I actually got this washer for free the person said it wouldn't fill with water. I cleaned the inlet screen fixed that. Ran 1 load it worked great. The next load wouldn't agitate or spin reset the motor then it worked great for another 3 loads. The next time when I pressed the start button it started filling but the fill light flashes and started beeping every 20 seconds or so. It was just filling not agitating. So I put it on drain and drained the water out. Did another motor reset but now it isn't agitating or draining. What could this be? Could it be the motor or a fuse? Please help this is the 3rd washer I have had this year!
