Discuss
Maytag Centennial problems
 in
Washer Repair
I had another post about the calibration, but that has been resolved. the problem is a Maytag Centennial top loader
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Centennial problems
  #1 (permalink)
Old 08-01-2017, 11:44 AM
Junior Member
beezerboy is on a distinguished road
Default Maytag Centennial problems
Brand: Maytag   Age: 1 - 5 years
I had another post about the calibration, but that has been resolved. the problem is a Maytag Centennial top loader thats been acting up. it won't complete a wash cycle without a re-start or an extra spin. when I first did the diagnostic I got F7E1 and F0E5. that put me onto the shift actuator/speed sensor, P/N.... W10006355 as the possible problem. I am looking for test data on the part if available, so if anybody has that I'm interested. my electrical is above average.
I pulled my actuator & cleaned things, checked all wires for breaks & corrosion. put it back together, then I cleared the codes, did the re-set & calibration. the self test cycle seemed to work, and no fault codes at the end. on the initial start with a load, it took a couple tries for the cycle to start. then it seemed to stay on the spin cycles & and then rinse/spin a few times. there were no fault codes when the cycle completed. so, its working but requires intervention. we will run another load today on a different cycle to see if it changes.
when I was checking and cleaning parts there was a bunch of water in the drum. I drained it as best I could, but after the test run, I got another fault code F0E5.... off balance. could that be due to excess water that did not drain?
what do you think...
  #2 (permalink)
Old 08-01-2017, 01:03 PM
Junior Member
Default
OK, ran another load on REGULAR cycle. start and wash were fine but did not drain and spin correctly. repeated drain & spin cycle which repeated several times. eventually the lid unlocked and we pressed cancel. clothes were wetter than usual. there is no fault code
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag centennial kristenhector Washer Repair 0 09-05-2016 09:53 PM
Maytag Centennial tpalibra Washer Repair 0 05-24-2016 09:43 PM
maytag centennial mikeuhn Dryer Repair 1 09-26-2013 06:00 AM
Maytag Centennial Brecia Washer Repair 0 07-16-2013 05:01 PM
Centennial Agitator Problems Dgrega Washer Repair 4 10-12-2011 07:09 PM
