOMATIC WASHER
Whirlpool LA5580XSN0 AUTOMATIC WASHER
Whirlpool LA5580XSN1 AUTOMATIC WASHER
Whirlpool LA5580XSN2 AUTOMATIC WASHER
Whirlpool LA5580XSN3 AUTOMATIC WASHER
Whirlpool LA5580XSW0
Whirlpool LA5580XSW1
Whirlpool LA5580XSW2
Whirlpool LA5580XSW3
Whirlpool LA5580XTF0 AUTOMATIC WASHER
Whirlpool LA5580XTF1
Whirlpool LA5580XTG0 AUTOMATIC WASHER
Whirlpool LA5580XTG1
Whirlpool LA5580XTM0 AUTOMATIC WASHER
Whirlpool LA5580XTM1
Whirlpool LA5580XTN0 AUTOMATIC WASHER
Whirlpool LA5580XTN1
Whirlpool LA5580XTW0
Whirlpool LA5580XTW1
Whirlpool LA5588XYG0
Whirlpool LA5588XYN0
Whirlpool LA5588XYW0
Whirlpool LA5590XPW0
Whirlpool LA5590XPW1
Whirlpool LA5591XPW3 Washers*
Whirlpool LA5591XPW4
Whirlpool LA5599XPW4
Whirlpool LA5600XMW0
Whirlpool LA5600XPW0
Whirlpool LA5600XPW1
Whirlpool LA5600XPW3
Whirlpool LA5600XPW4
Whirlpool LA5600XPW5
Whirlpool LA5600XPW6
Whirlpool LA5600XPW7
Whirlpool LA5600XSW0
Whirlpool LA5600XSW1
Whirlpool LA5600XSW2
Whirlpool LA5600XTF0
Whirlpool LA5600XTF1
Whirlpool LA5600XTG0
Whirlpool LA5600XTG1
Whirlpool LA5600XTM0
Whirlpool LA5600XTM1
Whirlpool LA5600XTN0
Whirlpool LA5600XTN1
Whirlpool LA5600XTW0
Whirlpool LA5600XTW1
Frigidaire LA560AXD1 Wwh(v6) / 27 " Washer
Frigidaire LA560AXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560AXW1 Wwh(v5) / 27 " Washer
Frigidaire LA560AXW2 Wwh(v1) / 27 " Washer
Frigidaire LA560JXD3 Wwh(v1) / Washer
Frigidaire LA560JXD4 Wwh(v1) / Top Load Washer
Frigidaire LA560JXD5 Wwh(v1) / Top Load Washer
Frigidaire LA560JXF3 Wwh(v2) / Washer
Frigidaire LA560JXF4 Wwh(v2) / Top Load Washer
Frigidaire LA560JXH3 Wwh(v3) / Washer
Frigidaire LA560JXH4 Wwh(v3) / Top Load Washer
Frigidaire LA560JXV3 Wwh(v4) / Washer
Frigidaire LA560JXV4 Wwh(v4) / Top Load Washer
Frigidaire LA560JXW3 Wwh(v5) / Washer
Frigidaire LA560JXW4 Wwh(v5) / Top Load Washer
Frigidaire LA560JXW5 Wwh(v2) / Top Load Washer
Frigidaire LA560MXD1 Wwh(v3) / 27 " Washer
Frigidaire LA560MXD2 Wwh(v2) / 27 " Washer
Frigidaire LA560MXH2 Wwh(v3) / 27 " Washer
Frigidaire LA560MXW1 Wwh(v1) / 27 " Washer
Frigidaire LA560MXW2 Wwh(v1) / 27 " Washer
Whirlpool LA5610XTF0
Whirlpool LA5610XTG0
Whirlpool LA5610XTG1
Whirlpool LA5610XTM0
Whirlpool LA5610XTN0
Whirlpool LA5610XTN1
Whirlpool LA5610XTW0
  #2 (permalink)
Old 10-02-2017, 04:51 PM
Senior Member
brobriffin is on a distinguished road
Default
Your machine does not have a shift actuator. You have (probably one of the best ever made) a direct drive machine. If you have to manually advance the timer it may be bad.
Does the machine spin at all? Check with lid open, use screwdriver to hold the lid switch closed. (Note injuries can occur when the machine is spinning and the lid is open. Please keep hands out of basket area while performing this test)
  #3 (permalink)
Old 10-02-2017, 06:20 PM
Junior Member
Default
Thanks for the reply, I'm glad I posted here and didn't just buy the part impulsively! I just confirmed, the machine definitely spins, just not at certain positions on the timer. This happens on both normal and permanent press cycles (I haven't tried delicate). Are you thinking it's the timer, then? Are there any other parts it could be, or is there a way to test the timer in place?
  #4 (permalink)
Old 10-02-2017, 06:22 PM
Senior Member
Default
Ok r u up for some Q n A to diagnose it?
  #5 (permalink)
Old 10-02-2017, 06:24 PM
Junior Member
Default
Yeah absolutely!
  #6 (permalink)
Old 10-02-2017, 06:35 PM
Senior Member
Default
Ok so lets try running a quick wash by setting the timer to the shortest time on regular wash cycle and let it run. During this test (lid open, bypass lid switch .. see above warning) see if the unit will drain the water out but not spin after it agitates in wash cycle then pause and begin to spin all this prior to rinse cycle. This would be without advancing the timer by hand. If it does let it continue to fill agitate in rinse cycle then again without helping the timer will it drain first then pause and then spin?
Let me know the results.
BRB gonna watch some TV (Shark Tank) for a bit
  #7 (permalink)
Old 10-02-2017, 06:44 PM
Junior Member
Default
Okay, I am performing this test now, but in the process I think I may have solved it! As I was allowing the machine to fill, I realized the temperature was set to "hot/cold." Meaning to not waste hot water I turned the machine to "cold/cold" and filling stopped completely. Resumed on any setting with hot water. Is there a cold water inlet valve? Could that have malfunctioned? It seems in line with my symptoms
Edited to add: the machine filled hot water, agitated, drained, and spun, then got stuck before next fill up. When I switched temperature to "hot/warm" it started filling again. I'm now quite confident this is an issue with the cold water supply.
Edited (again) to add: Yep, definitely a cold water supply issue. Unfortunately, it was the old ID10T error, I just didn't have the water tap all the way open. Once opened, the machine ran through all the points it used to hang up. I feel like a dumbass, but its running again! Thanks for all the help!
  #8 (permalink)
Old 10-02-2017, 07:32 PM
Senior Member
Default
Woop woop you solved it! Every rinse only uses cold water.....
Problem solved.
Glad we could help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blinking Lid Lock Light, loud hum, Replaced Shift Actuator NutDr Washer Repair 0 12-16-2015 10:05 AM
Maytage Centennial Washer Will Not Spin or Agigate after Shift Actuator Change GDK Washer Repair 0 07-26-2015 01:14 PM
Mode Shift Circuit Failed houndoggyjt Washer Repair 2 12-13-2011 09:24 AM
Shift mode assembly eraserskin Washer Repair 0 09-06-2010 10:29 AM
Whirpool Motor Testing ALEJANDRO GONZALEZ Washer Repair 1 01-16-2009 01:36 AM
