Discuss
Washer not completing cycle and timer resets
 in
Washer Repair
Hello experts! I have a Frigidaire front load washer that has been giving me tons of problems the last couple
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer not completing cycle and timer resets
  #1 (permalink)
Old 08-09-2017, 07:12 PM
Junior Member
blackcivic96 is on a distinguished road
Question Washer not completing cycle and timer resets
Model Number: FAFW3001LW4   Brand: Frigidaire   Age: 1 - 5 years
Hello experts!
I have a Frigidaire front load washer that has been giving me tons of problems the last couple weeks.
Two weeks ago we noticed the washer leaking a bit, so I took off the front to inspect the drain and the pump and found them clear. Reassembled the machine and all seemed to be working properly, until the next day.
Then it wouldn't complete a cycle, we tried normal which starts at "47" it ran at the most until 20-25 then the timer went back to 47 and stayed there. Checked and the error code was E52 (Bad signal from tacho generator) so I pulled the motor and all tests check out except the resistance on pins 4 & 5 which was around 89 Ohms (acceptable range is 105-130 Ohms). So assuming the motor was bad I ordered a new motor, installed it and same issue continued. Pulled the new motor and it had the same Ohm reading on 4 & 5 pins, so I put the old back in, since readings on all were the same.
Now I was receiving E59 (No tacho signal for 3 seconds), so I ordered a new motor control board and front control panel for good measure.
Installed the new motor control board and it worked! For two loads... Then continued to do the same thing, not even getting near to completing the cycle before resetting.
So then today I replaced the front control and the pump (from an old washer that was a direct replacement) and it is still not working- pump works fine, but the washer is still leaking and doesn't complete a cycle!
So now I have it narrowed down to the door lock, which has tested fine or the bearing on the drum, which spins fine plus the leaks which isn't a major concern (for now), unless it is the cause.
Any thoughts or ideas are appreciated!
Side notes: since the "normal" cycles were not completing we were using the Rinse/Spin (without rinse selected) cycle which worked initially, but now does not. It turns one way half way then stops. And it is still leaking (I installed a drip pan when I installed the new motor- thanks goodness!).
Appreciate any help that can be provided!
Related Models
Frigidaire FAFW3511KB0 WASHER
Frigidaire FAFW3511KR0 WASHER
Frigidaire FAFW3511KW0 WASHER
Frigidaire FAFW3511KW1 WASHER
Frigidaire FAFW3514KA0 WASHER
Frigidaire FAFW3514KA1 WASHER
Frigidaire FAFW3514KN0 WASHER
Frigidaire FAFW3514KN1 WASHER
Frigidaire FAFW3517KA1 WASHER
Frigidaire FAFW3517KB0 WASHER
Frigidaire FAFW3517KB1 WASHER
Frigidaire FAFW3517KN0 WASHER
Frigidaire FAFW3517KN1 WASHER
Frigidaire FAFW3517KR0 WASHER
Frigidaire FAFW3517KR1 WASHER
Frigidaire FAFW3517KT1 WASHER
Frigidaire FAFW3517KW0 WASHER
Frigidaire FAFW3517KW1 WASHER
Frigidaire FAFW3574KA0 FRONT LOAD WASHER
Frigidaire FAFW3574KB0 FRONT LOAD WASHER
Frigidaire FAFW3574KN0 FRONT LOAD WASHER
Frigidaire FAFW3574KR0 WASHER
Frigidaire FAFW3574KW0 FRONT LOAD WASHER
Frigidaire FAFW3577KA0 WASHER
Frigidaire FAFW3577KA1 WASHER
Frigidaire FAFW3577KB0 WASHER
Frigidaire FAFW3577KB1 WASHER
Frigidaire FAFW3577KN0 WASHER
Frigidaire FAFW3577KN1 WASHER
Frigidaire FAFW3577KR0 WASHER
Frigidaire FAFW3577KR1 WASHER
Frigidaire FAFW3577KW0 WASHER
Frigidaire FAFW3577KW1 WASHER
Frigidaire FAFW3801LB0 WASHER
Frigidaire FAFW3801LW0 WASHER
Frigidaire FAFW4011LB0 WASHER
Frigidaire FAFW4011LW0 WASHER
Frigidaire FAFW4221LB0 WASHER
Frigidaire FAFW4221LW0 WASHER
Frigidaire FAH085N1T Frigidaire/air Conditioner
Frigidaire FAH085N1T2 Frigidaire/air Conditioner
Frigidaire FAH085P1T1 Frigidaire/air Conditioner
Frigidaire FAH086J1T1 Frg/room Air Conditioner
Frigidaire FAH086J1T2 Frg/room Air Conditioner
Frigidaire FAH086M1T1 Frigidaire/air Conditioner
Frigidaire FAH086N1T1 Frigidaire/air Conditioner
Frigidaire FAH086R1T1 Frigidaire/air Conditioner
Frigidaire FAH086S1TA ROOM AIR CONDITIONER
