Discuss
Cabrio washer rotator
 in
Washer Repair
I have a whirlpool cabrio platinum washer. (Not sure how old) The bolt on the bottom of the rotator keeps
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Cabrio washer rotator
  #1 (permalink)
Old 07-07-2017, 10:09 AM
Junior Member
Jspeagle is on a distinguished road
Default Cabrio washer rotator
Brand: Whirlpool   Age: 1 - 5 years
I have a whirlpool cabrio platinum washer. (Not sure how old) The bolt on the bottom of the rotator keeps coming loose and causing an f51 error. I tip the washer back tighten the bolt and it will run a few (small loads) loads before I have to tighten it again. Larger loads seem to cause this more frequently.
My question is: do you know what is causing the bolt to come loose and Can I put lock tight on that bolt to make it stay in place or will that cause permenant damage to the rotator or cause it to not work properly.
  #2 (permalink)
Old 07-07-2017, 10:00 PM
Senior Member
PNWDrew is on a distinguished road
Default
Do you mean the allen key bolt that holds the rotor onto the shaft? Looks like this?
Whirlpool 280146 Motor Rotor - AppliancePartsPros.com
You can try loctite on that allen bolt, but I've always just tightened them down and not needed it. It repeatedly coming loose isn't good. Perhaps the inner splines on the rotor are damaged and it is wobbling, that's my guess. Pull the whole rotor down and examine the splines that engage the drive shaft, odds are they are worn out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Cabrio Washer - Short Cycles in Clean Washer Cycle doehunter Washer Repair 0 08-02-2015 05:37 AM
Cabrio Washer pileggi1 Washer Repair 0 04-22-2012 05:11 PM
Cabrio Washer mattward Washer Repair 1 04-02-2011 05:53 PM
Rotator arm won't, rotate that is. dragonlady Dishwasher Repair 1 09-01-2007 01:28 PM
