Discuss
agitator out?
 in
Washer Repair
Hi, I am replacing the seal at the bottom of the tub, and am at the point to remove the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » agitator out?
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 02-22-2008, 08:41 AM
jkl jkl is offline
Junior Member
jkl is on a distinguished road
Default agitator out?
Model Number: LWA30AW   Brand: Amana   Age: 5 - 10 years
I am replacing the seal at the bottom of the tub, and am at the point to remove the agitator, how do I do that? There is no bolt inside the top of it. Does it spin out/off?
jkl
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 02-22-2008, 09:38 AM
Kwhits Kwhits is offline
Junior Member
Kwhits is on a distinguished road
Default Agitator Removal
There should be a small hex head (usually 1/4") attaching the plastic agitator to the metal agitator shaft on the side of agitator. Just reach into the tub area and feel around near where the agitator base flares out. The screw will be just above it. It would help if you have a mirror to see it. Once the screw is loosen a couple turns (not necessary to remove it completely) the agitator will lift off of the splined shaft. Good luck...
Tom
  #3 (permalink)
Old 02-22-2008, 03:35 PM
jkl jkl is offline
Junior Member
Default agitator?
Model LWA30AW
in this sight there is no hex head, also I have looked very carefully, any other ideas
jkl
  #4 (permalink)
Old 02-22-2008, 07:08 PM
roycreamer roycreamer is offline
Expert
APP Volunteer
roycreamer is on a distinguished road
Default
unless you are VERY mechanically inclined, (like you work on cars for a living) i would not attempt this job. you need special tools to get some parts off, (and on).
kudo's if you succeed...
roy
  #5 (permalink)
Old 02-23-2008, 12:09 PM
jkl jkl is offline
Junior Member
Default agitator?
Well, this is one of those time where I hafta do any other ideas how to get the agitator out?
jkl
  #6 (permalink)
Old 03-22-2008, 01:24 PM
HLBAKER1 HLBAKER1 is offline
Junior Member
HLBAKER1 is on a distinguished road
Default
Take Your Fingers And Place Them Under The Agitator Lip And Pull Straight Upip
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer 80 top agitator does not move with bottom agitator erbaker Washer Repair 1 02-19-2008 11:11 AM
agitator hurst Washer Repair 2 12-13-2007 05:22 PM
Mover Agitator Came Off The Agitator memmie Washer Repair 2 11-16-2007 06:41 PM
Top Agitator came apart from the bottom Agitator memmie Washer Repair 1 11-15-2007 09:06 PM
Top agitator on duel agitator not working bigfoot Washer Repair 1 10-28-2007 05:34 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
