Discuss
Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves
 in
Washer Repair
Hi, I hope someone can help me, I have read through the washer theads and can't find a thread with
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves
  #1 (permalink)
Old 07-18-2017, 06:57 AM
Junior Member
Girliemom21 is on a distinguished road
Default Whirlpool top load washer, wtw4800bq0, agitator bolt loose, and bottom moves
Model Number: Wtw4800bq0   Brand: Whirlpool   Age: 1 - 5 years
I hope someone can help me, I have read through the washer theads and can't find a thread with exact problems I am having. I hope someone can help me
Figure this out, as I'm wife trying to figure out the problem and fix. Washer History:bought for a rental company used , seemed to be working ok when I bought it.
Problem 1 - clothes not coming clean even after running another wash cycle
With a 2nd rinse. The time for the whole wash seems like it's taking longer and longer to completed over any hour in on normal wash cycle and casual set to light, but with 2nd rinse. It used to take less than an hour.
We have very soft water, the tins cycles only fill water just as beginning of wash,on regular and softener rinses, no spray as the owners manual says. The tub is. It moving while the water is filling in any of the rinses. After it fills for rinse it will agitate on first rinse. On 2nd rinse it will fill a couple of inches. No tub movement, then start draining then spin out.
Problem 2 - I have checked dogs, only moves one way, the bottom of agitator moves with a muscle push both ways and independent of the tub. I can spin the tub both ways too. The nut in agitator keeps coming loose:
I have pulled the agitator off,the splines look fine under bottom of agitator. I tried to move shaft with hand and won't move, but with agitator on and I push in bottom of agitator with some muscle (not like a finger) the agitator can be spun both ways. You can feel it moving the motor, and hear it. When moving the bottom agitator it moves separate from the tub. I can't get it tightened enough to make agitator not move at all: I have taken the agitator off 3 times. First 2 times lots of grease on transmission shaft splines and wet. But the cap under softener cup wasn't sealing. I cleaned cap took o ring off and put some dish soap on it to seal. Sealed and cap stayed. After 2nd time taking agitator off my my husband hand righted nut a little tighter than I tighted it. So I check agitator yesterday and seemed loose too off cap got wrench to see if nut was tight, and it was loose, like if I could of got my hand in there I Wouldn't need a wrench to u screw it.
When I try to raise agitator to see if loose while bolted in it had some play and makes A loud "knocking" metal hitting something noise. Just lifting it straight up?
Problem 3 - I have got tech book out and ran fault code errors test.
Will you get a fault code when your electricity is surging
For like an hour and the washer was on?
I got motor fault error: is this from a surge because it won't come back up.
Problem 4- no warm water
I have to run wash in to which this washer won't let you have straight got. Our hot water heater is set amlittler hotter than normal so running washer on hot is only way to get any warm water.
Why when I clean in "clean washer mode" it will put straight hot water?, and even in rinse? I got hot water to hot in rinse code last time I ran cleaning cycle. The inlet has been cleaned me checked by my husband. But it take 10-15 min to fill washer depending if on cold or set to hot. On large load: if I run on
Cold Tap water only this will seam like washer takes 2 hours. We have new plumbing so that is not the issue.
If anyone could please help me, I would greatly appreciate your help to figure out what is wrong. Our local appliance part store thought it was the trans and said this washer was only built to last 5 yrs, I find hard to believe. I specifically bought this washer so I can tell it How much and how hot water to put in the wash and rinses with more than a he washer.
Thank you in advance for your help!
