Discuss
Water will not fill unless selector is in between settings
 in
Washer Repair
Hello, I hope someone can help. My Kenmore washer will not fill unless the water level selector switch is held
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Water will not fill unless selector is in between settings
  #1 (permalink)
Old 07-07-2017, 12:25 PM
Junior Member
Dirka is on a distinguished road
Default Water will not fill unless selector is in between settings
Model Number: 11027542600   Brand: Kenmore   Age: 5 - 10 years
Hello, I hope someone can help. My Kenmore washer will not fill unless the water level selector switch is held between the med and large setting.
Also, when setting the cycle selector, once you pull out the knob, the drum immediately starts to agitate.
Both of these symptoms lead me to the water level switch being bad or stuck. Is that the first thing I should check?
If yes, what is the easiest way to determine if it is bad, other than the symptoms above of course. LOL
Thanks!
Related Models
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
Kenmore 11027871600 RESIDENTIAL WASHERS
Kenmore 11027872600 RESIDENTIAL WASHERS
Kenmore 11027874600 RESIDENTIAL WASHERS
Kenmore 11027892790 AUTOMATIC WASHER
Kenmore 11027892791 AUTOMATIC WASHER
Kenmore 11027894790 AUTOMATIC WASHER
Kenmore 11027894791 AUTOMATIC WASHER
Kenmore 11027902790 AUTOMATIC WASHER
Kenmore 11027982790 AUTOMATIC WASHER
Kenmore 11028002010 AUTOMATIC WASHER
Kenmore 11028002011 AUTOMATIC WASHER
Kenmore 11028012010 AUTOMATIC WASHER
Kenmore 11028012011 AUTOMATIC WASHER
Kenmore 11028032700 RESIDENTIAL WASHER
Kenmore 11028032701 RESIDENTIAL WASHER
Kenmore 11028042700 RESIDENTIAL WASHER
Kenmore 11028042701 WASHER
Kenmore 11028062800 RESIDENTIAL WASHER
Kenmore 11028072800 RESIDENTIAL WASHER
Kenmore 11028081700 WASHER
Kenmore 11028082700 RESIDENTIAL WASHER
Kenmore 11028087700 RESIDENTIAL WASHER
Kenmore 11028091700 WASHER
Kenmore 11028092700 RESIDENTIAL WASHER
Kenmore 11028097700 WASHER
Kenmore 11028222700 RESIDENTIAL WASHER
Kenmore 11028222701 WASHER
Kenmore 11028299890 AUTOMATIC WASHER
Kenmore 11028322700 RESIDENTIAL WASHER
Kenmore 11028332700 RESIDENTIAL WASHER
Kenmore 11028352700 RESIDENTIAL WASHER
Kenmore 11028362700 RESIDENTIAL WASHER
Kenmore 11028372700 RESIDENTIAL WASHER
Kenmore 11028422700 RESIDENTIAL WASHER
Kenmore 11028432700 RESIDENTIAL WASHER
Kenmore 11028522700 RESIDENTIAL WASHER
Kenmore 11028522701 RESIDENTIAL WASHER
Kenmore 11028532700 RESIDENTIAL WASHER
Kenmore 11028532701 RESIDENTIAL WASHER
Kenmore 11028622700 RESIDENTIAL WASHER
Kenmore 11028622701 RESIDENTIAL WASHER
Kenmore 11028632700 RESIDENTIAL WASHER
Kenmore 11028632701 RESIDENTIAL WASHER
Kenmore 11028692700 RESIDENTIAL WASHER
Kenmore 11028692701 RESIDENTIAL WASHER
Kenmore 1102870090 AUTOMATIC WASHER
Kenmore 11028722700 RESIDENTIAL WASHER
Kenmore 11028732700 RESIDENTIAL WASHER
Kenmore 11028752700 RESIDENTIAL WASHER
Kenmore 11028762700 RESIDENTIAL WASHER
Kenmore 11028782700 RESIDENTIAL WASHER
Kenmore 11028802890 AUTOMATIC WASHER
Kenmore 11028803890 AUTOMATIC WASHER
Kenmore 11028812790 AUTOMATIC WASHER
Kenmore 11028822790 AUTOMATIC WASHER
Kenmore 11028822791 AUTOMATIC WASHER
Kenmore 11028824790 AUTOMATIC WASHER
Kenmore 11028824791 AUTOMATIC WASHER
Kenmore 11028832700 RESIDENTIAL WASHER
Kenmore 11028837700 RESIDENTIAL WASHER
Kenmore 11028842700 RESIDENTIAL WASHER
Kenmore 11028847700 RESIDENTIAL WASHER
