Will not allow water in
Washer Repair
On timer is a electronic control that sits on the left side back of the timer. I believe it is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Will not allow water in
  #1 (permalink)
Old 08-25-2017, 10:41 AM
Junior Member
Lululee is on a distinguished road
Default Will not allow water in
Model Number: 110.29522801   Brand: Kenmore   Age: 5 - 10 years
On timer is a electronic control that sits on the left side back of the timer. I believe it is also called an agitator delay unit. My question is can this if defective stop the water from entering the machine. note: At this point I have spent more than this machine is worth, but I have to know why no water is entering. I have bought new parts: Timer, sensor temp pressure switch, lid switch, water inlet valves, I have tested continuity and I have ran 1 120 volt test and here is the results. 120 volts but only 2.2 volts to water valves and it takes 120 v to open valves. Please tell me if that electronic control would stop water entering and of course the drop in voltage
Related Models
Hoover 1100
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11012202100 WASHER
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 08-26-2017, 09:00 AM
Senior Member
PNWDrew is on a distinguished road
Not likely as that is just agitation delay for handwash/delicates. I don't recall ever changing one. You may have a bad pressure switch or timer.
Does it agitate while empty?
1)Pull the hose off the pressure switch in console and blow down it, it should be audible entering the tub. If not the pressure switch thinks the machine is full. Normally this would make it agitate while empty, or overflow.
2)While that hose is off try to start again and see if water flows.
You can pull the knob off the pressure switch and remove it from console then gently blow into it's nipple. Very gently. It should click, that click is it recognizing a full tub and telling timer to start agitation.
After that start tracing wires, from pressure switch to valves and from timer to pressure switch. You may have a broken wire or other less likely issue.
W10337781 - pressure switch
  #3 (permalink)
Old 08-27-2017, 12:18 PM
Junior Member
Default will not allow water in
Thank you PNWDrew. I did as you suggested and no water still will come in to the machine. The model # of washer is 110.29522801 it uses a pressure, sensor/temp all in one switch. The switch part # is 1010248240 which I replaced. The water inlet valve is W10175893 with thermistor, which I replaced. I also replaced the timer, however I have not replaced the control unit on back of timer. I have gone through the wiring several times and found no breaks. below the water inlet valves is a white circular unit that attaches to the hose before entering the tub and it has a small wire connection. I am assuming it is a level control but for the life of me I am not sure. Do you have any ideas. I am starting to think that I bought a defective switch and have to find which one. I have no agitation and no pump action now, possible the new timer is at fault?
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Ice maker poring water. Replaced water valve and ice maker still no water going in to Lab2004 Refrigerator & Freezer Repair 0 10-22-2014 03:07 PM
Frigidarie Water leaking in ICW make while dispensing water from water dispenser psanand Refrigerator & Freezer Repair 0 05-12-2012 06:32 PM
Water refilling ice or water dispenser=water spraying in fridge cheshirekitti Refrigerator & Freezer Repair 2 01-30-2012 09:28 AM
Water Dispener on Whirlpool Fridge Makes Noise and Vibrates Water Line But No Water ugagrad04 Refrigerator & Freezer Repair 0 07-20-2010 06:43 PM
Whirlpool LA5300XM Cold water trickles, warm water flows properly ajaysheetal Washer Repair 2 02-14-2008 04:49 PM
