Discuss
How to replace the washer belts on a Maytag SE1000 or SG1000
 in
Washer Repair
I just replaced the two belts on my stackable Maytag SG1000. (It would be the same procedure for the SE1000).
Appliance Repair Forum > Appliance Repair Help > Washer Repair » How to replace the washer belts on a Maytag SE1000 or SG1000
  #1 (permalink)
Old 07-18-2017, 02:46 PM
Junior Member
AntiPlannedObsolescence is on a distinguished road
Default How to replace the washer belts on a Maytag SE1000 or SG1000
Model Number: SG1000   Brand: Maytag   Age: More than 10 years
The belt kit for that washer is the Whirlpool 12112425 Washer Belt Kit. (Whirlpool owns Maytag) It consists of two belts, one for the agitator, one for the pump. Best to replace both at the same time. It was pretty easy, took 15 minutes. The only tool I needed was a #2 Philips screwdriver.
Remove the two Philips head sheet metal screws on the the front, towards the bottom of the washer. The front panel then tilts up from the bottom and pulls out and down. Notice the metal spring clips that held it in. Put the panel aside.
This is a good time to inspect the inside of the washer. Any rusty spots you want to treat with phosphoric acid? Notice how the motor is spring loaded; it can move towards and away from the axis of the agitator.
Next, lay down on the floor in front of the machine, perpendicular to it, on your right shoulder. You canít see the belts, as they are under the metal deck thatís beneath the motor. Feel around under there and youíll notice the belt to the pump is on the bottom. Itís easy to take off. Move the motor to make slack in the belt to make it easier to remove. Same with the belt to the agitator.
Note that the agitator belt is wider / thicker than the pump belt. Note how the motor pulley has two grooves, one for each belt, and the motor belt groove is wider and at the top.
Put the new belts on. I donít think they have any particular directional needs, but I put them on with the ďMaytagĒ lettering right side up. The agitator belt has to go on first. Again, you can move the motor to create slack, and you can also use your left hand on the agitator axle to move its pulley as you feed the belt onto that pulley from underneath. The pump belt goes on second. It is easy to put on.
With the belts installed, put the front panel back on. Best way to do that is to put the top in place first, noting the slots for the spring clips. Angle the panel in at the top, way out at the bottom. Push it up and in as you swing the bottom back into position. Install the screws and youíre done!
Related Models
Maytag SG1000 STACKED LAUNDRY- GAS
Maytag SG1000T Stacked Laundry - Gas
Hardwick SG1616A49R RANGE- F/S STD GAS
Hardwick SG1616W49R RANGE- F/S STD GAS
Hardwick SG1616Y49R RANGE- F/S STD GAS
Amana SG19SL REF - SXS/I&W
Amana SG19SW REF - SXS/I&W
Amana SG22MBG REF - SXS/I&W
Amana SG22MBL REF - SXS/I&W
Amana SG22MBW REF - SXS/I&W
Amana SG521SBL REF - SXS/I&W
Amana SG521SBW REF - SXS/I&W
Amana SG521SW REF - SXS/I&W
Maytag SG7800 STACKED LAUNDRY- GAS
Hoover SG901---
Hoover SG903---
Hoover SG905---
Hoover SG907---
Hoover SG913---
Hoover SG915---
Hoover SG919---
Hoover SG921001
Hoover SG925
Hardwick SG9612W79RO RANGE- F/S STD GAS
Hardwick SG9617A429R RANGE- F/S STD GAS
Hardwick SG9617W429R RANGE- F/S STD GAS
Maytag SG9900 STACKED LAUNDRY- GAS
Thermador SGC304R