Shelly
Related Models
Whirlpool WTW4800XQ0 AUTOMATIC WASHER
Whirlpool WTW4800XQ1 AUTOMATIC WASHER
Whirlpool WTW4800XQ2 AUTOMATIC WASHER
Whirlpool WTW4820XQ0 AUTOMATIC WASHER
Whirlpool WTW4850XQ0 WASHER
Whirlpool WTW4910XQ0 AUTOMATIC WASHER
Whirlpool WTW4910XQ1 AUTOMATIC WASHER
Whirlpool WTW4930XW0 AUTOMATIC WASHER
Whirlpool WTW4930XW1 WASHER
Whirlpool WTW4950XW0 AUTOMATIC WASHER
Whirlpool WTW4950XW1 AUTOMATIC WASHER
Whirlpool WTW4950XW2 WASHER
Whirlpool WTW5100SQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ0 AUTOMATIC WASHER
Whirlpool WTW5100VQ1 AUTOMATIC WASHER
Whirlpool WTW5100VQ2 AUTOMATIC WASHER
Whirlpool WTW5200SQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ0 AUTOMATIC WASHER
Whirlpool WTW5200VQ1 AUTOMATIC WASHER
Whirlpool WTW5200VQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ0 AUTOMATIC WASHER
Whirlpool WTW5300SQ2 AUTOMATIC WASHER
Whirlpool WTW5300SQ3 AUTOMATIC WASHER
Whirlpool WTW5300VW0 AUTOMATIC WASHER
Whirlpool WTW5300VW1 AUTOMATIC WASHER
Whirlpool WTW5300VW2 AUTOMATIC WASHER
Whirlpool WTW5300VW3 AUTOMATIC WASHER
Whirlpool WTW5310SQ0 AUTOMATIC WASHER
Whirlpool WTW5310VQ0 AUTOMATIC WASHER
Whirlpool WTW5320SQ0 AUTOMATIC WASHER
Whirlpool WTW5321SQ0 AUTOMATIC WASHER
Whirlpool WTW5400TQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ0 AUTOMATIC WASHER
Whirlpool WTW5500SQ2 AUTOMATIC WASHER
Whirlpool WTW5500ST0 AUTOMATIC WASHER
Whirlpool WTW5500ST2 AUTOMATIC WASHER
Whirlpool WTW5500XL0 AUTOMATIC WASHER
Whirlpool WTW5500XL1 AUTOMATIC WASHER
Whirlpool WTW5500XL2 WASHER
Whirlpool WTW5500XW0 AUTOMATIC WASHER
Whirlpool WTW5500XW1 AUTOMATIC WASHER
Whirlpool WTW5500XW2 WASHER
Whirlpool WTW5505SQ0 AUTOMATIC WASHER
Whirlpool WTW5505SQ1 AUTOMATIC WASHER
Whirlpool WTW5505VQ0 AUTOMATIC WASHER
Whirlpool WTW5505VQ1 AUTOMATIC WASHER
Whirlpool WTW5510VQ0 AUTOMATIC WASHER
Whirlpool WTW5520SQ0 AUTOMATIC WASHER
Whirlpool WTW5521SQ0 AUTOMATIC WASHER
Whirlpool WTW5530SQ0 AUTOMATIC WASHER
Whirlpool WTW5540SQ0 AUTOMATIC WASHER
Whirlpool WTW5540ST0 AUTOMATIC WASHER
Whirlpool WTW5550SQ0 AUTOMATIC WASHER
Whirlpool WTW5550ST0 AUTOMATIC WASHER
Whirlpool WTW5550XW0 AUTOMATIC WASHER
Whirlpool WTW5550XW1 AUTOMATIC WASHER
Whirlpool WTW5550XW2 WASHER
Whirlpool WTW5560SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ0 AUTOMATIC WASHER
Whirlpool WTW5590SQ2 AUTOMATIC WASHER
Whirlpool WTW5590ST0 AUTOMATIC WASHER
Whirlpool WTW5590ST2 AUTOMATIC WASHER
Whirlpool WTW5590VQ0 AUTOMATIC WASHER
Whirlpool WTW5590VQ1 AUTOMATIC WASHER
Whirlpool WTW5600SQ0 AUTOMATIC WASHER
Whirlpool WTW5600VQ0 AUTOMATIC WASHER
Whirlpool WTW5600XW0 AUTOMATIC WASHER
Whirlpool WTW5600XW1 AUTOMATIC WASHER
Whirlpool WTW5600XW2 WASHER
Whirlpool WTW5610XW0 AUTOMATIC WASHER
Whirlpool WTW5610XW1 AUTOMATIC WASHER
Whirlpool WTW5610XW2 WASHER
Whirlpool WTW5640XW0 AUTOMATIC WASHER
Whirlpool WTW5640XW1 AUTOMATIC WASHER
Whirlpool WTW5640XW2 WASHER
Whirlpool WTW5700SW0 AUTOMATIC WASHER
Whirlpool WTW5700XL0 AUTOMATIC WASHER
Whirlpool WTW5700XL1 AUTOMATIC WASHER
Whirlpool WTW5700XL2 WASHER
Whirlpool WTW5700XW0 AUTOMATIC WASHER
Whirlpool WTW5700XW1 AUTOMATIC WASHER
Whirlpool WTW5700XW2 WASHER
Whirlpool WTW5790SQ0 AUTOMATIC WASHER
Whirlpool WTW5790SQ2 AUTOMATIC WASHER
Whirlpool WTW5790ST0 AUTOMATIC WASHER
Whirlpool WTW5790ST2 AUTOMATIC WASHER
Whirlpool WTW5790VQ0 AUTOMATIC WASHER
Whirlpool WTW5790VQ1 AUTOMATIC WASHER
Whirlpool WTW5790VQ2 AUTOMATIC WASHER
Whirlpool WTW57ESVH0 AUTOMATIC WASHER
Whirlpool WTW57ESVH1 AUTOMATIC WASHER
Whirlpool WTW57ESVW0 AUTOMATIC WASHER
Whirlpool WTW57ESVW1 AUTOMATIC WASHER
Whirlpool WTW5800SG0 AUTOMATIC WASHER
Whirlpool WTW5800SW0 AUTOMATIC WASHER
Whirlpool WTW5810SW0 AUTOMATIC WASHER
Whirlpool WTW5820SW0 AUTOMATIC WASHER
Whirlpool WTW5821SW0 AUTOMATIC WASHER