Frigidaire FAH086S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH086S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH086S1TB ROOM AIR CONDITIONER
Frigidaire FAH086T1T0 ROOM AIR CONDITIONER
Frigidaire FAH086T1T10 ROOM AIR CONDITIONER
Frigidaire FAH08EJ1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH08EM1T1 Frigidaire/air Conditioner
Frigidaire FAH08EN1T Frigidaire/air Conditioner
Frigidaire FAH08EN1T2 Frigidaire/air Conditioner
Frigidaire FAH08EN1T3 Frigidaire/air Conditioner
Frigidaire FAH08EP1T1 Frigidaire/air Conditioner
Frigidaire FAH08ER1T1 Frigidaire/air Conditioner
Frigidaire FAH08ES1TA ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA11 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA12 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TA13 ROOM AIR CONDITIONER
Frigidaire FAH08ES1TB ROOM AIR CONDITIONER
Frigidaire FAH08ET1T0 ROOM AIR CONDITIONER
Frigidaire FAH08ET1T10 ROOM AIR CONDITIONER
Frigidaire FAH096J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T2 Frg(v0) / Room Air Conditioner
Frigidaire FAH096J2T3 Frigidaire/air Conditioner
Frigidaire FAH096M2T1 Frigidaire/air Conditioner
Frigidaire FAH105N1T Frigidaire/air Conditioner
Frigidaire FAH105N1T2 Frigidaire/air Conditioner
Frigidaire FAH105N2T Frigidaire/air Conditioner
Frigidaire FAH105N2T2 Frigidaire/air Conditioner
Frigidaire FAH105P1T1 Frigidaire/air Conditioner
Frigidaire FAH105P2T1 Frigidaire/air Conditioner
Frigidaire FAH106J1T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J1T2 Frigidaire/air Conditioner
Frigidaire FAH106J2T1 Frg(v0) / Room Air Conditioner
Frigidaire FAH106J2T2 Frigidaire/air Conditioner
Frigidaire FAH106M1T1 Frigidaire/air Conditioner
Frigidaire FAH106M2T1 Frigidaire/air Conditioner
Frigidaire FAH106N1T1 Frigidaire/air Conditioner
Frigidaire FAH106N2T1 Frigidaire/air Conditioner
Frigidaire FAH106R1T1 Frigidaire/air Conditioner
Frigidaire FAH106R2T1 Frigidaire/air Conditioner
Frigidaire FAH106S1TA ROOM AIR CONDITIONER
Frigidaire FAH106S1TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S1TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S1TB ROOM AIR CONDITIONER
Frigidaire FAH106S2TA ROOM AIR CONDITIONER
Frigidaire FAH106S2TA11 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA12 ROOM AIR CONDITIONER
Frigidaire FAH106S2TA13 ROOM AIR CONDITIONER
Frigidaire FAH106S2TB ROOM AIR CONDITIONER
Frigidaire FAH106T1T0 ROOM AIR CONDITIONER
Frigidaire FAH106T1T10 ROOM AIR CONDITIONER
Frigidaire FAH106T2T0 ROOM AIR CONDITIONER
Frigidaire FAH106T2T10 ROOM AIR CONDITIONER
Frigidaire FAH10EJ2T2 Frigidaire/air Conditioner
Frigidaire FAH10EM2T1 Frigidaire/air Conditioner
Frigidaire FAH10EN2T Frigidaire/air Conditioner
Frigidaire FAH10EN2T2 Frigidaire/air Conditioner
Frigidaire FAH10EN2T3 Frigidaire/air Conditioner
Frigidaire FAH10EP2T1 Frigidaire/air Conditioner
Frigidaire FAH10ER2T1 Frigidaire/air Conditioner
Frigidaire FAH10ES2TA ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA11 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA12 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TA13 ROOM AIR CONDITIONER
Frigidaire FAH10ES2TB ROOM AIR CONDITIONER
Frigidaire FAH10ET2T0 ROOM AIR CONDITIONER
Frigidaire FAH10ET2T10 ROOM AIR CONDITIONER
Frigidaire FAH124N2T Frigidaire/air Conditioner
Frigidaire FAH124S1TA ROOM AIR CONDITIONER
Frigidaire FAH124S1TB ROOM AIR CONDITIONER
Frigidaire FAH125N2T Frigidaire/air Conditioner
  #2 (permalink)
Old 08-10-2017, 07:52 PM
Junior Member
Default
After tearing apart the machine again, I found that the "drain filter" was too high within the "Tub to Pump Hose" causing a drainage restriction which stopped the washer from completing the cycle and throwing false positive error codes. Upon lowering and re-assembling there are now no more leaks and the washer works like new!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer restarts on it's own after completing a cycle. J.T.B. Washer Repair 3 03-23-2015 05:30 PM
Washer not completing spin cycle Rlharperpi Washer Repair 0 05-28-2013 09:21 PM
Whirlpool Coin operated washer timer not completing to end. comcaller Washer Repair 0 11-03-2011 01:51 PM
washer not completing cycle chrisgroves123 Washer Repair 1 06-03-2011 05:45 PM
Timer not completing full cycle killermrob83 Dishwasher Repair 0 06-25-2010 04:42 AM
