Discuss
Frigidaire front load no agitate or spin
 in
Washer Repair
Washer did not final spin, and making buzzing noise at pump. Then not agitating or spinning at all. Cleared change,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire front load no agitate or spin
  #1 (permalink)
Old 06-19-2017, 03:39 PM
Junior Member
Charlotte0355 is on a distinguished road
Unhappy Frigidaire front load no agitate or spin
Model Number: CRTF1240ASO   Brand: Frigidaire   Age: More than 10 years
Washer did not final spin, and making buzzing noise at pump. Then not agitating or spinning at all. Cleared change, couple of nuts in drain, made sure all lines clear, nothing blocking pump. Seems to be pumping fine, impeller moving appropriately by hand when I had it out and open. Sounds much better. Timer advances, fills, drains etc. on all cycles. I can 'help' it agitate and spin by BARELY moving pulley manually, with no load, just water. With small load, it will agitate (with little assist) but won't spin- just rocks back and forth, but won't turn completely around, and will not speed up at all. Motor seems to be turning fine, tub rotates easily, no noise. I am NOT electronics wizard, so tech sheets inside bottom Make little sense, but I can follow direction and have ohm meter. Any assistance is greatly appreciated. I have ordered a belt, just in case it might be slipping, and should get it tomorrow.
Related Models
Frigidaire CRTR9300AS0 Frtld Wshr - Frig/best Buy
Frigidaire CRWS1879AS0 Washer - Frigidaire/best Buy
Frigidaire CRWS1879AS2 Washer - Frig/best Buy
Frigidaire CRWS5700AS0 Fs Washer - Frig/best Buy
Frigidaire CRWS7900AS0 Fs Washer - Frig/best Buy
Frigidaire CRWS7900AS1 Frigidaire/washer
Whirlpool CS20TKXNQ00 REFRIGERATOR
Crosley CS20X6A REF - SXS
Crosley CS20X6W REF - SXS
Crosley CS20Y6A REF - SXS
Crosley CS20Y6W REF - SXS
Crosley CS21A2A REF - SXS
Crosley CS21A2Q REF - SXS
Crosley CS21A2W REF - SXS
Crosley CS21A5DA REF - SXS/I&W
Crosley CS21A5DW REF - SXS/I&W
Crosley CS21B5DA REF - SXS/I&W
Crosley CS21B5DQ REF - SXS/I&W
Crosley CS21B5DW REF - SXS/I&W
Crosley CS21F2Q REF - SXS
Crosley CS21F2W REF - SXS
Crosley CS21F5DW REF - SXS/I&W
Crosley CS21G2Q REF - SXS
Crosley CS21G2W REF - SXS
Crosley CS21G5DQ REF - SXS/I&W
Crosley CS21G5DW REF - SXS/I&W
Whirlpool CS22AEXHN00 REFRIGERATOR
Whirlpool CS22AEXHN01 REFRIGERATOR
Whirlpool CS22AEXHN02 REFRIGERATOR
Whirlpool CS22AEXHW00 REFRIGERATOR
Whirlpool CS22AEXHW01 REFRIGERATOR
Whirlpool CS22AEXHW02 REFRIGERATOR
Whirlpool CS22AFXKB05 REFRIGERATOR
Whirlpool CS22AFXKB06 REFRIGERATOR
Whirlpool CS22AFXKQ00 REFRIGERATOR
Whirlpool CS22AFXKQ01
Whirlpool CS22AFXKQ03 REFRIGERATOR
Whirlpool CS22AFXKQ04 REFRIGERATOR
Whirlpool CS22AFXKQ05 REFRIGERATOR
Whirlpool CS22AFXKQ06 REFRIGERATOR
Whirlpool CS22AFXKS05 REFRIGERATOR
Whirlpool CS22AFXKS06 REFRIGERATOR
