I have a GE washer that will cycles really slow it just started doing this. We have just recently moved and it worked fine for a month or so and then bam it starts acting up. I cant afford to replace the machine right now. I there any way I can test some things to see what is causing it and then replace a part to fix the problem. Thanks for the help in advance.
