Discuss
Washer banging at the end of spin cycle
 in
Washer Repair
My top load roper RTW4340sq0 is starting to make a banging noise when the spin cycle is stopping. It doesn't
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer banging at the end of spin cycle
  #1 (permalink)
Old 09-24-2017, 07:08 PM
Junior Member
jskocdopole is on a distinguished road
Default Washer banging at the end of spin cycle
Model Number: RTW4340sq0   Brand: Roper   Age: More than 10 years
My top load roper RTW4340sq0 is starting to make a banging noise when the spin cycle is stopping. It doesn't happen all the time, it seems to happen with heavier loads. I've done some research and the most common things I see is replacing the clutch, basket drive, and/or the basket drive block. I just wanted some input on which one it is or if I should just replace all three while I have it apart since the washer is about 11 years old. Everything else works fine, the agitator moves and the basket spins fine with no additional noise.
Thank you
Related Models
Roper RTW4340SQ0 AUTOMATIC WASHER
Roper RTW4400SQ0 AUTOMATIC WASHER
Roper RTW4400TQ0 AUTOMATIC WASHER
Roper RTW4440VQ0 AUTOMATIC WASHER
Roper RTW4440VQ1 AUTOMATIC WASHER
Roper RTW4440VQ2 AUTOMATIC WASHER
Roper RTW4440XQ0 AUTOMATIC WASHER
General Electric RU38*C1 Electric range
General Electric RU38*C2 Electric range
General Electric RU38*C3 Electric range
General Electric RU380C3 ELECTRIC COOKTOP
General Electric RU38B*C1 Electric range
General Electric RU38B*C2 Electric range
General Electric RU38B*C3 Electric range
General Electric RU38B0C3 ELECTRIC COOKTOP
General Electric RU9150S RECOVERY PUMP
Roper RUD0800EB DISHWASHER
Roper RUD0800HB0 DISHWASHER
Roper RUD1000DB0 UNDERCOUNTER DISHWASHER
Roper RUD1000DB1 UNDERCOUNTER DISHWASHER
Roper RUD1000DB2 UNDERCONTER DISHWASHER
Roper RUD1000DB3 DISHWASHERS
Roper RUD1000DB4 UNDERCOUNTER DISHWASHER
Roper RUD1000HB0 DISHWASHER
Roper RUD1000HB1 DISHWASHER
Roper RUD1000KB0 DISHWASHER
Roper RUD1000KB1 DISHWASHER
Roper RUD1000KB3 UNDERCOUNTER DISHWASHER
Roper RUD3000DB0 UNDERCOUNTER DISHWASHER
Roper RUD3000DB1 UNDERCOUNTER DISHWASHER
Roper RUD3000DB2 UNDERCOUNTER DISHWASHER
Roper RUD3000DB3 UNDERCOUNTER DISHWASHER
Roper RUD3000DQ0 UNDERCOUNTER DISHWASHER
Roper RUD3000DQ1 UNDERCOUNTER DISHWASHER
Roper RUD3000DQ3 UNDERCOUNTER DISHWASHER
Roper RUD3000GB0 UNDERCOUNTER DISHWASHER
Roper RUD3000GB1 UNDERCOUNTER DISHWASHER
Roper RUD3000GQ0 UNDERCOUNTER DISHWASHER
Roper RUD3000GQ1 UNDERCOUNTER DISHWASHER
Roper RUD3000HB0 DISHWASHER
Roper RUD3000HB1 DISHWASHER
Roper RUD3000HQ0 DISHWASHER
Roper RUD3000HQ1 DISHWASHER
Roper RUD3000KB0 DISHWASHER
Roper RUD3000KB1 DISHWASHER
Roper RUD3000KQ0 DISHWASHER
Roper RUD3000KQ1 DISHWASHER
Roper RUD3006DB0 UNDERCOUNTER DISHWASHER
Roper RUD3006DB1 UNDERCOUNTER DISHWASHER
Roper RUD3006DB2 UNDERCOUNTER DISHWASHER
Roper RUD3006DB3 DISHWASHERS
Roper RUD4000MB0 UNDERCOUNTER DISHWASHER
Roper RUD4000MB2 UNDERCOUNTER DISHWASHER
Roper RUD4000MQ0 UNDERCOUNTER DISHWASHER
Roper RUD4000MQ2 UNDERCOUNTER DISHWASHER
Roper RUD4000MU0 UNDERCOUNTER DISHWASHER
Roper RUD4000MU1 UNDERCOUNTER DISHWASHER
Roper RUD4000MU2 UNDERCOUNTER DISHWASHER
Roper RUD4000SB0 UNDERCOUNTER DISHWASHER
Roper RUD4000SB1 UNDERCOUNTER DISHWASHER
Roper RUD4000SQ0 UNDERCOUNTER DISHWASHER
Roper RUD4000SQ1 UNDERCOUNTER DISHWASHER
Roper RUD4000SU0 UNDERCOUNTER DISHWASHER
Roper RUD4300DQ2 UNDER-COUNTER DISHWASHER
Roper RUD4300DQ3 DISHWASHERS
Roper RUD4500DB0 UNDERCOUNTER DISHWASHER
Roper RUD4500DB1 UNDERCOUNTER DISHWASHER
Roper RUD4500DB2 UNDERCOUNTER DISHWASHER
Roper RUD4500DB3 DISHWASHERS
Roper RUD4500DB4 UNDERCOUNTER DISHWASHER
