Discuss
Maytag 2000 series will not fill on any wash cycle, only rinse cycle
 in
Washer Repair
We started getting LF code on the occasional wash cycle 2 months ago. When that occurred, we'd cancel the load,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag 2000 series will not fill on any wash cycle, only rinse cycle
  #1 (permalink)
Old 06-22-2017, 08:31 AM
Junior Member
JenBTampa is on a distinguished road
Default Maytag 2000 series will not fill on any wash cycle, only rinse cycle
Model Number: MHWE200XW00   Brand: Maytag   Age: 5 - 10 years
We started getting LF code on the occasional wash cycle 2 months ago. When that occurred, we'd cancel the load, power the washer on/off and restart it, usually with success. We checked the inlet valve screens and replaced the valves. The problem seemed to be gone for a week, then came back. We called someone out for repair and they flushed the drain line. The LF codes went away again for a few days, then came back. The same repair folks came out yesterday and said the problem is now likely the board. However, they suggested running the Clean cycle to rule out detergent buildup as the root cause and then unplug the washer for 2 hours. The Clean cycle wouldn't run without LF, so we ran the normal cycle with hot water and Affresh twice. After 2 hours, we plugged the washer back in and the normal cycle started up again, but then my husband powered the washer off after it filled for only a few seconds without hitting cancel and letting it drain. Thereafter, the washer would only spin and not fill with water on any cycle - almost like it thought it was already full of water. The rinse/spin/drain cycle is the only one that would allow water into the washer.
I saw some suggestions about replacing the pressure level switch. I took mine off and blew into it and I only heard 1 click, which I think means that it is faulty. My question is, would a fault pressure level switch also cause the washer to not fill at all on any cycle? But still allow the rinse cycle to fill?
Related Models
Maytag MHWE200XW00 AUTOMATIC WASHER
Maytag MHWE300VF00 AUTOMATIC WASHER
Maytag MHWE300VW00 AUTOMATIC WASHER
Maytag MHWE300VW10 AUTOMATIC WASHER
Maytag MHWE300VW11 AUTOMATIC WASHER
Maytag MHWE300VW12 AUTOMATIC WASHER
Maytag MHWE300VW13 AUTOMATIC WASHER
Maytag MHWE400WJ00 AUTOMATIC WASHER
Maytag MHWE400WJ01 AUTOMATIC WASHER
Maytag MHWE400WR00 AUTOMATIC WASHER
Maytag MHWE400WR01 AUTOMATIC WASHER
Maytag MHWE400WW00 AUTOMATIC WASHER
Maytag MHWE400WW01 AUTOMATIC WASHER
Maytag MHWE450WJ00 AUTOMATIC WASHER
Maytag MHWE450WJ01 AUTOMATIC WASHER
Maytag MHWE450WR00 AUTOMATIC WASHER
Maytag MHWE450WR01 AUTOMATIC WASHER
Maytag MHWE450WW00 AUTOMATIC WASHER
Maytag MHWE450WW01 AUTOMATIC WASHER
Maytag MHWE500VP00 AUTOMATIC WASHER
Maytag MHWE500VP01 AUTOMATIC WASHER
Maytag MHWE500VW00 AUTOMATIC WASHER
Maytag MHWE500VW01 AUTOMATIC WASHER
Maytag MHWE500VW10 AUTOMATIC WASHER
Maytag MHWE500VW11 AUTOMATIC WASHER
Maytag MHWE500VW12 AUTOMATIC WASHER
Maytag MHWE550WJ00 AUTOMATIC WASHER
Maytag MHWE550WJ01 AUTOMATIC WASHER
Maytag MHWE550WR00 AUTOMATIC WASHER
Maytag MHWE550WR01 AUTOMATIC WASHER
Maytag MHWE550WW00 AUTOMATIC WASHER
Maytag MHWE550WW01 AUTOMATIC WASHER
Maytag MHWE900VJ00 AUTOMATIC WASHER
Maytag MHWE900VJ01 AUTOMATIC WASHER
Maytag MHWE900VW00 AUTOMATIC WASHER
Maytag MHWE900VW01 AUTOMATIC WASHER
Maytag MHWE950WW00 AUTOMATIC WASHER
Maytag MHWZ400TB00 AUTOMATIC WASHER
Maytag MHWZ400TB01 AUTOMATIC WASHER
Maytag MHWZ400TB02 AUTOMATIC WASHER
Maytag MHWZ400TQ00 AUTOMATIC WASHER
Maytag MHWZ400TQ01 AUTOMATIC WASHER
Maytag MHWZ400TQ02 AUTOMATIC WASHER
Maytag MHWZ400TQ03 AUTOMATIC WASHER
