Discuss
GE Space Saver washer dryer
 in
Washer Repair
I'm attempting to install a new tub seal. I've got the front panel, top w/door, the agitator, tub cover assembly,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Space Saver washer dryer
  By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 09-25-2017, 03:56 PM
Junior Member
Mora is on a distinguished road
Default GE Space Saver washer dryer
Model Number: GUD27ESSJOWW   Brand: GE   Age: 1 - 5 years
I'm attempting to install a new tub seal. I've got the front panel, top w/door, the agitator, tub cover assembly, hub nut and hub washer removed but I can't get the washtub to budge on the drive spindle to remove it and get at the seal. Is there something else I need to remove? From the parts diagram it appears the tub just slides over the shaft. Any help would be appreciated.
Related Models
Maytag GV1110PRW RANGE- F/S STD GAS
Admiral GV1226NXEW FREEZER- VERTICAL
Admiral GV1726NXEW FREEZER- VERTICAL
Hoover GV3177WUA RANGE- F/S STD GAS
Hoover GV3177WUW RANGE- F/S STD GAS
Hoover GV3177WUW5 RANGE- F/S STD GAS
Maytag GV3277XUA RANGE- F/S STD GAS
Maytag GV3277XUW RANGE- F/S STD GAS
Hoover GV3531WUA RANGE- F/S STD ELE
Hoover GV3531WUW RANGE- F/S STD ELE
General Electric GVSR1060H7WW WASHER
General Electric GVSR1060H9WW WASHER
General Electric GVSR1080H8WW WASHER
Whirlpool GVW9959KL0 WASHER
Whirlpool GVW9959KL1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KL3 AUTOMATIC WASHER
Whirlpool GVW9959KQ0 WASHER
Whirlpool GVW9959KQ1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KQ3 AUTOMATIC WASHER
Whirlpool GVW9959KT0 WASHER
Whirlpool GVW9959KT1 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT2 WASHER - DIRECT DRIVE
Whirlpool GVW9959KT3 AUTOMATIC WASHER
Maytag GW18F1A WASHER-TOP LOADING
Maytag GW18F1H WASHER-TOP LOADING
Maytag GW18F1W WASHER-TOP LOADING
Maytag GW18F2A WASHER-TOP LOADING
Maytag GW18F2H WASHER-TOP LOADING
Maytag GW18F2W WASHER-TOP LOADING
Maytag GW18G1A WASHER-TOP LOADING
Maytag GW18G1HW WASHER-TOP LOADING
Maytag GW18G1WW WASHER-TOP LOADING
Maytag GW20F6A WASHER-TOP LOADING
Maytag GW20F6H WASHER-TOP LOADING
Maytag GW20F6W WASHER-TOP LOADING
Frigidaire GW30SPEA2 Wwh(v1) / Electric Range
Frigidaire GW30SPED1 Wwh(v2) / Electric Range
Frigidaire GW30SPEW1 Wwh(v1) / Electric Range
Frigidaire GW30SPEW2 Wwh(v2) / Electric Range
Whirlpool GW395LEGB0 GAS RANGE
Whirlpool GW395LEGB1 GAS RANGE
Whirlpool GW395LEGB2 GAS RANGE
Whirlpool GW395LEGB3 GAS RANGE
Whirlpool GW395LEGB4 GAS RANGE
Whirlpool GW395LEGB5 GAS RANGE
Whirlpool GW395LEGB6 GAS RANGE
Whirlpool GW395LEGQ0 GAS RANGE
Whirlpool GW395LEGQ1 GAS RANGE
Whirlpool GW395LEGQ2 GAS RANGE
Whirlpool GW395LEGQ3 GAS RANGE
Whirlpool GW395LEGQ4 GAS RANGE
Whirlpool GW395LEGQ5 GAS RANGE
Whirlpool GW395LEGQ6 GAS RANGE
Whirlpool GW395LEGT2 GAS RANGE
Whirlpool GW395LEGT3 GAS RANGE
Whirlpool GW395LEGT4 GAS RANGE
Whirlpool GW395LEGT5 GAS RANGE
Whirlpool GW395LEGT6 GAS RANGE
Whirlpool GW395LEGZ0 GAS RANGE
Whirlpool GW395LEGZ1 GAS RANGE
Whirlpool GW395LEGZ2 GAS RANGE
Whirlpool GW395LEGZ3 GAS RANGE
Whirlpool GW395LEPB00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPB05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPQ05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPS05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT00 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT01 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT02 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT03 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT04 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW395LEPT05 30" Slide-In GAS OVEN NON-CONV