Roper RUD4500MB0 UNDERCOUNTER DISHWASHER
Roper RUD4500MB2 UNDERCOUNTER DISHWASHER
Roper RUD4500MQ0 UNDERCOUNTER DISHWASHER
Roper RUD4500MQ2 UNDERCOUNTER DISHWASHER
Roper RUD5000HB0 DISHWASHER
Roper RUD5000HB1 DISHWASHER
Roper RUD5000HQ0 DISHWASHER
Roper RUD5000HQ1 DISHWASHER
Roper RUD5000KB0 DISHWASHER
Roper RUD5000KB1 UNDERCOUNTER DISHWASHER
Roper RUD5000KQ0 DISHWASHER
Roper RUD5000KQ1 UNDERCOUNTER DISHWASHER
Roper RUD5750DB0 UNDERCOUNTER DISHWASHER
Roper RUD5750DB1 UNDERCOUNTER DISHWASHER
Roper RUD5750DB2 DISHWASHER
Roper RUD5750DB3 DISHWASHERS
Roper RUD5750DB4 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ0 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ1 UNDERCOUNTER DISHWASHER
Roper RUD5750DQ2 DISHWASHER
Roper RUD5750DQ3 DISHWASHERS
Roper RUD5750DQ4 UNDERCOUNTER DISHWASHER
Roper RUD5750HB0 DISHWASHER
Roper RUD5750HQ0 DISHWASHER
Roper RUD5750KB0 DISHWASHER
Roper RUD5750KB1 DISHWASHER
Roper RUD5750KQ0 DISHWASHER
Roper RUD5750KQ1 DISHWASHER
Roper RUD6000PB2 UNDERCOUNTER DISHWASHER
Roper RUD6000PQ2 UNDERCOUNTER DISHWASHER
Whirlpool RUD6050RD0 UNDERCOUNTER DISHWASHER
Roper RUD6050RD2 UNDERCOUNTER DISHWASHER
Roper RUD8000RQ0 UNDERCOUNTER DISHWASHER
Roper RUD8000RQ1 UNDERCOUNTER DISHWASHER
Roper RUD8000SQ0 UNDERCOUNTER DISHWASHER
Roper RUD8050RD0 UNDERCOUNTER DISHWASHER
Roper RUD8050SD0 UNDERCOUNTER DISHWASHER
Roper RUD8050SD1 UNDERCOUNTER DISHWASHER
Roper RUD8050SD2 UNDERCOUNTER DISHWASHER
Amana RV-10 COMMERCIAL MICROWAVES
Amana RV-10A COMMERCIAL MICROWAVES
Amana RV-8 COMMERCIAL MICROWAVES
Amana RV10 COMMERCIAL MICROWAVES
Roper RV1088RBW00 VERTICAL FREEZER
Amana RV10A COMMERCIAL MICROWAVES
Amana RV10AT COMMERCIAL MICROWAVES
  #2 (permalink)
Old 09-25-2017, 11:14 PM
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
Does it happen just as the washer finishes its spin? Its probably the brakes grabbing and stopping too soon.
Parts for Roper RTW4340SQ0: Brake and Drive Tube Parts - AppliancePartsPros.com
Whirlpool told me to spray a little WD40 on a rag and wipe the inside of the drum so the brakes will not stick, but instead slow down smoothly.
  #3 (permalink)
Old 09-26-2017, 08:30 PM
Junior Member
Default
Thanks I'll check that out, I think at this point I'm just going to order a spanner wrench and take a look at things. Its not that bad to take the washer apart. It will beat guessing then getting the wrong thing.
  #4 (permalink)
Old 09-26-2017, 10:36 PM
ThatGuy's Avatar
Expert
APP Volunteer
Default
I was a service tech. for Whirlpool for more than 20 years. I was trying to help you diagnose your problem. A brake that grabs doesn't really require any new parts, just some WD40.
  #5 (permalink)
Old 10-01-2017, 02:54 PM
Junior Member
Default
I wasn't discounting what you said, I was just saying I wanted to see what was wrong instead of going off a sound. It ended up being that the basket drive block was worn out and was skipping over the nubs it grabs on to. I still cleaned everything else while I had it apart. I worked industrial matanance for ten years so I took a concencus of many different forums then descided it was easier just to see what was going on. I still appreciate the time you took to post you diagnosis.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer noise (banging) spin cycle rtdwest1 Washer Repair 1 05-15-2017 08:09 PM
Noisy washer banging in spin cycle jeaniene Washer Repair 0 03-14-2016 01:24 PM
Front Load Washer Banging at end of spin cycle dalo6926 Washer Repair 0 07-01-2015 09:29 PM
washer banging sound while in spin cycle avemaria Washer Repair 2 10-01-2014 05:22 PM
Kenmore Elite washer banging in spin cycle chuckdog Washer Repair 0 11-03-2012 10:57 AM
