Washer makes noise while agitating. I replaced the agitator dogs did not fix it. Installed the medium can agitator repair kit did not fix it. I replaced the drive block no luck. I replaced the complete agitator assembly noise still there. I replaced the gear case while carefully watching your video. Replaced the motor coupling while I had it apart. Got it back together. New noise. Took everything apart again and found the gearcase would not pull out like before. When I got it out the basket drive came out with it. I cannot get the basket drive off of the gearcase. The brake on the bottom of the basket drive broke off. Yes I did install the spacer back on top of the clutch before installing the transmission. How do I get the basket drive off of the gearcase?
