Discuss
Grounding Washer?
 in
Washer Repair
Not really a repair question, more of an installation question. My washer has a ground wire hanging from the back.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Grounding Washer?
  #1 (permalink)
Old 09-13-2017, 10:22 AM
Junior Member
M Yaworski is on a distinguished road
Default Grounding Washer?
Brand: Kitchen Aid   Age: More than 10 years
My washer has a ground wire hanging from the back. At one time, this wire was attached to the cold water pipe to ground it.
The outlet is grounded and according to my meter the ground is good. The question is, do I need to hook that ground back to the pipe?
I understand that if the outlet wasn't grounded, it would important to ground the unit through another means.
In case you're wondering, I inherited this house which included the washer and dryer. The house is 60 years old and most outlets were not grounded outlets. I've been going through the house and replacing the outlets. The boxes are all grounded back to the panel which is grounded outside in the actual ground.
As always, thanks.
  #2 (permalink)
Old 09-16-2017, 08:41 AM
Senior Member
brobriffin is on a distinguished road
Default
If you have indeed run three wire from the breaker panel to the plug outlet and it is grounded as you said, then you are correct you do not have to run a separate ground if the washer has a three prong (grounding) plug. That would be my question does the washer have three prongs on its electric cord or is it two prong?
  #3 (permalink)
Old 09-17-2017, 04:20 PM
Junior Member
Default
Thanks, that's what I thought but I figured that I might as well check in case there is something unusual about washers.
Ground from the outlet goes back to the panel and it is a three prong plug.
Now I have about ten feet of green wire for my parts bin. :-)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Missing grounding prong seldomJAZZ Refrigerator & Freezer Repair 0 03-18-2014 06:37 PM
Grounding problem Randy49 Dishwasher Repair 0 01-22-2014 06:00 PM
Grounding for washer Christinejoy Washer Repair 3 09-25-2012 03:47 AM
Grounding Control Board/ tavarich7 Washer Repair 1 03-01-2011 09:41 AM
Grounding Wires Ge Refrigerator MGRINZ Refrigerator & Freezer Repair 0 02-02-2010 06:14 PM
