Discuss
Washer Won't Spin
 in
Washer Repair
Entered the test mode and got the following error messages: Er:20 Spin Cycle Terminated, No communication between control and inverter,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Won't Spin
  #1 (permalink)
Old 09-05-2017, 12:00 PM
Junior Member
je00409 is on a distinguished road
Default Washer Won't Spin
Model Number: WFVC4400UC/29   Brand: Bosch   Age: 1 - 5 years
Er:20 Spin Cycle Terminated, No communication between control and inverter, Unbalance too high, check wire harness, check load
dr:08 Speedometer Failure, Damaged speedometer, check wire harness
dr:10 Power limiter switch off, too heavy load, mechanical friction, check oscillating system, check gasket, check load
dr:11 Voltage too low, weak power supply, check line voltage
Given the above, is this something that can be repaired and if so, what parts are needed?
Thank you
Related Models
Whirlpool WFW8200TW00 AUTOMATIC WASHER
Whirlpool WFW8200TW01 AUTOMATIC WASHER
Whirlpool WFW8300SW0 AUTOMATIC WASHER
Whirlpool WFW8300SW00 RESIDENTIAL WASHER
Whirlpool WFW8300SW01 RESIDENTIAL WASHER
Whirlpool WFW8300SW02 AUTOMATIC WASHER
Whirlpool WFW8300SW03 AUTOMATIC WASHER
Whirlpool WFW8300SW04 AUTOMATIC WASHER
Whirlpool WFW8300SW05 AUTOMATIC WASHER
Whirlpool WFW8300SW1 AUTOMATIC WASHER
Whirlpool WFW8400TB00 AUTOMATIC WASHER
Whirlpool WFW8400TB01 AUTOMATIC WASHER
Whirlpool WFW8400TB02 AUTOMATIC WASHER
Whirlpool WFW8400TE00 AUTOMATIC WASHER
Whirlpool WFW8400TE01 AUTOMATIC WASHER
Whirlpool WFW8400TW00 AUTOMATIC WASHER
Whirlpool WFW8400TW01 AUTOMATIC WASHER
Whirlpool WFW8400TW02 AUTOMATIC WASHER
Whirlpool WFW8400TW03 AUTOMATIC WASHER
Whirlpool WFW8410SW0 AUTOMATIC WASHER
Whirlpool WFW8410SW01 AUTOMATIC WASHER
Whirlpool WFW8410SW02 AUTOMATIC WASHER
Whirlpool WFW8410SW03 AUTOMATIC WASHER
Whirlpool WFW8500SR0 AUTOMATIC WASHER
Whirlpool WFW8500SR01 AUTOMATIC WASHER
Whirlpool WFW8500SR02 AUTOMATIC WASHER
Whirlpool WFW8500SR03 AUTOMATIC WASHER
Whirlpool WFW8500SR04 AUTOMATIC WASHER
Whirlpool WFW9050XW00 AUTOMATIC WASHER
Whirlpool WFW9050XW01 AUTOMATIC WASHER
Whirlpool WFW9050XW02 AUTOMATIC WASHER
Whirlpool WFW9050XW03 AUTOMATIC WASHER
Whirlpool WFW9150WW00 AUTOMATIC WASHER
Whirlpool WFW9150WW01 AUTOMATIC WASHER
Whirlpool WFW9150WW02 AUTOMATIC WASHER
Whirlpool WFW9151YW00 WASHER
Whirlpool WFW9200SQ00 AUTOMATIC WASHER
Whirlpool WFW9200SQ01 AUTOMATIC WASHER
Whirlpool WFW9200SQ02 AUTOMATIC WASHER
Whirlpool WFW9200SQ03 AUTOMATIC WASHER
Whirlpool WFW9200SQ04 AUTOMATIC WASHER
Whirlpool WFW9200SQ10 AUTOMATIC WASHER
Whirlpool WFW9200SQA10 AUTOMATIC WASHER
Whirlpool WFW9200SQA11 AUTOMATIC WASHER
Whirlpool WFW9200SQA12 AUTOMATIC WASHER
Whirlpool WFW9250WL00 AUTOMATIC WASHER
Whirlpool WFW9250WL01 AUTOMATIC WASHER
Whirlpool WFW9250WL02 AUTOMATIC WASHER
Whirlpool WFW9250WR00 AUTOMATIC WASHER
Whirlpool WFW9250WR01 AUTOMATIC WASHER
Whirlpool WFW9250WR02 AUTOMATIC WASHER
Whirlpool WFW9250WW00 AUTOMATIC WASHER
Whirlpool WFW9250WW01 AUTOMATIC WASHER
Whirlpool WFW9250WW02 WASHER
Whirlpool WFW9300VU02 AUTOMATIC WASHER
