Discuss
25 Year Old Whirlpool:Wash Tub Flopps Around and Jerks
 in
Washer Repair
I have looked at a number of videos and searched but I cannot find a satisfying answer. The washtub seems
Appliance Repair Forum > Appliance Repair Help > Washer Repair » 25 Year Old Whirlpool:Wash Tub Flopps Around and Jerks
  #1 (permalink)
Old 09-22-2017, 06:15 PM
Junior Member
MattyD is on a distinguished road
Default 25 Year Old Whirlpool:Wash Tub Flopps Around and Jerks
Model Number: LSR7233DQ0   Brand: Whirlpool   Age: More than 10 years
The washtub seems to be too loose. It goes out of balance very easily and when you turn the machine off the tub jerks violently, banging into the surrounding structures.
I took the outer housing off the machine expecting to find broken suspension springs, but all the springs seem to be intact, including the counter balance spring. The tub and motor assembly seem to move too easily and too much. Is it possible bad suspension pads and snubbers could allow this condition to occur? Puzzled and needing to get some wash down and hating the laundromat.
Related Models
Whirlpool LSR7233DQ0 WASHER
Whirlpool LSR7233DQ1 AUTOMATIC WASHER
Whirlpool LSR7233DW0 WASHER
Whirlpool LSR7233DZ0 WASHER
Whirlpool LSR7233DZ1 AUTOMATIC WASHER
Whirlpool LSR7233EQ0 WASHER
Whirlpool LSR7233EQ1 AUTOMATIC WASHER
Whirlpool LSR7233EW0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ0 DIRECT-DRIVE WASHER
Whirlpool LSR7233EZ1 AUTOMATIC WASHER
Whirlpool LSR7233HQ0 AUTOMATIC WASHER
Whirlpool LSR7233HZ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ0 AUTOMATIC WASHER
Whirlpool LSR7300PQ1 AUTOMATIC WASHER
Whirlpool LSR7300PQ2 AUTOMATIC WASHER
Whirlpool LSR7333PQ0 AUTOMATIC WASHER
Whirlpool LSR7333PQ1 AUTOMATIC WASHER
Whirlpool LSR7333PQ3 AUTOMATIC WASHER
Whirlpool LSR7333PQ4 AUTOMATIC WASHER
Whirlpool LSR8010PQ0 AUTOMATIC WASHER
Whirlpool LSR8010PQ1 AUTOMATIC WASHER
Whirlpool LSR8010PQ2 AUTOMATIC WASHER
Whirlpool LSR8010PT0 AUTOMATIC WASHER
Whirlpool LSR8010PT1 AUTOMATIC WASHER
Whirlpool LSR8010PT2 AUTOMATIC WASHER
Whirlpool LSR8133HQ0 AUTOMATIC WASHER
Whirlpool LSR8133HZ0 AUTOMATIC WASHER
Whirlpool LSR8200EQ0 AUTOMATIC WASHER
Whirlpool LSR8200EZ0 AUTOMATIC WASHER
Whirlpool LSR8233EQ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EQ1 AUTOMATIC WASHER
Whirlpool LSR8233EZ0 HOME WASHERS DIRECT-DRIVE
Whirlpool LSR8233EZ1 AUTOMATIC WASHER
Whirlpool LSR8233JQ0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JQ1 WASHER
Whirlpool LSR8233JT0 AUTOMATIC WASHER, COMPACT A/W
Whirlpool LSR8233JT1 WASHER
Whirlpool LSR8244BN0
Whirlpool LSR8244BN1
Whirlpool LSR8244BN2
Whirlpool LSR8244BW0
Whirlpool LSR8244BW1
Whirlpool LSR8244BW2
Whirlpool LSR8244DQ0
Whirlpool LSR8244DZ0
Whirlpool LSR8244EQ0
Whirlpool LSR8244EQ1
Whirlpool LSR8244EZ0
Whirlpool LSR8244EZ1
Whirlpool LSR8300EQ0
Whirlpool LSR8300EQ1
Whirlpool LSR8300EZ0
Whirlpool LSR8300EZ1
Whirlpool LSR8433KQ0 WASHER
Whirlpool LSR8433KQ1 AUTOMATIC WASHER
Whirlpool LSR8433KQ2 AUTOMATIC WASHER
Whirlpool LSR8433KT0 WASHER
Whirlpool LSR8433KT1 AUTOMATIC WASHER
Whirlpool LSR8433KT2 AUTOMATIC WASHER
Whirlpool LSR8444LQ0 WASHER
Whirlpool LSR8444LQ1 AUTOMATIC WASHER
Whirlpool LSR8444LT0 WASHER
Whirlpool LSR9355DQ0
Whirlpool LSR9355DZ0
Whirlpool LSR9434PQ0 AUTOMATIC WASHER
Whirlpool LSR9434PQ1 AUTOMATIC WASHER
Whirlpool LSR9434PQ3 AUTOMATIC WASHER
Whirlpool LSR9434PQ4 AUTOMATIC WASHER
Whirlpool LSR9434PT0 AUTOMATIC WASHER
Whirlpool LSR9434PT1 AUTOMATIC WASHER
Whirlpool LSR9434PT3 AUTOMATIC WASHER
Whirlpool LSR9434PT4 AUTOMATIC WASHER
General Electric LSS25XGTABB Refrigerator
General Electric LSS25XGTAWW Refrigerator
General Electric LSS25XGTBBB Refrigerator
General Electric LSS25XGTBWW Refrigerator
General Electric LSS25XGTEBB Refrigerator
General Electric LSS25XGTEWW Refrigerator
General Electric LSS25XSTASS Refrigerator
General Electric LSS25XSTBSS Refrigerator
General Electric LSS25XSTESS Refrigerator
General Electric LSS25XSWASS REFRIGERATOR W SERIES
General Electric LSS25XSWCSS REFRIGERATOR W SERIES
Whirlpool LSS7233AN0
Whirlpool LSS7233AN1
Whirlpool LSS7233AW0
Whirlpool LSS7233AW1
Whirlpool LSS7233DQ0