Thermador SGC304RB STEEL BURNER GAS COOKTOPS
Thermador SGC304RS STEEL BURNER GAS COOKTOPS
Roper SGC355XW0 Range (gas)*
Roper SGC355XW1 Range (gas)*
Roper SGC355XX2 Range (gas)*
Roper SGC355XX3 Range (gas)*
Thermador SGC365RB GAS COOKTOP
Thermador SGC365RS GAS COOKTOP
Thermador SGC365RW GAS COOKTOP
Thermador SGC456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RB SN 9803
Thermador SGC456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RS SN 9803
Thermador SGC456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGC456RW SN 9803
Thermador SGCS304RB STEEL BURNER GAS COOKTOPS
Thermador SGCS304RS STEEL BURNER GAS COOKTOPS
Thermador SGCS304RW STEEL BURNER GAS COOKTOPS
Thermador SGCS365RB GAS COOKTOP
Thermador SGCS365RS GAS COOKTOP
Thermador SGCS365RW GAS COOKTOP
Thermador SGCS456RB STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RB SN 9803
Thermador SGCS456RS STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RS SN 9803
Thermador SGCS456RW STEEL GAS COOKTOPS WITH FULL SERVICE GRATES
Thermador SGCS456RW SN 9803
Thermador SGCV36 COOKTOP
Thermador SGCV3601 COOKTOP
Thermador SGCV36G01 COOKTOP
Thermador SGCV36G02 COOKTOP
Amana SGD22TL REF - SXS/I&W
Amana SGD22TW REF - SXS/I&W
Amana SGD26VL REF - SXS/I&W
Amana SGD26VW REF - SXS/I&W
Amana SGD521SBL REF - SXS/I&W
Amana SGD521SBW REF - SXS/I&W
Amana SGD521SW REF - SXS/I&W
Whirlpool SGDS800HQ0 GAS DRYER
Whirlpool SGDS800JQ0 GAS DRYER
Whirlpool SGDS800JQ1 GAS DRYER
Whirlpool SGDS800JQ2 GAS DRYER
Whirlpool SGDS800MQ0 29"GAS DRYER
Whirlpool SGDS800MQ1 29"GAS DRYER
Whirlpool SGDX600HQ0 DRYER
Whirlpool SGDX600JQ0 DRYER
Whirlpool SGDX600JQ1 DRYER
Whirlpool SGDX600JQ2 DRYER
Whirlpool SGDX600MQ0 29"GAS DRYER
Whirlpool SGDX600MQ1 29"GAS DRYER
Frigidaire SGER341AS0 Frigidaire/dryer
Frigidaire SGER341AS1 Frigidaire/electric Dryer
Frigidaire SGGR341AS0 Frigidaire/dryer
Frigidaire SGGR341AS1 Frigidaire/gas Dryer
Frigidaire SGGR341AS2 Frigidaire/gas Dryer
 SGM365 COOKTOP
Thermador SGN30B GAS COOKTOP
Thermador SGN30S GAS COOKTOP
Thermador SGN30W GAS COOKTOP
Thermador SGN36GB GAS COOKTOP
Thermador SGN36GS GAS COOKTOP
Thermador SGN36GW GAS COOKTOP
Thermador SGNCV36GB GAS COOKTOP
Thermador SGNCV36GS GAS COOKTOP
Thermador SGNCV36GW GAS COOKTOP
Roper SGP335XW0 Range (gas)*
Roper SGP335XW1 Range (gas)*
Roper SGP335XX2 Range (gas)*
White Westinghouse SGQ2152HS0 DRYER
White Westinghouse SGQ2152HS1 DRYER
White Westinghouse SGQ2170KS0 DRYER
 SGQ7000FS0 ELECTROLUX/DRYER
White Westinghouse SGR231CQ0 White Westinghouse/dryer
White Westinghouse SGR231CS0 White Westinghouse/dryer
White Westinghouse SGR231HQ0 DRYER
White Westinghouse SGR231HQ1 DRYER
White Westinghouse SGR231HS0 DRYER
White Westinghouse SGR231HS1 DRYER
White Westinghouse SGR341AQ0 Dryer - W.west
White Westinghouse SGR341AQ1 Dryer - West/grupo Gomo
White Westinghouse SGR341AQ2 White Westinghouse/gas Dryer
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag SE1000 stack washer/dryer leaking issue flyin99 Washer Repair 4 07-18-2017 02:47 PM
How to replace the dryer belt on a Maytag SG1000 AntiPlannedObsolescence Dryer Repair 0 07-16-2017 07:59 AM
Maytag washer spins, won't drain: new pump, belts sellersm Washer Repair 0 06-21-2013 01:46 PM
Maytag washer - replace belts or pump? mzpatti Dishwasher Repair 1 06-20-2013 08:08 PM
***Maytag SG1000 (or SE1000) won't go past spin cycle PLEASE HELP*** canderousa Washer Repair 1 05-02-2013 09:11 AM
