Discuss
Maytag 2000 Series Washer: LF Error
 in
Washer Repair
Hello all, Yesterday, our washer (Maytag 2000 Series) started reporting an "LF" error. The service manual tells me that it
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag 2000 Series Washer: LF Error
  #1 (permalink)
Old 06-24-2017, 09:52 AM
Junior Member
ThatChubbyGuy is on a distinguished road
Default Maytag 2000 Series Washer: LF Error
Model Number: MHWE251YG00   Brand: Maytag   Age: 1 - 5 years
Hello all,
The service manual tells me that it is a "No water detected entering wash or pressure switch trip not detected".
I have read through the Possible Causes / Procedure section.
What I've done so far to diagnose / troubleshoot:
1. Checked to make sure water was turned on for both hot and cold (yes).
2. Checked water pressure for both hot and cold (normal pressure for both).
3. Checked the filters for both the single (hot) and double (cold) inlet valves (clear).
4. Checked the hoses from the wall to the washer and the inlet valves to the detergent compartment for kinks or leaks (none).
5. Checked the inlet valves for resistance using my voltmeter (both passed).
6. Checked the continuity of the pressure switch (passed).
7. Cleared the error and ran the diagnostic test per the service manual (all passed).
Now....here's where it gets interesting:
When I attempt to run a load of laundry (in this example, it was on Normal cycle, Cold, Extra High Spin, Normal soil level), the water does begin to fill the tub, but in a noticeably lower pressure/speed than when I run the diagnostic test or when I do a "Rinse/Drain/Spin" cycle. When I run the diagnostic test, you can very clearly tell that the water is coming into the tub at a much faster rate.
Following running the above load of laundry and getting the LF error, I changed to "Rinse / Drain / Spin" mode and started the washer again. Very noticeable change in the speed of the water coming into the tub.
Does anyone have any thoughts as to what would cause this? I am assuming that the inlet valves are either open or closed, with no in between. The water (hot or cold) valve opens, water enters the tub to the pre-determined level, then is shut off via the pressure switch activation.
It doesn't make sense that there would be such a dramatic difference in the speed of the water entering the tub.
Any comments or suggestions are very much-appreciated.
Related Models
Maytag MHWE300VF00 AUTOMATIC WASHER
Maytag MHWE300VW00 AUTOMATIC WASHER
Maytag MHWE300VW10 AUTOMATIC WASHER
Maytag MHWE300VW11 AUTOMATIC WASHER
Maytag MHWE300VW12 AUTOMATIC WASHER
Maytag MHWE300VW13 AUTOMATIC WASHER
Maytag MHWE400WJ00 AUTOMATIC WASHER
Maytag MHWE400WJ01 AUTOMATIC WASHER
Maytag MHWE400WR00 AUTOMATIC WASHER
Maytag MHWE400WR01 AUTOMATIC WASHER
Maytag MHWE400WW00 AUTOMATIC WASHER
Maytag MHWE400WW01 AUTOMATIC WASHER
Maytag MHWE450WJ00 AUTOMATIC WASHER
Maytag MHWE450WJ01 AUTOMATIC WASHER
Maytag MHWE450WR00 AUTOMATIC WASHER
Maytag MHWE450WR01 AUTOMATIC WASHER
Maytag MHWE450WW00 AUTOMATIC WASHER
Maytag MHWE450WW01 AUTOMATIC WASHER
Maytag MHWE500VP00 AUTOMATIC WASHER
Maytag MHWE500VP01 AUTOMATIC WASHER
Maytag MHWE500VW00 AUTOMATIC WASHER
Maytag MHWE500VW01 AUTOMATIC WASHER
Maytag MHWE500VW10 AUTOMATIC WASHER
Maytag MHWE500VW11 AUTOMATIC WASHER
Maytag MHWE500VW12 AUTOMATIC WASHER
Maytag MHWE550WJ00 AUTOMATIC WASHER
Maytag MHWE550WJ01 AUTOMATIC WASHER
Maytag MHWE550WR00 AUTOMATIC WASHER
Maytag MHWE550WR01 AUTOMATIC WASHER
Maytag MHWE550WW00 AUTOMATIC WASHER
Maytag MHWE550WW01 AUTOMATIC WASHER
Maytag MHWE900VJ00 AUTOMATIC WASHER
Maytag MHWE900VJ01 AUTOMATIC WASHER
