Discuss
Since burned smell, works 5 secs then stops
 in
Washer Repair
I have this old GE top load washer here. I think it's 20 years old. I looked all over it,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Since burned smell, works 5 secs then stops
  #1 (permalink)
Old 07-23-2017, 10:26 AM
Junior Member
TremblayGil is on a distinguished road
Default Since burned smell, works 5 secs then stops
Model Number: N/A   Brand: GE   Age: More than 10 years
I have this old GE top load washer here. I think it's 20 years old. I looked all over it, can't find model #.
Yesterday there was burnt smell and it stopped during rinse. Wouldn't start again. I waited 10-15min, I reset the cycle to rinse, it worked 5 seconds then stopped again. Waiter 10-15mins, did same, worked 5 seconds then stopped.
I opened the back and I see this burned wire and burn marks in the inside of the casing. I don't see anything else wrong in there but I don't know much about these. Here are two pictures of the burned stuff. I have more pictures also if anyone wants.
Any idea if this can be fixed? Thanks!
Related Models
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
Norge N3422PRA RANGE- S/C F/S GAS
Norge N3422PRW RANGE- S/C F/S GAS
Norge N3438SRA RANGE- S/C F/S GAS
Norge N3438SRW RANGE- S/C F/S GAS
Norge N3438VRV RANGE- S/C F/S GAS
Roper N3457*0 Ranges, Electric*
Roper N3457W0 Ranges, Electric*
Norge N3472SRA RANGE- S/C F/S GAS
Norge N3472SRW RANGE- S/C F/S GAS
Norge N3478VRV RANGE- S/C F/S GAS
Norge N3478VVV RANGE- S/C F/S GAS
Norge N3478XRA RANGE- S/C F/S GAS
Norge N3478XRW RANGE- S/C F/S GAS
Norge N3478XVA RANGE- S/C F/S GAS
Norge N3478XVW RANGE- S/C F/S GAS
Norge N3510KRA RANGE- F/S STD ELE
Norge N3510KRW RANGE- F/S STD ELE
Norge N3510PPA RANGE- F/S STD ELE
Norge N3510PPW RANGE- F/S STD ELE
Norge N3510PRA RANGE- F/S STD ELE
Norge N3510PRW RANGE- F/S STD ELE
Norge N3520SPA RANGE- F/S STD ELE
Norge N3520SPN RANGE- F/S STD ELE
Norge N3520SPW RANGE- F/S STD ELE
Norge N3520SRA RANGE- F/S STD ELE
Norge N3520SRW RANGE- F/S STD ELE
Norge N3521XPA RANGE- F/S STD ELE
Norge N3521XPW RANGE- F/S STD ELE
Norge N3521XRA RANGE- F/S STD ELE
Norge N3521XRW RANGE- F/S STD ELE
Norge N3832XRA RANGE- S/C F/S ELE
Norge N3832XRW RANGE- S/C F/S ELE
Norge N3875XRA RANGE- S/C F/S ELE
Norge N3875XRW RANGE- S/C F/S ELE
Norge N3878VRV RANGE- S/C F/S ELE
Norge N3878VVD RANGE- S/C F/S ELE
Norge N3878VVV RANGE- S/C F/S ELE
Norge N3878XRA RANGE- S/C F/S ELE
Norge N3878XRW RANGE- S/C F/S ELE
Norge N3878XVA RANGE- S/C F/S ELE
Norge N3878XVW RANGE- S/C F/S ELE
Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE
Norge N4231WRA RANGE-F/S CONT CLEAN GAS
Norge N4231WRW RANGE-F/S CONT CLEAN GAS
Norge N4251WTA RANGE- F/S STD GAS
Norge N4251WTW RANGE- F/S STD GAS
Roper N9157*0 Ranges, Electric*
Roper N9157*1 Ranges, Electric*
Roper N9157L0 Ranges, Electric*
Roper N9157L1 Ranges, Electric*
Roper N9157X0 Ranges, Electric*
Roper N9257*0 Ranges, Electric*
Roper N9257*1 Ranges, Electric*
Roper N9257*2 Ranges, Electric*
Roper N9257L1 Ranges, Electric*
Roper N9257L2 Ranges, Electric*
Roper N9257X0 Ranges, Electric*
Roper N9257X1 Ranges, Electric*
Roper N9357*0 Ranges, Electric*
Roper N9357*2 ELECTRIC RANGE
Roper N9357*3 Ranges, Electric*
Roper N9357L0 Ranges, Electric*
Roper N9357L2 ELECTRIC RANGE
Roper N9357L3 Ranges, Electric*
Roper N9457*0 Ranges, Electric*
Roper N9457*2 Ranges, Electric*
Roper N9457*3 Ranges, Electric*
Roper N9457*4 Ranges, Electric*
Roper N9457*5 Ranges, Electric*
Roper N9457L3 Ranges, Electric*
Roper N9457X0 Ranges, Electric*
Roper N9457X2 Ranges, Electric*
  #2 (permalink)
Old 07-23-2017, 02:31 PM
Junior Member
Default
Ok with a bit of google, I found that the part the burned orange wire is connected to is the Relay switch, part # on the piece is 144c7366g03 but I found a page where it says part is now WH12M70 and another page that says it's now WG04F04806. See attached.
Is it worthwhile to attempt to replace the relay switch and the burned wire?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Panasonic stops/clears timer after 4 secs artyprice Microwave Repair 0 08-26-2014 04:45 PM
wire burned smell marcoadj Dishwasher Repair 1 05-02-2012 06:39 AM
Cooking stops at 2 min 30 secs every time kycat Microwave Repair 0 12-20-2009 09:50 AM
Microwave Stops After 3 Secs shooter12 Microwave Repair 0 10-03-2009 11:20 AM
Burned rubber smell and scraping noise ccacace Washer Repair 1 04-13-2009 03:55 PM
