Discuss
Panda XPB36 portable washing machine blows fuse and trips circuit breaker
 in
Washer Repair
I'm having some difficulty with a Panda XPB36 twin tub portable washing machine. I'm hoping somebody here might be able
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Panda XPB36 portable washing machine blows fuse and trips circuit breaker
  #1 (permalink)
Old 07-04-2017, 07:26 PM
Junior Member
amount is on a distinguished road
Default Panda XPB36 portable washing machine blows fuse and trips circuit breaker
Model Number: XPB36   Brand: -other-   Age: 1 - 5 years
I'm having some difficulty with a Panda XPB36 twin tub portable washing machine. I'm hoping somebody here might be able to help! I have very little experience with this sort of thing, so I'd appreciate it very much if you could explain things to me like I'm five.
Problem:
When I bought the washer, it worked fine for about two months. Then, occasionally, the spinner started tripping the circuit interrupter in the bathroom outlet. Everything would work again after resetting the GFCI. Eventually, however, the machine stopped working entirely, even when plugged into an outlet without a GFCI.
I opened the access panel on the back and saw that there was a blown fuse (it says "F5A/250V") in one of the lines. I replaced it with a Cooper Bussmann 5 Amp Time Delay Fuse that said it could be used for circuits up to 250 volts. When I plugged the machine back in, the pump worked and the washer motor worked, but the spinner motor blew the replacement fuse.
I put another new fuse in and tried washing a load. As before, the wash cycle tripped the GFCI. But when I plugged the machine into a different outlet, it worked fine. The wash cycled worked and the pump drained the tub. I didn't bother trying the spinner again since I had only bought the two replacement fuses.
One potential important observation: when I opened the back of the machine, I noticed that the capacitor had come loose from its bracket. It may have gotten wet at some point when the wash tub was over-filled, I don't know.
Details:
Washer: PANDA TWIN TUB WASHING MACHINE Model: XPB36 Class of Waterproof: IPX4 Rated Washing Capacity: 3.6kg Rated Spinning Capacity: 2.0kg Washing Input Power: 240W Spin Input Power: 120W Rated Voltage: 110V~ Rated Frequency: 60Hz
Here's a picture of the wiring diagram on the back of the washer:
Imgur: The most awesome images on the Internet
Capacitor:
CBB60 (12+25)μF5% SH 250VAC 50/60Hz 40/70/21 C.P0
Here's a picture of the capacitor (it has four wires coming out):
Spinner motor:
XTD-30 (A) 30 W 110V 60Hz 1.3A 12μF/250V Class B Zhejiang Weikang Motor Co., Ltd. 2013.11
Here's a picture of the spinner motor:
If anyone has any ideas for how I can diagnose the problem and begin to fix it, I'd love to hear them! I would also be interested in hearing about where I should go to track down replacement parts if needed (such as the capacitor).
Thanks a bunch!
Related Models
Amana XRBR206BB REF - BOTTOM MOUNTS
Amana XRBR206BW REF - BOTTOM MOUNTS
Amana XRBR904BB REF - BOTTOM MOUNTS
Amana XRBR904BS REF - BOTTOM MOUNTS
Amana XRBR904BW REF - BOTTOM MOUNTS
Amana XRBS017BB REF - BOTTOM MOUNTS
Amana XRBS017BW REF - BOTTOM MOUNTS
Amana XRBS209BBR REF - BOTTOM MOUNTS
Amana XRBS209BSR REF - BOTTOM MOUNTS
Amana XRBS209BWR REF - BOTTOM MOUNTS
Amana XRSR465BW REF - SXS/I&W
Amana XRSR665BW REF - SXS/I&W
Amana XRSR687BW REF - SXS/I&W
Amana XRSS204BB REF - SXS
Amana XRSS204BW REF - SXS
Amana XRSS264BB REF - SXS/I&W
Amana XRSS264BW REF - SXS/I&W
Amana XRSS267BB REF - SXS/I&W
Amana XRSS267BW REF - SXS/I&W
Amana XRSS287BB REF - SXS/I&W