Maytag MHWE900VW00 AUTOMATIC WASHER
Maytag MHWE900VW01 AUTOMATIC WASHER
Maytag MHWE950WW00 AUTOMATIC WASHER
Maytag MHWZ400TB00 AUTOMATIC WASHER
Maytag MHWZ400TB01 AUTOMATIC WASHER
Maytag MHWZ400TB02 AUTOMATIC WASHER
Maytag MHWZ400TQ00 AUTOMATIC WASHER
Maytag MHWZ400TQ01 AUTOMATIC WASHER
Maytag MHWZ400TQ02 AUTOMATIC WASHER
Maytag MHWZ400TQ03 AUTOMATIC WASHER
Maytag MHWZ600TB00 AUTOMATIC WASHER
Maytag MHWZ600TB01 AUTOMATIC WASHER
Maytag MHWZ600TB02 AUTOMATIC WASHER
Maytag MHWZ600TE00 AUTOMATIC WASHER
Maytag MHWZ600TE01 AUTOMATIC WASHER
Maytag MHWZ600TK00 AUTOMATIC WASHER
Maytag MHWZ600TK01 AUTOMATIC WASHER
Maytag MHWZ600TK02 AUTOMATIC WASHER
Maytag MHWZ600TW00 AUTOMATIC WASHER
Maytag MHWZ600TW01 AUTOMATIC WASHER
Maytag MHWZ600TW02 AUTOMATIC WASHER
Maytag MHWZ600WR00 AUTOMATIC WASHER
Maytag MHWZ600WR01 AUTOMATIC WASHER
General Electric MIG23MIMHFBB Refrigerator
General Electric MIG23MISAFBB Refrigerator
General Electric MIG23MISBFBB Refrigerator
Maytag MIM1554VRB0 ICE CUBE MAKER
Maytag MIM1554VRS0 ICE CUBE MAKER
Maytag MIM1554VRW0 ICE CUBE MAKER
Maytag MIM1554WRS0 ICE CUBE MAKER
Maytag MIM1554WRS1 ICE CUBE MAKER
Maytag MIP85S MISC / ACCESSORY
Maytag MIP85T-2 MISC / ACCESSORY
General Electric MK KIT 1 ICEMAKER
Whirlpool MK100
Whirlpool MK110
Jenn-Air MK241W MISC / ACCESSORY
Jenn-Air MK24B MISC / ACCESSORY
Jenn-Air MK271B MISC / ACCESSORY
Jenn-Air MK271W MISC / ACCESSORY
Jenn-Air MK272B MISC / ACCESSORY
Jenn-Air MK272W MISC / ACCESSORY
Jenn-Air MK27B MISC / ACCESSORY
Jenn-Air MK27W MISC / ACCESSORY
Jenn-Air MK301B MISC / ACCESSORY
Jenn-Air MK301W MISC / ACCESSORY
Jenn-Air MK302B MISC / ACCESSORY
Jenn-Air MK302W MISC / ACCESSORY
Jenn-Air MK30B MISC / ACCESSORY
Jenn-Air MK30W MISC / ACCESSORY
Amana ML-1 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-10 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-2 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-3 MWAVE - FAMILY SIZE (60 HZ)
KitchenAid ML-42082 DISHWASHER
KitchenAid ML-42117 DISHWASHER
KitchenAid ML-42131 HEAVY DUTY DISPOSER
KitchenAid ML-42132 HEAVY DUTY DISPOSER
KitchenAid ML-42135 HEAVY DUTY DISPOSER
KitchenAid ML-42136 HEAVY DUTY DISPOSER
Whirlpool ML02CCXHW REFRIGERATOR
Whirlpool ML02CCXHW1 REFRIGERATOR
Whirlpool ML03CCXHW REFRIGERATOR
Whirlpool ML03CCXHW1 REFRIGERATOR
Whirlpool ML05CCXHW REFRIGERATOR
Whirlpool ML05CCXHW1 REFRIGERATOR
Amana ML10 MWAVE- CNTRTP / STAND ALONE
Amana ML40 AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML441T MWAVE- CNTRTP / STAND ALONE
Amana ML446P AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML451T MWAVE- CNTRTP / STAND ALONE
Frigidaire MLCE52RCS0 Tap(v1) / Laundry Center
Frigidaire MLCE52RCS1 Frg(v1) / Laundry Center
Frigidaire MLCE52RCT0 Tap(v2) / Laundry Center
Frigidaire MLCE52RCT1 Frg(v2) / Laundry Center
Amana MLD510 COMMERCIAL MICROWAVES
Amana MLD510D COMMERCIAL MICROWAVES
Maytag MLE15MNAGW MANUAL, PARTS (DRYER GAS)
Maytag MLE15MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE15MNAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYA MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYQ MANUAL, PARTS (DRYER ELE)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Leaking Maytag Series 2000 Washer sure74 Washer Repair 0 04-15-2017 10:32 AM
Maytag 2000 series washer leaking water underneith Norco Washer Repair 0 03-25-2017 01:39 PM
Maytag 2000 series dryer sabm0506 Dryer Repair 0 06-05-2016 03:25 PM
Maytag 2000 Series Washer has no power tameraharris Washer Repair 3 11-29-2014 06:02 PM
maytag 2000 series has error codes??? melaniewasherbroke Washer Repair 0 01-21-2014 03:47 PM
