Discuss
LG- Fixed bearings- Put back together & tub catches- Rotor Assembly or Stator?
 in
Washer Repair
I have an LG WM1812CW washing machine. It started doing a weird spinning that sounded like a jet plane. Then
Appliance Repair Forum > Appliance Repair Help > Washer Repair » LG- Fixed bearings- Put back together & tub catches- Rotor Assembly or Stator?
  #1 (permalink)
Old 09-27-2017, 06:55 AM
Junior Member
funkyone is on a distinguished road
Default LG- Fixed bearings- Put back together & tub catches- Rotor Assembly or Stator?
Model Number: WM1812CW   Brand: -brand-   Age: 5 - 10 years
I have an LG WM1812CW washing machine. It started doing a weird spinning that sounded like a jet plane. Then it started making horrible noises. So, I just replaced both bearings, seal and tub gasket. The bearings were terrible. Put it back together and tested it spinning manually and then continued. However, we never checked after we reinstalled the stator assembly and cover. There was a crack in one of the magnets but everything looked ok except a fair amount of rust color which seems like itís not uncommon looking at some videos. Is it possible we didnít install the stator properly or too tightly, etcÖOr could that little crack matter? So, we plugged it in and now it makes a sound when spinning almost like itís hitting something or catching on something.
We pulled the top off and spun it manually and as stated above, it sounds and feels like the metal tub is catching something. Could the problem be the stator or the rotor assembly? Did I fix the wrong thing?
Any thoughts?
I appreciate the help!
Also, this is the video I used to repair
https://www.youtube.com/watch?v=WY7KQMcsWKY
Related Models
 WM1812CW Washer
 WM1814CW Washer
 WM1815CS Washer
 WM1832CW Washer
 WM2010CW Washer
 WM2016CW Washer
 WM2032HS Washer
 WM2032HW Washer
 WM2042CW Washer
 WM2075CW Washer
 WM2077CW Washer
 WM2101HW Washer
 WM2233HD Washer
 WM2233HS Washer
 WM2233HU Washer
 WM2233HW Washer
 WM2277HB Washer
 WM2277HS Washer
 WM2277HW Washer
Jenn-Air WM227B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM227W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM236W WALLOVEN- S/C MWAVE ELE
 WM2432HW Washer
 WM2442HW Washer
 WM2455HG Washer
 WM2487HRM Washer
 WM2487HRMA Washer
 WM2487HWM Washer
 WM2487HWMA Washer
 WM2496HSM Washer
 WM2496HWM Washer
 WM2677HSM Washer
 WM2688HNM Washer
 WM2688HNMA Washer
 WM2688HWM Washer
 WM2688HWMA Washer
Jenn-Air WM27160B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27160W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2720W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27260W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM27460W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2750W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM277W WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM2780W WALLOVEN- S/C MWAVE ELE
 WM2801HLA Washer
 WM2801HRA Washer
 WM2801HWA Washer
 WM3001HPA Washer
 WM3001HRA Washer
 WM3001HWA Washer
Jenn-Air WM30460B WALLOVEN- S/C MWAVE ELE
Jenn-Air WM30460W WALLOVEN- S/C MWAVE ELE
 WM3431HS Washer
 WM3431HW Washer
 WM3632HW Washer
 WM3677HW Washer
 WM3988HWA Washer
Amana WM612 MWAVE- CNTRTP / STAND ALONE
Amana WM614 MWAVE- CNTRTP / STAND ALONE
Amana WM615 MWAVE- CNTRTP / STAND ALONE
Amana WM712 MWAVE- CNTRTP / STAND ALONE
Amana WM714 MWAVE- CNTRTP / STAND ALONE
Amana WM715 MWAVE- CNTRTP / STAND ALONE
General Electric WMCD2050G0WC Washer
General Electric WMCD2050H0WC WASHER
General Electric WMCD2050H1WC WASHER
General Electric WMCD2050H2WC WASHER
General Electric WMCD2050H3WC WASHER
General Electric WMCD2050H4WC WASHER
General Electric WMCD2050H5WC WASHER
General Electric WMCD2050H6WC COIN-OP WASHER
General Electric WMCD2050J0WC COIN-OP WASHER
General Electric WMCD2050J1WC WASHER
Jenn-Air WME3020B WALLOVEN- S/C MWAVE ELE
Jenn-Air WME3020W WALLOVEN- S/C MWAVE ELE
Jenn-Air WMG3020B WALLOVEN- S/C MWAVE GAS
Jenn-Air WMG3020W WALLOVEN- S/C MWAVE GAS
Whirlpool WMH1162XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVB4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVD4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVQ4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS1 Microwave Oven 1.6 Cu. Ft.
Whirlpool WMH1162XVS2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS3 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1162XVS4 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVB2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVD2 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ0 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ1 MICROWAVE OVEN 1.6 CU. FT.
Whirlpool WMH1163XVQ2 MICROWAVE OVEN 1.6 CU. FT.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Stator & Rotor Assy kissdude Washer Repair 0 03-15-2014 07:55 PM
Stator bolts froze/stator cracked pooter Washer Repair 3 09-28-2013 06:02 AM
Cannot put lower arm assembly back on!!! jaypaze Dishwasher Repair 0 02-20-2013 04:23 PM
Fixed an old Maytag MDB PCB assembly Todd K. Dishwasher Repair 2 08-08-2012 11:15 PM
KitchenAid Mixer Field Assembly Stator Janet Graham General Talk 0 04-27-2008 11:35 AM