Maytag MHWZ600TB00 AUTOMATIC WASHER
Maytag MHWZ600TB01 AUTOMATIC WASHER
Maytag MHWZ600TB02 AUTOMATIC WASHER
Maytag MHWZ600TE00 AUTOMATIC WASHER
Maytag MHWZ600TE01 AUTOMATIC WASHER
Maytag MHWZ600TK00 AUTOMATIC WASHER
Maytag MHWZ600TK01 AUTOMATIC WASHER
Maytag MHWZ600TK02 AUTOMATIC WASHER
Maytag MHWZ600TW00 AUTOMATIC WASHER
Maytag MHWZ600TW01 AUTOMATIC WASHER
Maytag MHWZ600TW02 AUTOMATIC WASHER
Maytag MHWZ600WR00 AUTOMATIC WASHER
Maytag MHWZ600WR01 AUTOMATIC WASHER
General Electric MIG23MIMHFBB Refrigerator
General Electric MIG23MISAFBB Refrigerator
General Electric MIG23MISBFBB Refrigerator
Maytag MIM1554VRB0 ICE CUBE MAKER
Maytag MIM1554VRS0 ICE CUBE MAKER
Maytag MIM1554VRW0 ICE CUBE MAKER
Maytag MIM1554WRS0 ICE CUBE MAKER
Maytag MIM1554WRS1 ICE CUBE MAKER
Maytag MIP85S MISC / ACCESSORY
Maytag MIP85T-2 MISC / ACCESSORY
General Electric MK KIT 1 ICEMAKER
Whirlpool MK100
Whirlpool MK110
Jenn-Air MK241W MISC / ACCESSORY
Jenn-Air MK24B MISC / ACCESSORY
Jenn-Air MK271B MISC / ACCESSORY
Jenn-Air MK271W MISC / ACCESSORY
Jenn-Air MK272B MISC / ACCESSORY
Jenn-Air MK272W MISC / ACCESSORY
Jenn-Air MK27B MISC / ACCESSORY
Jenn-Air MK27W MISC / ACCESSORY
Jenn-Air MK301B MISC / ACCESSORY
Jenn-Air MK301W MISC / ACCESSORY
Jenn-Air MK302B MISC / ACCESSORY
Jenn-Air MK302W MISC / ACCESSORY
Jenn-Air MK30B MISC / ACCESSORY
Jenn-Air MK30W MISC / ACCESSORY
Amana ML-1 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-10 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-2 MWAVE - FAMILY SIZE (60 HZ)
Amana ML-3 MWAVE - FAMILY SIZE (60 HZ)
KitchenAid ML-42082 DISHWASHER
KitchenAid ML-42117 DISHWASHER
KitchenAid ML-42131 HEAVY DUTY DISPOSER
KitchenAid ML-42132 HEAVY DUTY DISPOSER
KitchenAid ML-42135 HEAVY DUTY DISPOSER
KitchenAid ML-42136 HEAVY DUTY DISPOSER
Whirlpool ML02CCXHW REFRIGERATOR
Whirlpool ML02CCXHW1 REFRIGERATOR
Whirlpool ML03CCXHW REFRIGERATOR
Whirlpool ML03CCXHW1 REFRIGERATOR
Whirlpool ML05CCXHW REFRIGERATOR
Whirlpool ML05CCXHW1 REFRIGERATOR
Amana ML10 MWAVE- CNTRTP / STAND ALONE
Amana ML40 AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML441T MWAVE- CNTRTP / STAND ALONE
Amana ML446P AMANA MWAVE- COUNTERTOP / STAN (MICROWAVE)
Amana ML451T MWAVE- CNTRTP / STAND ALONE
Frigidaire MLCE52RCS0 Tap(v1) / Laundry Center
Frigidaire MLCE52RCS1 Frg(v1) / Laundry Center
Frigidaire MLCE52RCT0 Tap(v2) / Laundry Center
Frigidaire MLCE52RCT1 Frg(v2) / Laundry Center
Amana MLD510 COMMERCIAL MICROWAVES
Amana MLD510D COMMERCIAL MICROWAVES
Maytag MLE15MNAGW MANUAL, PARTS (DRYER GAS)
Maytag MLE15MNAYW MANUAL, PARTS (DRYER ELE)
Maytag MLE15MNAZW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAGW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAUW MANUAL, PARTS (DRYER ELE)
Maytag MLE15PDAYA MANUAL, PARTS (DRYER ELE)
  #2 (permalink)
Old 06-22-2017, 08:41 AM
Junior Member
Default Update: Pump trap FULL
Operating on the suspicion that the pump trap must be working properly to reset the pressure level switch, I had my husband check the pump trap. He said it was completely full with lint, like a ball the size of his fist. I can't believe the appliance repair people we called flushed the drain line but never bothered to check the trap?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer drains after wash cycle then won't fill for rinse DawnCack Washer Repair 1 07-08-2014 06:40 PM
Washer won't fill on wash cycle but will during rinse march_33 Washer Repair 4 12-07-2011 06:48 PM
Low fill levels wash and rinse cycle Balding Washer Repair 3 10-21-2011 03:28 PM
dishwasher wont fill in wash cycle, but rinse cycle is Ok lindallplace Dishwasher Repair 0 10-12-2011 05:38 PM
