Discuss
Kitchen Aid Washer Won't agitate or spin
 in
Washer Repair
Kitchen Aid washer made by Whirlpool, model KAWS700G. A couple months ago, the rubber and plastic coupling between the motor
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kitchen Aid Washer Won't agitate or spin
  #1 (permalink)
Old 07-18-2017, 08:00 AM
Junior Member
M Yaworski is on a distinguished road
Default Kitchen Aid Washer Won't agitate or spin
Model Number: KAWS700G   Brand: Kitchen Aid   Age: More than 10 years
ago, the rubber and plastic coupling between the motor and transmission
broke. That was a fairly easy fix.
New problem this time. Last week I was doing a load of towels and while
I was standing there the timer quit turning and made a loud humming sound.
I took the timer out and sprayed it out with contact cleaner but that
didn't help.
I went to the local parts store and bought a new genuine Whirlpool
replacement timer. I installed the timer and it hummed loudly like the other
one but the knob moved around for a couple minutes and then it stopped and
the hum went away.
I turned the knob around to spin again (spin so the machine wouldn't
fill with water). Nothing. No hum. No movement.
Before I make the trek back to the parts store, is it likely that I got a
bad replacement timer?
Any other likely points of failure?
Thanks.
I'm not an expert or I wouldn't be here asking, but I am fairly competent with tools and not afraid to tackle repairs.
Thanks again.
Related Models
Whirlpool KAWS700GQ0 AUTOMATIC WASHER
Whirlpool KAWS700GT0 AUTOMATIC WASHER
Whirlpool KAWS700GZ0 AUTOMATIC WASHER
Whirlpool KAWS700JQ0 RESIDENTIAL WASHER
Whirlpool KAWS700JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ3 RESIDENTIAL WASHER
Whirlpool KAWS700JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS700JT0 RESIDENTIAL WASHER
Whirlpool KAWS700JT1 RESIDENTIAL WASHERS
Whirlpool KAWS700JT2 RESIDENTIAL WASHERS
Whirlpool KAWS700JT3 RESIDENTIAL WASHER
Whirlpool KAWS700JT4 RESIDENTIAL WASHERS
Whirlpool KAWS700LQ0 RESIDENTIAL WASHERS
Whirlpool KAWS700LT0 RESIDENTIAL WASHERS
Whirlpool KAWS750GQ0 AUTOMATIC WASHER
Whirlpool KAWS750GQ1 AUTOMATIC WASHER
Whirlpool KAWS750GT1 AUTOMATIC WASHER
Whirlpool KAWS750GZ0 AUTOMATIC WASHER
Whirlpool KAWS750GZ1 AUTOMATIC WASHER
Whirlpool KAWS750JQ0 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ3 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS750JT0 RESIDENTIAL WASHERS
Whirlpool KAWS750JT1 RESIDENTIAL WASHERS
Whirlpool KAWS750JT2 RESIDENTIAL WASHERS
Whirlpool KAWS750JT3 RESIDENTIAL WASHERS
Whirlpool KAWS750JT4 RESIDENTIAL WASHERS
Whirlpool KAWS750LQ0 AUTOMATIC WASHER
Whirlpool KAWS750LQ1 AUTOMATIC WASHER
Whirlpool KAWS750LQ2 AUTOMATIC WASHER
Whirlpool KAWS750LQ3 AUTOMATIC WASHER
Whirlpool KAWS750LQ4 AUTOMATIC WASHER
Whirlpool KAWS750LT0 AUTOMATIC WASHER
Whirlpool KAWS750LT1 AUTOMATIC WASHER
Whirlpool KAWS750LT2 AUTOMATIC WASHER
Whirlpool KAWS750LT3 AUTOMATIC WASHER
Whirlpool KAWS750LT4 AUTOMATIC WASHER
Whirlpool KAWS777EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS777EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS800GQ0 AUTOMATIC WASHER
Whirlpool KAWS800GQ1 AUTOMATIC WASHER
Whirlpool KAWS800GZ0 AUTOMATIC WASHER
Whirlpool KAWS800GZ1 AUTOMATIC WASHER
Whirlpool KAWS850GQ0 AUTOMATIC WASHER
Whirlpool KAWS850GQ1 AUTOMATIC WASHER
Whirlpool KAWS850GT0 AUTOMATIC WASHER
Whirlpool KAWS850GT1 AUTOMATIC WASHER
Whirlpool KAWS850GZ0 AUTOMATIC WASHER
Whirlpool KAWS850GZ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ0 AUTOMATIC WASHER
Whirlpool KAWS850JQ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ2 AUTOMATIC WASHER
Whirlpool KAWS850JQ3 AUTOMATIC WASHER
Whirlpool KAWS850JQ4 AUTOMATIC WASHER
Whirlpool KAWS850JT0 AUTOMATIC WASHER
Whirlpool KAWS850JT1 AUTOMATIC WASHER
Whirlpool KAWS850JT2 AUTOMATIC WASHER
Whirlpool KAWS850JT3 AUTOMATIC WASHER
Whirlpool KAWS850JT4 AUTOMATIC WASHER
Whirlpool KAWS850LE0 AUTOMATIC WASHER
Whirlpool KAWS850LE1 AUTOMATIC WASHER
Whirlpool KAWS850LE2 AUTOMATIC WASHER
Whirlpool KAWS850LQ0 AUTOMATIC WASHER
Whirlpool KAWS850LQ1 AUTOMATIC WASHER
Whirlpool KAWS850LQ2 AUTOMATIC WASHER
Whirlpool KAWS850LT0 AUTOMATIC WASHER
Whirlpool KAWS850LT1 AUTOMATIC WASHER
Whirlpool KAWS850LT2 AUTOMATIC WASHER
Whirlpool KAWS855JE0 WASHER
Whirlpool KAWS855JE1 WASHER
Whirlpool KAWS855JE2 WASHER
Whirlpool KAWS855JE3 WASHER
Whirlpool KAWS855JE4 WASHER
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 QT. STAND MIXER
Whirlpool KB26G1XAC3 6 QT. STAND MIXER
Whirlpool KB26G1XAC5 6 QT. STAND MIXER
