Discuss
Whirlpool front load washer
 in
Washer Repair
I have a whirlpool front load washing machine model WFW94HEXW1 The problem im have is the water won't flow into
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool front load washer
  #1 (permalink)
Old 07-01-2017, 09:00 PM
Junior Member
Jhennessy is on a distinguished road
Default Whirlpool front load washer
Model Number: WFW94HEXW1   Brand: Whirlpool   Age: 1 - 5 years
The problem im have is the water won't flow into machine. I replaced the inlet valve thinking that was the problem. Still having the same problem.
My next step would be to change the dispenser motor switch assembly or should I change the pressure switch? Is there a way to check these items b4 replacing ? I hear a clicking sound coming from the dispenser motor switch assembly like it's skipping or not working properly.. does that switch control if water enters machine?
Related Models
Whirlpool WFW94HEXW1 AUTOMATIC WASHER
Whirlpool WFW94HEXW2 AUTOMATIC WASHER
Whirlpool WFW9500TC00 AUTOMATIC WASHER
Whirlpool WFW9500TC01 AUTOMATIC WASHER
Whirlpool WFW9500TC02 AUTOMATIC WASHER
Whirlpool WFW9500TC03 AUTOMATIC WASHER
Whirlpool WFW9500TW00 AUTOMATIC WASHER
Whirlpool WFW9500TW01 AUTOMATIC WASHER
Whirlpool WFW9500TW02 AUTOMATIC WASHER
Whirlpool WFW9500TW03 AUTOMATIC WASHER
Whirlpool WFW9550WL00 AUTOMATIC WASHER
Whirlpool WFW9550WL01 AUTOMATIC WASHER
Whirlpool WFW9550WL10 AUTOMATIC WASHER
Whirlpool WFW9550WR00 AUTOMATIC WASHER
Whirlpool WFW9550WR01 AUTOMATIC WASHER
Whirlpool WFW9550WW00 AUTOMATIC WASHER
Whirlpool WFW9550WW01 AUTOMATIC WASHER
Whirlpool WFW9550WW10 AUTOMATIC WASHER
Whirlpool WFW95HEXL0 WASHER
Whirlpool WFW95HEXL1 AUTOMATIC WASHER
Whirlpool WFW95HEXL2 AUTOMATIC WASHER
Whirlpool WFW95HEXR0 WASHER
Whirlpool WFW95HEXR1 AUTOMATIC WASHER
Whirlpool WFW95HEXR2 AUTOMATIC WASHER
Whirlpool WFW95HEXW0 WASHER
Whirlpool WFW95HEXW1 AUTOMATIC WASHER
Whirlpool WFW95HEXW2 AUTOMATIC WASHER
Whirlpool WFW9600TA00 AUTOMATIC WASHER
Whirlpool WFW9600TA01 AUTOMATIC WASHER
Whirlpool WFW9600TA02 AUTOMATIC WASHER
Whirlpool WFW9600TB00 AUTOMATIC WASHER
Whirlpool WFW9600TC00 AUTOMATIC WASHER
Whirlpool WFW9600TU00 AUTOMATIC WASHER
Whirlpool WFW9600TW00 AUTOMATIC WASHER
Whirlpool WFW9600TW01 AUTOMATIC WASHER
Whirlpool WFW9600TW02 AUTOMATIC WASHER
Whirlpool WFW9600TZ00 AUTOMATIC WASHER
Whirlpool WFW9640XW00 AUTOMATIC WASHER
Whirlpool WFW9700VA00 AUTOMATIC WASHER
Whirlpool WFW9700VA01 AUTOMATIC WASHER
Whirlpool WFW9700VW00 AUTOMATIC WASHER
Whirlpool WFW9700VW01 AUTOMATIC WASHER
Whirlpool WFW9750WL00 AUTOMATIC WASHER
Whirlpool WFW9750WL01 AUTOMATIC WASHER
Whirlpool WFW9750WL02 AUTOMATIC WASHER
Whirlpool WFW9750WR00 AUTOMATIC WASHER
Whirlpool WFW9750WR01 AUTOMATIC WASHER
Whirlpool WFW9750WR02 AUTOMATIC WASHER
Whirlpool WFW9750WW00 AUTOMATIC WASHER
Whirlpool WFW9750WW01 AUTOMATIC WASHER
Whirlpool WFW9750WW02 AUTOMATIC WASHER
Whirlpool WFW97HEXL0 WASHER
Whirlpool WFW97HEXL1 WASHER
Whirlpool WFW97HEXL2 AUTOMATIC WASHER
Whirlpool WFW97HEXR0 WASHER
Whirlpool WFW97HEXR1 WASHER
Whirlpool WFW97HEXR2 AUTOMATIC WASHER
Whirlpool WFW97HEXW0 WASHER
Whirlpool WFW97HEXW1 WASHER
Whirlpool WFW97HEXW2 AUTOMATIC WASHER
Amana WG1010.000 COMMERCIAL MICROWAVES
Amana WG1010.010 COMMERCIAL MICROWAVES
Amana WG1010.200 COMMERCIAL MICROWAVES
Amana WG1021.000 COMMERCIAL MICROWAVES
Amana WG1021.200 COMMERCIAL MICROWAVES
Amana WG1065.000 COMMERCIAL MICROWAVES
Amana WG1120.500 COMMERCIAL MICROWAVES
Amana WG1120.600 COMMERCIAL MICROWAVES
Amana WG1121.000 COMMERCIAL MICROWAVES
Amana WG1165.000 COMMERCIAL MICROWAVES
Amana WG1165.700 COMMERCIAL MICROWAVES
Amana WG1166.500 COMMERCIAL MICROWAVES
 WG1804R Air Conditioner
