Hi All, I have read the issues with the F1E8 codes. The problem I have is the washer fills okay and drains some. I start a load of wash and about 10 min into the load I go back and check the unit is flashing the F1E8 and the water in the tub is half full on the door. I tried to cancel by shutting the power button off but until I would touch the the three buttons in sequence three times "Wash Temp" "Spin" and "Soil" Then I would be able to touch the power button. The code would go away and the unit would drain. Start the wash cycle again and the same thing would happen. Need help.:)
