Discuss
Check switch fuse blows on unbalanced load
 in
Washer Repair
Maytag washer kept spinning with loud banging on badly unbalanced load. I opened the lid to stop the spinning and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Check switch fuse blows on unbalanced load
  #1 (permalink)
Old 09-02-2017, 03:44 PM
Junior Member
gesingle is on a distinguished road
Default Check switch fuse blows on unbalanced load
Model Number: LAT9806AAM   Brand: Maytag   Age: More than 10 years
Maytag washer kept spinning with loud banging on badly unbalanced load. I opened the lid to stop the spinning and adjusted the load. Upon closing the lid, the washer would not restart. I reset all the buttons and centered the tub.
Troubleshooting, I found the 4 amp fuse on the lid switch assembly was blown. I replaced the fuse and it immediately blew again on start. So, I ordered and replaced the WP22001682 assembly. I also removed and inspected the off balance lever and actuator. While somewhat corroded, it did not appear damaged. After reassembly, the washer now works.
I checked the continuity of the old lid and check switches. They are good.
So here are my questions:
1. The user's manual says an unevenly distributed load may stop the washer. Why would the unbalanced load not automatically stop it in my case? Is there another part that may be broken?
2. The fuse blew when I opened the lid while the tub was thrashing. What could cause it to blow then? Perhaps the balance lever was jammed in an unnatural position until I disassembled?
For information to others who may puzzle over how the check switch works, here is what I found (correct me if I'm wrong). The lid switch is the long switch next to the fuse. It opens when the lid is slightly opened. The check switch is the smaller 3 terminal switch. It switches when the lid opens farther. If the lid switch fails closed and the lid is opened until the check switch closes, the fuse will blow to give a safety shutdown of the washer. Verify both switch operations when adjusting.
Related Models
Maytag LAT9806AAM WASHER-TOP LOADING
Maytag LAT9806ABE WASHER-TOP LOADING
Admiral LAT9806AGE WASHER-TOP LOADING
Admiral LAT9806AKM WASHER-TOP LOADING
Admiral LAT9806AKQ WASHER-TOP LOADING
Admiral LAT9806BGE WASHER-TOP LOADING
Admiral LAT9806DAM WASHER-TOP LOADING
Admiral LAT9806DAQ WASHER-TOP LOADING
Admiral LAT9806GGE WASHER-TOP LOADING
Maytag LAT9824AAE WASHER-TOP LOADING
Maytag LAT9824AAL WASHER-TOP LOADING
Maytag LAT9824AAM WASHER-TOP LOADING
Maytag LAT9824ABE WASHER-TOP LOADING
Maytag LAT9824ABL WASHER-TOP LOADING
Maytag LAT9824ABM WASHER-TOP LOADING
Admiral LAT9824AGE WASHER-TOP LOADING
Admiral LAT9824AKM WASHER-TOP LOADING
Admiral LAT9824BGE WASHER-TOP LOADING
Admiral LAT9824DAM WASHER-TOP LOADING
Admiral LAT9824GGE WASHER-TOP LOADING
Maytag LAT9900AAL WASHER-TOP LOADING
Maytag LAT9900AAW WASHER-TOP LOADING
Maytag LAT9900ABL WASHER-TOP LOADING
Maytag LAT9900ABW WASHER-TOP LOADING
Maytag LAT9904AAE WASHER-TOP LOADING
Maytag LAT9904AAL WASHER-TOP LOADING
Maytag LAT9904AAM WASHER-TOP LOADING
Maytag LAT9904ABE WASHER-TOP LOADING
Admiral LATA100AAE WASHER-TOP LOADING
Admiral LATA100AAL WASHER-TOP LOADING
Admiral LATA100AAM WASHER-TOP LOADING
Admiral LATA100AAW WASHER-TOP LOADING
Admiral LATA100AGE WASHER-TOP LOADING
Admiral LATA100AJE WASHER-TOP LOADING
Admiral LATA100AKE WASHER-TOP LOADING
Admiral LATA100ARE WASHER-TOP LOADING