Whirlpool KB26G1XBU3 6 QT. STAND MIXER
Whirlpool KB26G1XBU5 6 QT. STAND MIXER
Whirlpool KB26G1XER3 6 QT. STAND MIXER
Whirlpool KB26G1XER5 6 QT. STAND MIXER
Whirlpool KB26G1XGN3 6 QT. STAND MIXER
Whirlpool KB26G1XGR3 6 QT. STAND MIXER
Whirlpool KB26G1XGR5 6 QT. STAND MIXER
Whirlpool KB26G1XMC3 6 QT. STAND MIXER
Whirlpool KB26G1XMC5 6 QT. STAND MIXER
Whirlpool KB26G1XMY3 6 QT. STAND MIXER
Whirlpool KB26G1XMY5 6 QT. STAND MIXER
Whirlpool KB26G1XOB3 6 QT. STAND MIXER
Whirlpool KB26G1XOB5 6 QT. STAND MIXER
Whirlpool KB26G1XPT3 6 QT. STAND MIXER
Whirlpool KB26G1XPT5 6 QT. STAND MIXER
Whirlpool KB26G1XTG3 6 QT. STAND MIXER
Whirlpool KB26G1XTG5 6 QT. STAND MIXER
Whirlpool KB26G1XWW3 6 QT. STAND MIXER
Whirlpool KB26G1XWW5 6 QT. STAND MIXER
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
  #2 (permalink)
Old 07-18-2017, 11:29 AM
Senior Member
brobriffin is on a distinguished road
Default
where do you hear the humming noise coming from, is it in the control head with the timer or could it be coming from lower inside the case?
  #3 (permalink)
Old 07-18-2017, 11:44 AM
Junior Member
Default
Quote:
It seems to be from the control panel. I'm thinking that anything could hum that would be lower down would be way at the bottom where the motor is.
Before you ask, the fill valve seems to be working fine.
  #4 (permalink)
Old 07-18-2017, 02:14 PM
Senior Member
Default
Just for fun have you tried running an agitation cycle.
1. If so, I am sure it fills with water as you said water valve work fine, but does it agitate?
2. If it does and you let it advance to drain and spin does it drain or spin?
  #5 (permalink)
Old 07-18-2017, 03:14 PM
Junior Member
Default
Okay, I just did what you suggested. I found out that I was wrong. The timer is advancing. I can hear the timer motor running with my ear right next to it but the loud hum that I mentioned earlier is gone. Interesting.
The timer advances but other than fill, nothing else happens. No agitation, no drain, no spin. Now I have a washer half filled with water :-(
The lights in the laundry are on the same circuit as the washer's outlet and when I pull the knob out (or push it in, don't recall which it requires) to turn it on, the lights dim a bit.
To me that says that something is pulling quite a bit of current.
Thanks for your help so far.
  #6 (permalink)
Old 07-18-2017, 03:28 PM
Senior Member
Default
With the humming sound and what else you explained I suspect the start/run capacitor might be bad.
This is a very cheap thing to replace. Unless you have a digital multi-meter to check how many microfarads your capacitor has I would suggest replacing it and see if there is a change.
This is the part number you need. WP8572720
  #7 (permalink)
Old 07-18-2017, 07:51 PM
Junior Member
Default
My DMM does not do capacitance :-( I never thought that I'd need that function. I guess that I was wrong.
I'll order one and give that a shot.
Thanks.
  #8 (permalink)
Old 07-19-2017, 11:44 AM
Junior Member
Default
I looked up how to test a capacitor with a DMM. It said to put my meter across it set for resistance and the reading should start at zero and go up.
I pulled the cap from my washer. It doesn't look or smell blown.
Following the directions that I found online, I put the DMM's probes onto the terminals of the capacitor. The reading jumps to 3.5 megohm almost immediately and then continues to go up slowly.
Still think that it might be the capacitor? I've replaced capacitors in a couple fans and those looked swollen and burnt.
I don't want to order a $40 capacitor and find out that wasn't the problem.
Thanks.
  #9 (permalink)
Old 07-19-2017, 12:15 PM
Senior Member
Default
Over time and use they tend to lose their capacitance. A capacitor can still work but not be the correct capacitance. This one should be between 324 to 389 f (microfarads). If it is significantly less this will cause the motor to humm and not start or run.
  #10 (permalink)
Old 07-19-2017, 12:17 PM
Senior Member
Default
Perhaps you have a friend, or relative that has a meter to check it out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kitchen Aid turns on but will not agitate or spin LTuttle Washer Repair 4 07-24-2017 05:45 PM
Kitchen Aid Washer will not spin HiLife Dishwasher Repair 5 12-17-2012 10:03 AM
Kitchen Aid Washer won't spin silver1 Washer Repair 1 02-12-2012 05:42 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Kitchen Aid Washer Does not spin Guy Gerrard Washer Repair 13 02-11-2009 06:11 AM
