Discuss
Kenmore Series 80 Washer
 in
Washer Repair
My Kenmore series 80 washer ceased agitating and spinning in the middle of a load. I have done enough searching
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore Series 80 Washer
  #1 (permalink)
Old 07-20-2017, 02:01 PM
Junior Member
CDESr is on a distinguished road
Default Kenmore Series 80 Washer
Brand: Kenmore   Age: More than 10 years
My Kenmore series 80 washer ceased agitating and spinning in the middle of a load. I have done enough searching to realize that the lid switch is a major culprit with this model. I have bypassed the switch completely, by jumping two wires behind the control panel. The washer will fill with water. which leads me to guess that the timer switch is operational, but this is a guess. If I turn the timer switch to any other cycle other than filling with water, nothing happens. No agitation, no spinning, no draining, and no noise at all. Which leads me to guess that the motor may be dead. Can someone please help me with troubleshooting steps for this model? Thanks!
  #2 (permalink)
Old 07-20-2017, 04:41 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
In order to provide most accurate advice we need the complete model number of the washer.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 07-20-2017, 06:56 PM
Junior Member
Default
110.24832200
  #4 (permalink)
Old 07-22-2017, 05:08 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
You were absolutely right. A faulty lid switch is one of the most common problems with direct drive washers. The situation you described is very strange. I would recommend to order and replace the lid switch first. If it would not fix the problem, you can easily return it.
The lid switch Part number: AP6008880
__________________
  #5 (permalink)
Old 07-23-2017, 02:55 PM
Junior Member
Default
Before I changed out the lid switch, I decided to try to run a full cycle, without a load. to see if it would fully fill with water and run any portion of the cycle. the washer fills and agitates but stops working after about 5 minutes of agitation. So the failure occurs at the beginning of a drain or spin cycle would begin. It seemed that I could manually select an agitation cycle, I just didn't know that the agitation section was so short, and it is also not labeled (which is why i stated in my first post that it would not agitate. I cannot manually select a spin, or drain cycle.
I replaced the lid switch, and all of the same behaviors exist. No change.
This did not surprise me, due to the fact that I had completely bypassed the lid switch by shorting the two switch wires together on the timer side. Yes, I removed my bypass once I installed the new lid switch.
  #6 (permalink)
Old 07-23-2017, 08:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
After your last comments, the problem looks very different.
Would it do anything after you advance the timer manually?
If "Yes" then the problem is a faulty timer.
__________________
  #7 (permalink)
Old 07-24-2017, 03:24 PM
Junior Member
Default
No, the only things it will do is fill and agitate. If I try to manually select or advance the timing switch, it will not spin or drain.
  #8 (permalink)
Old 07-24-2017, 03:42 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
If it would not spin and/or drain even with the new lid switch, very likely the timer has gone bad.
The timer Part number: AP6013028
__________________
  #9 (permalink)
Old 07-28-2017, 09:38 AM
Junior Member
Default
I have replaced the timer, and it is still showing the same symptoms. After changing out the timer, I let it run a full cycle. It fills, agitates and then simply stops working, I cannot manually select any other spin or drain cycles. Ideas? Are there any diagnostic checks or troubleshooting steps that we can take? I'd very much like to test to find the problem rather than just changing out parts to see what happens. Is it possible to return the timer that I purchased, since it is clearly not the problem?
  #10 (permalink)
Old 08-20-2017, 07:24 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Sorry for the delay.
Check how the wires are connected to the drive motor.
If there is nothing wrong, check the drive motor windings for continuity.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 90 series washer givens777 Washer Repair 0 03-06-2014 06:34 AM
kenmore washer 80 series delores Washer Repair 1 01-28-2011 06:00 PM
Kenmore Series 80 Washer barsss Washer Repair 9 12-23-2009 07:23 PM
Kenmore series 90 washer Glen Barclay Washer Repair 7 10-22-2008 12:53 PM
Kenmore Washer 80 Series steamguy456 Washer Repair 0 06-23-2008 01:18 PM