Whirlpool GW397LXUB0 30" Gas Slide-In
Whirlpool GW397LXUB05 30" GAS SLIDE-IN
Whirlpool GW397LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUB1 30" GAS SLIDE-IN
Whirlpool GW397LXUB5 30" GAS SLIDE-IN
Whirlpool GW397LXUQ0 30" Gas Slide-In
Whirlpool GW397LXUQ06 30" GAS SLIDE-IN
Whirlpool GW397LXUQ1 30" GAS SLIDE-IN
Whirlpool GW397LXUQ6 30" GAS SLIDE-IN
Whirlpool GW397LXUS0 30" Gas Slide-In
Whirlpool GW397LXUS05 30" GAS SLIDE-IN
Whirlpool GW397LXUS06 30" GAS SLIDE-IN RANGE
Whirlpool GW397LXUS1 30" GAS SLIDE-IN
Whirlpool GW397LXUS5 30" GAS SLIDE-IN
Whirlpool GW397LXUT0 30" Gas Slide-In
Whirlpool GW397LXUT05 30" GAS SLIDE-IN
Whirlpool GW397LXUT06 30" GAS SLIDE-IN
Whirlpool GW397LXUT1 30" GAS SLIDE-IN
Whirlpool GW397LXUT5 30" GAS SLIDE-IN
Whirlpool GW399LXUB0 30" Gas Slide-In
Whirlpool GW399LXUB05 30" GAS SLIDE-IN
Whirlpool GW399LXUB06 30" GAS SLIDE-IN RANGE
Whirlpool GW399LXUB1 30" Gas Slide-In
Whirlpool GW399LXUB5 30" Gas Slide-In
Whirlpool GW399LXUQ0 30" Gas Slide-In
Whirlpool GW399LXUQ06 30" GAS SLIDE-IN
Whirlpool GW399LXUQ1 30" Gas Slide-In
Whirlpool GW399LXUQ6 30" Gas Slide-In
Whirlpool GW399LXUS0 30" Gas Slide-In
Whirlpool GW399LXUS04 30" GAS SLIDE-IN
Whirlpool GW399LXUS05 30" GAS SLIDE-IN
Whirlpool GW399LXUS06 30" GAS SLIDE-IN RANGE
  #2 (permalink)
Old 09-26-2017, 01:12 PM
Senior Member
PNWDrew is on a distinguished road
Default
I can't find your model #, double check it for me?
But if it's a modern GE unitized set the tub seal comes out the bottom I believe, on the trans shaft.
You still need the tub free from the shaft though so no wasted time.
If it is one of these modern ones that leak onto trans and make horrible noises we've been replacing whole tub assemblies, trans and all. I think the trans# in our system subbed to it automatically or there was a bulletin to do so.
Something like this:
GE WH45X24614 Kit 27"CENTAURO Doe 201 - AppliancePartsPros.com
That may not be yours though not knowing model #.
  #3 (permalink)
Old 09-26-2017, 01:25 PM
Junior Member
Default
https://www.geapplianceparts.com/sto...y/GUD27ESSJ0WW
GE's site for the model I have. It looks real similar to the site you posted. Thanks for the help. I'll get a shoehorn and move it into the open so I can get the tub out.
  #4 (permalink)
Old 09-27-2017, 12:28 AM
Senior Member
Default
Yep that's new design. If you've caught the leak before any significant damage to trans has occurred you might get away with just the seal. Usually when I see them its just the beginning. Its worth calling GE parts to see if they've released a whole tub asm kit as this issue seemed to get far too common.
Warning, there is nothing fun about this task, the suspension rods can be a pain, the big tub nut is usually an issue too.
Good luck
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ge Space Saver Microhood sjvlies Microwave Repair 1 04-28-2011 03:50 PM
GE space saver washing machine anitame Washer Repair 1 08-27-2010 12:26 PM
GE Space Saver Microwave paton Microwave Repair 2 11-24-2009 01:08 PM
hotpoint space saver just dead toddboucher Microwave Repair 3 10-27-2009 02:54 PM
Proflie 24" Space Saver GE Washer Not Spinning bobbertj Washer Repair 0 02-02-2008 06:39 AM