 WG1805RY6 Air Conditioner
Jenn-Air WG200 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG206 WALLOVEN- CONT CLEAN GAS
Jenn-Air WG24000B WALLOVEN- STD GAS
Jenn-Air WG24000W WALLOVEN- STD GAS
Jenn-Air WG30100B WALLOVEN- S/C GAS
Jenn-Air WG30100W WALLOVEN- S/C GAS
Amana WG445.1 COMMERCIAL MICROWAVES
Amana WG445.2 COMMERCIAL MICROWAVES
 WG5200R Air Conditioner
Whirlpool WGD4750XQ0 29" GAS DRYER
Whirlpool WGD4750XQ1 29" GAS DRYER
Whirlpool WGD4800XQ0 DRYER
Whirlpool WGD4850XQ0 29" GAS DRYER
Whirlpool WGD4890XQ0 29" GAS DRYER
Whirlpool WGD4900XW0 29" GAS DRYER
Whirlpool WGD4910XQ0 29" GAS DRYER
Whirlpool WGD5000VQ1 29" GAS DRYER
Whirlpool WGD5100SQ0 29" GAS DRYER
Whirlpool WGD5100VQ0 29" GAS DRYER
Whirlpool WGD5100VQ1 29" GAS DRYER
Whirlpool WGD5200TQ0 29" GAS DRYER
Whirlpool WGD5200VQ0 29" GAS DRYER
Whirlpool WGD5200VQ1 29" GAS DRYER
Whirlpool WGD5300SQ0 29"GAS DRYER
Whirlpool WGD5300ST0 29"GAS DRYER
Whirlpool WGD5300VW0 29" GAS DRYER
Whirlpool WGD5300VW1 29" GAS DRYER
Whirlpool WGD5310SQ0 29"GAS DRYER
Whirlpool WGD5320SQ0 29"GAS DRYER
Whirlpool WGD5321SQ0 29"GAS DRYER
Whirlpool WGD5500SQ0 29"GAS DRYER
Whirlpool WGD5500ST0 29"GAS DRYER
Whirlpool WGD5500XL0 27" ELECTRIC DRYER
Whirlpool WGD5500XL1 27" ELECTRIC DRYER
Whirlpool WGD5500XW0 27" ELECTRIC DRYER
Whirlpool WGD5500XW1 27" ELECTRIC DRYER
Whirlpool WGD5510VQ0 29"GAS DRYER
Whirlpool WGD5510VQ1 29"GAS DRYER
Whirlpool WGD5520SQ0 29" GAS DRYER
Whirlpool WGD5521SQ0 29"GAS DRYER
Whirlpool WGD5530SQ0 29"GAS DRYER
Whirlpool WGD5540SQ0 29"GAS DRYER
Whirlpool WGD5540ST0 29"GAS DRYER
Whirlpool WGD5550SQ0 29" GAS DRYER
Whirlpool WGD5550ST0 29" GAS DRYER
Whirlpool WGD5550XW0 27" GAS DRYER
  #2 (permalink)
Old 07-06-2017, 06:47 AM
Senior Member
brobriffin is on a distinguished road
Default
The dispenser switch only transfers the incoming water from the soap compartment to either the bleach or fabric softener compartments. If the water inlet valves are opening water would flow into the tub only thru the wrong compartment.
Things to try:
1. verify your water hoses are flowing water by removing them from the back of the machine and running each into the drain pipe
2. reconnect the hoses and verify the water valves are fully open
3. run all the different cycles and different water temp settings
4. while running all the different cycles open the dispenser tray slightly to see if any water is passing thru
Also while performing the checks, leave the top off the machine and watch to see if the dispenser switch arm moves. If not it may need replaced and if it isn't switching to the correct position may cause the water not to turn on. Try helping it move a little by hand when you hear it clicking.
If no water flows with any of the tests and you have installed a new water inlet valve assembly and the dispenser switch is working, then I suspect either the wiring isn't making a good connection or your electronic control board is bad.
  #3 (permalink)
Old 07-16-2017, 10:59 AM
Junior Member
Default
The connection to the dispenser switch was corroded I cleaned it up and it worked for a while. Then stopped again...I replaced the dispenser switch and cleaned up the wire connection. Everything is working fine now thanks
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool front load washer alk500 Washer Repair 1 07-21-2013 08:00 PM
whirlpool front load washer Connie B Good Washer Repair 0 03-24-2013 12:17 PM
Whirlpool front load cloths washer Bushman30 Washer Repair 0 09-04-2012 08:46 AM
Replace front door seals on front load whirlpool washer andy202746@verizon.net Washer Repair 0 08-06-2011 11:22 AM
Front load whirlpool washer JDPjr Washer Repair 2 08-03-2010 06:25 AM