Whirlpool WTW5830SW0 AUTOMATIC WASHER
Whirlpool WTW5840SG0 AUTOMATIC WASHER
Whirlpool WTW5840SW0 AUTOMATIC WASHER
Whirlpool WTW5850SG0 AUTOMATIC WASHER
Whirlpool WTW5850SW0 AUTOMATIC WASHER
Whirlpool WTW5860SG0 AUTOMATIC WASHER
Whirlpool WTW5860SW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW0 AUTOMATIC WASHER
Whirlpool WTW58ESVW1 AUTOMATIC WASHER
Whirlpool WTW5900SB0 AUTOMATIC WASHER
Whirlpool WTW5900SW0 AUTOMATIC WASHER
Whirlpool WTW5900TB0 AUTOMATIC WASHER
Whirlpool WTW5900TW0 AUTOMATIC WASHER
Whirlpool WTW6200SW0 AUTOMATIC WASHER
Whirlpool WTW6200SW1 AUTOMATIC WASHER
Whirlpool WTW6200SW2 AUTOMATIC WASHER
Whirlpool WTW6200SW3 AUTOMATIC WASHER
Whirlpool WTW6200VW0 AUTOMATIC WASHER
Whirlpool WTW6200VW1 AUTOMATIC WASHER
Whirlpool WTW6300SB0 AUTOMATIC WASHER
Whirlpool WTW6300SB1 AUTOMATIC WASHER
Whirlpool WTW6300SB2 AUTOMATIC WASHER
  #2 (permalink)
Old 07-18-2017, 09:19 PM
Junior Member
Question
I spoke to Gloria on your customer sevice line to to get a price in new agitator bolt and washer. I told her the issues I was having and the computer told her I needed a new agitator, transmission and Inlet valve. Those parts cost as mich as a new barely any water used toploader. I have the model I have because our water is soft with minerals. I have to have extra water in my wash. That is the reason I'm trying to figure out what's wrong, as I plan on keeping this washer a long time.
Today I checked the bottom of agitator, it still moved back and forth with muscle, not a light finger push. I checked the bolt, it was still very tight. I then ran diagnostics and no fault codes. I ran automatic test mode with rinse set to 2nd w/o softener, with the lid open so I can see exactly what is going on. It agitates fine. Lots I've movement and clothes going top to bottom, then drained, then spun. Then Water and the tub would turn on and off reall quick to spin tub slowly to get the clothes wet. The water ran to less than a minute. Then it spun out all water, then started filling again only to bottom of fins in bottom agitator, then spun that water out. This washer states it "SPRAYS" on rinse without softener. There is not spraying about it. This is not an Energy star nor a HE washer. So why won't it use more water to rinse out a load?
Is there a sensor for the rinse cycle based on weight like an he top load? The 2nd rinse on Softener only fills about 3 inches. I find the 2nd rinse either way to be useless.
After this Automatic test mode I then checked to bottom of the agitator to see if still spinning. Nope, tight as can be doesn't budge separate from the tub after I run a test mode. But as soon as I wash a load the agitator is back moving back and forth, what is causing this. Is the agitator supposed to move back and forth separate from the tub?
I apologize for all the questions, the local guy I think is just trying to sell me
A Front loader that I dont want or need. I found this forum and saw pope were actually getting answers to questions and issues, not a person reading a tech shear and saying you need this. That the people really want to help, and try to check other things that could be causing issues, ect. I just need help u derstanding this washer. Thank you again for anyone's help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Agitator bolt comes loose squibel1965 Washer Repair 1 01-29-2015 05:16 PM
Upper Agitator moves slow and loose Bjarki Washer Repair 1 02-15-2011 11:24 AM
Whirlpool agitator hardly moves pamelaleeson Washer Repair 8 02-11-2010 09:38 PM
Whirlpool washer not agitating or spinning. Top part of agitator is also very loose jennifer johns Dishwasher Repair 0 02-06-2010 06:47 AM
Whirlpool agitator hardly moves pamelaleeson Washer Repair 1 07-25-2009 06:00 PM