Amana XRSS287BW REF - SXS/I&W
Amana XRSS465BB REF - SXS/I&W
Amana XRSS665BB REF - SXS/I&W
Amana XRSS687BB REF - SXS/I&W
Amana XST-305 RANGE- S/C S/I DDRAFT GAS
Amana XST-307 RANGE- S/C S/I DDRAFT GAS
Amana XST-310 RANGE- S/C S/I DDRAFT GAS
Amana XST111 ELE CARTRIDGE
Amana XST111UB ELE CARTRIDGE
Amana XST111UB1 ELE CARTRIDGE
Amana XST111UW ELE CARTRIDGE
Amana XST111UW1 ELE CARTRIDGE
Amana XST111UWW1 ELE CARTRIDGE
Amana XST2022B RANGE- S/C S/I DDRAFT GAS
 XST2022W ELE CARTRIDGE
Amana XST2052B RANGE- S/C S/I DDRAFT GAS
Amana XST2052W RANGE- S/C S/I DDRAFT GAS
Amana XST2072B RANGE- S/C S/I DDRAFT GAS
Amana XST2072W RANGE- S/C S/I DDRAFT GAS
Amana XST209-2B RANGE- S/C S/I DDRAFT GAS
Amana XST209-2W RANGE- S/C S/I DDRAFT GAS
Amana XST2092B ELE CARTRIDGE
Amana XST2092K ELE CARTRIDGE
Amana XST2092W ELE CARTRIDGE
Amana XST229 ELE CARTRIDGE
Amana XST235 ELE CARTRIDGE
Amana XST310 ELE CARTRIDGE
Amana XST311U ELE CARTRIDGE
Amana XST329 ELE CARTRIDGE
Amana XST339 ELE CARTRIDGE
Whirlpool XVP5000TQ0 LAUNDRY TOWER
Whirlpool XVP8600TB0 LAUNDRY TOWER
Whirlpool XVP8600TU0 LAUNDRY TOWER
Whirlpool XVP8600TW0 LAUNDRY TOWER
Whirlpool XVP9000TA0 LAUNDRY TOWER
Whirlpool XVP9000TB0 LAUNDRY TOWER
Whirlpool XVP9000TU0 LAUNDRY TOWER
Whirlpool XVP9000TW0 LAUNDRY TOWER
Whirlpool XW18500VW0 SLIDE-OUT WORKSURFACE
Whirlpool XW29000TA0 LAUNDRY WORKSURFACE
Whirlpool XW29000TB0 LAUNDRY WORKSURFACE
Whirlpool XW29000TC0 LAUNDRY WORKSURFACE
Whirlpool XW29000TU0 LAUNDRY WORKSURFACE
Whirlpool XW29000TW0 LAUNDRY WORKSURFACE
Whirlpool XXHP1550VW0 PEDESTAL
Amana YA1200 WASHER-TOP LOADING
Whirlpool YACM052MM0 AIR CONDITIONER
Whirlpool YACM062MM0 AIR CONDITIONER
Whirlpool YACM082XK1 AIR CONDITIONER
Whirlpool YACM082XP0 AIR CONDITIONER
Whirlpool YACQ068MP0 AIR CONDITIONER
Whirlpool YACQ082XK1 AIR CONDITIONER
Whirlpool YACQ088MR0 AIR CONDITIONER
Whirlpool YACQ088XP0 AIR CONDITIONER
Whirlpool YACQ108MR0 AIR CONDITIONER
Whirlpool YACQ128XR0 AIR CONDITIONER
Maytag YAED4370TQ0 29" ELECTRIC DRYER
Maytag YAED4470TQ0 29" ELECTRIC DRYER
Maytag YAED4475TQ1 29" ELECTRIC DRYER
Maytag YAMV1160VAB0 Microwave Oven 1.6 Cu. Ft.
Maytag YAMV1160VAB1 MICROWAVE OVEN 1.6 CU. FT.
Maytag YAMV1160VAS0 Microwave Oven 1.6 Cu. Ft.
Maytag YAMV1160VAS1 MICROWAVE OVEN 1.6 CU. FT.
Maytag YAMV1160VAW0 Microwave Oven 1.6 Cu. Ft.
Maytag YAMV1160VAW1 MICROWAVE OVEN 1.6 CU. FT.
General Electric YBXR1060T2WW Washer
General Electric YBXR1060T3WW Washer
General Electric YBXR1060T4WW Washer
General Electric YBXR1060T5WW Washer
General Electric YBXR1060T8WW Washer
General Electric YBXR1060TAWW Washer
General Electric YBXR1060V0WW Washer
General Electric YBXR1060V1WW Washer
General Electric YBXR2070T2WW Washer
General Electric YBXR2070T3WW Washer
General Electric YBXR2070T5WW Washer
General Electric YBXR2070T6WW Washer
General Electric YBXR2070T8WW Washer
General Electric YBXR2070TAWW Washer
General Electric YBXR2070V0WW Washer
General Electric YBXR2070V1WW Washer
Whirlpool YCEDS563SQ0 29" ELECTRIC DRYER
Whirlpool YCEDX463RQ1 29"electric Dryer
Whirlpool YCEE2760KQ0 COMMERCIAL ELECTRIC DRYER
Whirlpool YCEE2760KQ1 COMMERCIAL ELECTRIC DRYER
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Blows house circuit breaker hov6472 Microwave Repair 0 02-01-2013 11:44 AM
Oven blows circuit breaker sufax Oven Repair (including Ranges and Cooktops) 0 03-28-2010 10:14 AM
Whishing machine trips circuit breaker at spin cycle mattwaldner Washer Repair 1 10-21-2009 02:33 PM
Portable Dishwasher Trips Circuit Breaker repairbymyself Dishwasher Repair 18 03-27-2009 08:44 PM
Broiler blows circuit breaker Sarafixit Oven Repair (including Ranges and Cooktops) 3 02-10-2009 05:24 AM