Whirlpool WFW9300VU03 AUTOMATIC WASHER
Whirlpool WFW9300VU04 AUTOMATIC WASHER
Whirlpool WFW9351YL00 AUTOMATIC WASHER
Whirlpool WFW9351YW00 AUTOMATIC WASHER
Whirlpool WFW9400SB00 AUTOMATIC WASHER
Whirlpool WFW9400SB01 AUTOMATIC WASHER
Whirlpool WFW9400SB02 AUTOMATIC WASHER
Whirlpool WFW9400SBA10 AUTOMATIC WASHER
Whirlpool WFW9400ST00 AUTOMATIC WASHER
Whirlpool WFW9400ST01 AUTOMATIC WASHER
Whirlpool WFW9400ST02 AUTOMATIC WASHER
Whirlpool WFW9400STA10 AUTOMATIC WASHER
Whirlpool WFW9400SU00 AUTOMATIC WASHER
Whirlpool WFW9400SU01 AUTOMATIC WASHER
Whirlpool WFW9400SU02 AUTOMATIC WASHER
Whirlpool WFW9400SW00 AUTOMATIC WASHER
Whirlpool WFW9400SW01 AUTOMATIC WASHER
Whirlpool WFW9400SW02 AUTOMATIC WASHER
Whirlpool WFW9400SW03 AUTOMATIC WASHER
Whirlpool WFW9400SW04 AUTOMATIC WASHER
Whirlpool WFW9400SWA10 AUTOMATIC WASHER
Whirlpool WFW9400SZ00 AUTOMATIC WASHER
Whirlpool WFW9400SZ01 AUTOMATIC WASHER
Whirlpool WFW9400SZ02 AUTOMATIC WASHER
Whirlpool WFW9400SZ03 AUTOMATIC WASHER
Whirlpool WFW9400SZ04 AUTOMATIC WASHER
Whirlpool WFW9400SZA10 AUTOMATIC WASHER
Whirlpool WFW9400VE01 AUTOMATIC WASHER
Whirlpool WFW9400VE02 AUTOMATIC WASHER
Whirlpool WFW9400VE03 AUTOMATIC WASHER
Whirlpool WFW9410XW00 WASHER
Whirlpool WFW9450WL00 AUTOMATIC WASHER
Whirlpool WFW9450WR00 AUTOMATIC WASHER
Whirlpool WFW9450WW00 AUTOMATIC WASHER
Whirlpool WFW9451XW00 AUTOMATIC WASHER
Whirlpool WFW9470WL00 AUTOMATIC WASHER
Whirlpool WFW9470WL01 AUTOMATIC WASHER
Whirlpool WFW9470WR00 AUTOMATIC WASHER
Whirlpool WFW9470WR01 AUTOMATIC WASHER
Whirlpool WFW9470WW00 AUTOMATIC WASHER
Whirlpool WFW9470WW01 AUTOMATIC WASHER
Whirlpool WFW94HEXL0 WASHER
Whirlpool WFW94HEXL1 AUTOMATIC WASHER
Whirlpool WFW94HEXL2 AUTOMATIC WASHER
Whirlpool WFW94HEXR0 WASHER
Whirlpool WFW94HEXR1 AUTOMATIC WASHER
Whirlpool WFW94HEXR2 AUTOMATIC WASHER
Whirlpool WFW94HEXW0 WASHER
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
  #2 (permalink)
Old 03-19-2018, 12:09 AM
Junior Member
missie is on a distinguished road
Default What did it turn out to be???
I have the exact same model and mine won't spin at all. Only error code is E20. SOOO frustrated!!!
  #3 (permalink)
Old 03-19-2018, 04:38 AM
Junior Member
Default
It needed a motor and motor control board. I bought a new washer.
  #4 (permalink)
Old 03-19-2018, 05:46 AM
Junior Member
Default
Thanks so much for the quick reply! I THINK my motor is ok- if I tested it correctly... so I guess I'll gamble on the control board. Thanks, again!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer wont spin . spins only when switch is turned to spin.. smieri6 Washer Repair 4 07-19-2013 05:30 PM
my kenmore washer makes a grinding noise during spin cycle and does not spin bronco48 Washer Repair 2 10-28-2012 02:42 AM
LOW-SPIN DURING SPIN CYCLE of MayTag Neptune Dryer/Washer stack mrdhoffman Washer Repair 1 08-30-2011 06:45 PM
Front load washer won't spin water out of clothes on last spin cycle Tracey Finley Washer Repair 1 06-28-2011 05:10 PM
Frigidare front load washer will not spin durning final spin cyle binky8992 Washer Repair 2 08-19-2009 06:29 PM