Admiral LATA200AAE WASHER-TOP LOADING
Admiral LATA200AAL WASHER-TOP LOADING
Admiral LATA200AAM WASHER-TOP LOADING
Admiral LATA200AAW WASHER-TOP LOADING
Admiral LATA200AGE WASHER-TOP LOADING
Admiral LATA200AJE WASHER-TOP LOADING
Admiral LATA200AJM WASHER-TOP LOADING
Admiral LATA300AAE WASHER-TOP LOADING
Admiral LATA300AAL WASHER-TOP LOADING
Admiral LATA300AAM WASHER-TOP LOADING
Admiral LATA300AAW WASHER-TOP LOADING
Admiral LATA300AGL WASHER-TOP LOADING
Admiral LATA300AGW WASHER-TOP LOADING
Admiral LATA400AAE WASHER-TOP LOADING
Admiral LATA400AAL WASHER-TOP LOADING
Admiral LATA400AAM WASHER-TOP LOADING
Admiral LATA400AAW WASHER-TOP LOADING
Admiral LATA400AGE WASHER-TOP LOADING
Admiral LATA400AKE WASHER-TOP LOADING
Admiral LATA400AKL WASHER-TOP LOADING
Admiral LATA400ASE WASHER-TOP LOADING
Admiral LATA401AGE WASHER-TOP LOADING
Admiral LATA401AGM WASHER-TOP LOADING
Admiral LATA401AKE WASHER-TOP LOADING
Admiral LATA401ARE WASHER-TOP LOADING
Admiral LATA500AAE WASHER-TOP LOADING
Admiral LATA500AAL WASHER-TOP LOADING
Admiral LATA500AAW WASHER-TOP LOADING
Hoover LATH100AAM WASHER-TOP LOADING
Hoover LATH100AAV WASHER-TOP LOADING
Hoover LATH100AKM WASHER-TOP LOADING
Hoover LATH100AKV WASHER-TOP LOADING
Hoover LATH100ARV WASHER-TOP LOADING
Hoover LATH100ARW WASHER-TOP LOADING
Hoover LATH100ATV WASHER-TOP LOADING
Hoover LATH300AAV WASHER-TOP LOADING
Hoover LATH300AKM WASHER-TOP LOADING
Hoover LATH300AKV WASHER-TOP LOADING
Hoover LATH300ARV WASHER-TOP LOADING
Hoover LATH300ATV WASHER-TOP LOADING
Hoover LATH400AAV WASHER-TOP LOADING
Hoover LATH400ATV WASHER-TOP LOADING
 LAU091CNP Air Conditioner
 LAU091HNP Air Conditioner
 LAU095HV Air Conditioner
 LAU121HNM Air Conditioner
 LAU121HNP Air Conditioner
 LAU125HV Air Conditioner
 LAU181CNW Air Conditioner
 LAU185HV Air Conditioner
 LAU245HV Air Conditioner
Maytag LAV3600AWW WASHER-TOP LOADING
Maytag LAW2400AAE WASHER-TOP LOADING
Maytag LAW2401AAE WASHER-TOP LOADING
Maytag LAW7500AAL WASHER-TOP LOADING
Maytag LAW7500AAW WASHER-TOP LOADING
Maytag LAW7500ABL WASHER-TOP LOADING
Maytag LAW7500ABW WASHER-TOP LOADING
Maytag LAW7500ABX WASHER-TOP LOADING
Maytag LAW9304AAE WASHER-TOP LOADING
Maytag LAW9304AAL WASHER-TOP LOADING
Maytag LAW9304AAM WASHER-TOP LOADING
Maytag LAW9304ABE WASHER-TOP LOADING
Maytag LAW9400AAL WASHER-TOP LOADING
Maytag LAW9400AAW WASHER-TOP LOADING
Maytag LAW9400ABL WASHER-TOP LOADING
Maytag LAW9400ABW WASHER-TOP LOADING
Maytag LAW9406AAE WASHER-TOP LOADING
Maytag LAW9406ABE WASHER-TOP LOADING
Maytag LAW9700AAL WASHER-TOP LOADING
Maytag LAW9700AAW WASHER-TOP LOADING
Maytag LAW9700ABL WASHER-TOP LOADING
Maytag LAW9700ABW WASHER-TOP LOADING
Maytag LAW9704AAE WASHER-TOP LOADING
Maytag LAW9704AAL WASHER-TOP LOADING
Maytag LAW9704AAM WASHER-TOP LOADING
Maytag LAW9704ABE WASHER-TOP LOADING
 LB1200ER Air Conditioner
Whirlpool LB3000XKW0
Whirlpool LB3000XLW0
Whirlpool LB5300XKW0
Whirlpool LB5300XLW0
Whirlpool LB5500XKW0
Whirlpool LB5500XLW0
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
inertial unbalanced load switch STEVEG1960 Washer Repair 0 01-29-2017 07:07 PM
Top load - unbalanced load error Dunkdad Washer Repair 0 08-31-2016 08:51 PM
Blows HV fuse, components okay...wrong fuse(?) c-peter5 Microwave Repair 0 07-27-2014 05:44 PM
unbalanced load koonsjoanna Washer Repair 0 05-22-2012 11:06 AM
Load Thumping Noise & Unbalanced Condition On GE front load washer Luke Vincent Washer Repair 2 08-06-2009 06:43 PM