Whirlpool LSS8244AQ0
Whirlpool LSS8244AW0
Whirlpool LSS8244AZ0
Whirlpool LSS9244EQ0 WASHER
Whirlpool LSS9244EZ0 WASHER
Whirlpool LST6132AG0
Whirlpool LST6132AN0
Whirlpool LST6132AW0
Whirlpool LST6132BN0
Whirlpool LST6132BW0
Whirlpool LST6132BW1
Whirlpool LST6132DQ0
Whirlpool LST7233AG0
Whirlpool LST7233AN0
Whirlpool LST7233AN1
Whirlpool LST7233AQ0
Whirlpool LST7233AQ1
Whirlpool LST7233AW0
Whirlpool LST7233AW1
Whirlpool LST7233AZ0
Whirlpool LST7233AZ1
Whirlpool LST7233DQ0
Whirlpool LST7233DQ1
Whirlpool LST7233DZ0
Whirlpool LST7233DZ1
Whirlpool LST8244AN0
Whirlpool LST8244AQ0
Whirlpool LST8244AW0
Whirlpool LST8244AZ0
Whirlpool LST8244BQ0
Whirlpool LST8244BQ1
Whirlpool LST8244BW0
  #2 (permalink)
Old 09-22-2017, 06:28 PM
Senior Member
brobriffin is on a distinguished road
Default
Check to see if the skate plate ( the part with the snubber pads) is out of alignment. If it is aligned properly then I would suspect you need to replace both the suspension pads (snubbers) on the skate plate and the tub suspension pads on the base frame.
Whirlpool 285219 Suspension Pad Kit - AppliancePartsPros.com
Whirlpool 285744 Tub Suspension Pads - AppliancePartsPros.com
  #3 (permalink)
Old 09-22-2017, 07:30 PM
Junior Member
Default
Is the "skate plate" the metal frame that everything is attached to, which rides and slides on the base that basically rests on the floor? That is where the most movement seems to be. If I'm understanding there should be three pads that isolate these two metal frames. And then on the next level up there's a kind of cradle with three more pads. I think the pads in the upper level are okay, But I think the lower pads are missing and the frames are riding metal on metal.
Will I need to get one of those spanner wrenches to get this thing apart to investigate fully?
  #4 (permalink)
Old 09-22-2017, 07:47 PM
Senior Member
Default
Look at item 17 on the drawing. The skate plate is a triangular piece that rests between the base frame and tub assembly. There are pads both on the base plate which the skate rides on and the skate has pads which the tub assembly rides on.
Parts for Whirlpool LSR7233DQ0: Machine Base Parts - AppliancePartsPros.com
  #5 (permalink)
Old 09-22-2017, 07:50 PM
Senior Member
Default
Watch the how-to videos with the links I sent for the pads. It will show you steps to access the pads.
  #6 (permalink)
Old 09-23-2017, 11:14 AM
Junior Member
Default
I can lift the skate frame off the base slightly and see that it seems to be rubbing, metal on metal. So, it looks like I need a spanner wrench to go any further.
  #7 (permalink)
Old 09-23-2017, 11:50 AM
Senior Member
Default
Perhaps a local app repair joint would rent or loan one if you purchased the pads from them... Just a thought!
Also verify that the plate is in the proper position on the base. The arms of the plate should be evenly on top of the pads of the base.
  #8 (permalink)
ThatGuy's Avatar
Expert
APP Volunteer
ThatGuy is on a distinguished road
Default
You should be able to replace the skate plate without removing the inner basket.
Remove the agitator, take the motor and pump off. Remove the three springs. Remove the rear spring. Remove the three bolts bolts that hold the gearcase on. Slide the gearcase straight out and set it off to one side. You should be able to lift the inner and other tubs off the base frame and skate plate.(As one piece.)
Replace the pads and skate plate. Reassemble washer.
  #9 (permalink)
Old 09-23-2017, 12:12 PM
Junior Member
Default
So I can approach this from the bottom up instead of the top down? Very clever. I will give it a try. Thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
4 Year old Whirlpool Not Running ineoeni Dishwasher Repair 0 11-11-2012 11:33 AM
1 year old Whirlpool gas dryer, doesn't heat Rich A Dryer Repair 3 03-15-2012 02:46 PM
When At Start Of Wash Cycle Jerks To The Left Then To The Right Then Gives Code ..le kat1234 Washer Repair 0 08-16-2011 12:22 PM
15 year old whirlpool chuckwill123 Dryer Repair 1 12-11-2009 07:10 AM
10 year old Whirlpool gas dryer georgec Dryer Repair 0 11-08-2009 02:25 PM