Kenmore 11028872890 AUTOMATIC WASHER
Kenmore 11028872891 AUTOMATIC WASHER
Kenmore 11028874890 AUTOMATIC WASHER
Kenmore 11028874891 AUTOMATIC WASHER
Kenmore 11028882790 AUTOMATIC WASHER
Kenmore 11028882791 AUTOMATIC WASHER
Kenmore 11028884790 AUTOMATIC WASHER
Kenmore 11028884791 AUTOMATIC WASHER
Kenmore 11028892790 AUTOMATIC WASHER
Kenmore 11028892791 AUTOMATIC WASHER
Kenmore 11028894790 AUTOMATIC WASHER
Kenmore 11028894791 AUTOMATIC WASHER
Kenmore 11028902790 AUTOMATIC WASHER
Kenmore 11028902791 AUTOMATIC WASHER
Kenmore 11028912790 AUTOMATIC WASHER
Kenmore 11028912791 AUTOMATIC WASHER
Kenmore 11028922790 AUTOMATIC WASHER
Kenmore 11028922791 AUTOMATIC WASHER
Kenmore 11028924790 AUTOMATIC WASHER
Kenmore 11028924791 AUTOMATIC WASHER
Kenmore 11028932790 AUTOMATIC WASHER
Kenmore 11028932791 AUTOMATIC WASHER
Kenmore 11028934790 AUTOMATIC WASHER
Kenmore 11028934791 AUTOMATIC WASHER
Kenmore 11028942890 Residential Washers
Kenmore 11028942891 AUTOMATIC WASHER
Kenmore 11028944890 Residential Washers
Kenmore 11028944891 AUTOMATIC WASHER
Kenmore 11028972890 AUTOMATIC WASHER
Kenmore 11028972891 AUTOMATIC WASHER
Kenmore 11028974890 AUTOMATIC WASHER
Kenmore 11028974891 AUTOMATIC WASHER
Kenmore 11029012990 COMMERICAL AUTOMATIC WASHER
Kenmore 11029032990 COMMERCIAL AUTOMATIC WASHER
  #2 (permalink)
Old 07-07-2017, 10:51 PM
Senior Member
PNWDrew is on a distinguished road
Default
Whirlpool W10337781 Switch-Wl - AppliancePartsPros.com Whirlpool changed this switch due to failures, and the new one comes with a hose, use it.
All signs point to a bad switch and I'd change that pressure switch ASAP as it is the sole water level control for your washer. It can and will flood your house if it malfunctions in a bad way.
If it is satisfied the timer is powered and agitation begins. If it is dry agitating at any point (other than a specific test spot at end of wash cycle on dial) there is really little else it could be.
There is a much less likely possibility but it's worth checking - You can check the hose that connects to it by blowing into the hose, if you can't hear air exit down below into the tub it is clogged and that is your issue. The console flips back by releasing the metal clips at the corners with a putty knife of similar object. That'll give you access to the switch end of the hose.
You can access the bottom end of the hose by leaning the machine back or removing the cabinet.
  #3 (permalink)
Old 07-08-2017, 12:16 PM
Junior Member
Default
Thanks for the confirmation, I will get that switch and hopefully will take care of it. I will post back once I swap if it is a fix or not.
  #4 (permalink)
Old 07-14-2017, 08:16 AM
Junior Member
Default Fixed!
Got the part from the link above and all is now working as it should. Thanks for the quick help, I really appreciate it!
  #5 (permalink)
Old 07-14-2017, 08:32 AM
Senior Member
Default
Good news!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer won't fill on rinse cycle unless between 2 settings jkaszer Washer Repair 7 06-06-2013 10:31 AM
Water level selector dial stripped Paul Briant Washer Repair 1 05-28-2013 05:30 AM
works on timed settings but not on automatic settings SP-5000 Dryer Repair 0 04-14-2013 12:08 PM
Water is not the temperature that temp selector indicates. OnTrack Washer Repair 2 08-30-2012 06:47 PM
Cold water in warm water settings Douglas Doty Washer Repair 1 06-03-2008 10:12 AM