Whirlpool CS22AFXKT00 REFRIGERATOR
Whirlpool CS22AFXKT01
Whirlpool CS22AFXKT03 REFRIGERATOR
Whirlpool CS22AFXKT04 REFRIGERATOR
Whirlpool CS22AFXKT05 REFRIGERATOR
Whirlpool CS22AFXKT06 REFRIGERATOR
Whirlpool CS22CFXTB00 REFRIGERATOR
Whirlpool CS22CFXTB01 REFRIGERATOR
Whirlpool CS22CFXTQ00 REFRIGERATOR
Whirlpool CS22CFXTQ01 REFRIGERATOR
Whirlpool CS22CFXTS00 REFRIGERATOR
Whirlpool CS22CFXTS01 REFRIGERATOR
Whirlpool CS22CFXTS02 REFRIGERATOR
Whirlpool CS22CFXTS03 REFRIGERATOR
Whirlpool CS22CFXTT00 REFRIGERATOR
Whirlpool CS22CFXTT01 REFRIGERATOR
Whirlpool CS22TKXNQ00 REFRIGERATOR
Crosley CS22Y7DA REF - SXS/I&W
Crosley CS22Y7DW REF - SXS/I&W
Crosley CS23A6DA REF - SXS/I&W
Crosley CS23A6DW REF - SXS/I&W
Crosley CS23B5A REF - SXS/I&W
Crosley CS23B5Q REF - SXS/I&W
Crosley CS23B5W REF - SXS/I&W
Crosley CS23B6DA REF - SXS/I&W
Crosley CS23B6DQ REF - SXS/I&W
Crosley CS23B6DW REF - SXS/I&W
Crosley CS23G5Q REF - SXS/I&W
Crosley CS23G5W REF - SXS/I&W
Crosley CS24G6DB REF - SXS/I&W
Crosley CS24G6DQ REF - SXS/I&W
Crosley CS24G6DW REF - SXS/I&W
Crosley CS25A7DA REF - SXS/I&W
Crosley CS25A7DB REF - SXS/I&W
Crosley CS25A7DQ REF - SXS/I&W
Crosley CS25A7DW REF - SXS/I&W
Whirlpool CS25AEXHN00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AEXHW00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKQ00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKQ01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKQ02 REFRIGERATOR
Whirlpool CS25AFXKQ03 REFRIGERATOR
Whirlpool CS25AFXKQ04 REFRIGERATOR
Whirlpool CS25AFXKQ05 REFRIGERATOR
Whirlpool CS25AFXKT00 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKT01 SIDE-BY-SIDE REFRIGERATOR
Whirlpool CS25AFXKT02 REFRIGERATOR
Whirlpool CS25AFXKT03 REFRIGERATOR
Whirlpool CS25AFXKT04 REFRIGERATOR
Whirlpool CS25AFXKT05 REFRIGERATOR
Crosley CS25B7DB REF - SXS/I&W
Crosley CS25B7DQ REF - SXS/I&W
Crosley CS25B7DW REF - SXS/I&W
Whirlpool CS25CFXTQ00 REFRIGERATOR
Whirlpool CS25CFXTQ01 REFRIGERATOR
Crosley CS26G3W REF - SXS
Crosley CS26G7DQ REF - SXS/I&W
Crosley CS26G7DW REF - SXS/I&W
Crosley CS26G8DB REF - SXS/I&W
Crosley CS26G8DQ REF - SXS/I&W
Crosley CS26G8DW REF - SXS/I&W
Crosley CS26G8DZ REF - SXS/I&W
Crosley CS26G9DB REF - SXS/I&W
Crosley CS26G9DQ REF - SXS/I&W
Crosley CS26G9DW REF - SXS/I&W
Crosley CS26G9DZ REF - SXS/I&W
Crosley CS27G6DB REF - SXS/I&W
Crosley CS27G6DQ REF - SXS/I&W
Crosley CS27G6DW REF - SXS/I&W
Whirlpool CS5000XSW0 Residential Dryer
Whirlpool CS5000XSW1 Residential Dryer
Whirlpool CS5000XWW0 Residential Dryer
Whirlpool CS5005XWW0 Residential Dryer
Whirlpool CS5100XSW0 Residential Dryer
Whirlpool CS5100XSW1 Residential Dryer
Whirlpool CS5100XWW0 Residential Dryer
Whirlpool CS5105XWW0 Residential Dryer
General Electric CS980SN1SS ELECTRIC RANGE
  #2 (permalink)
Old 06-19-2017, 11:12 PM
Junior Member
Talking Yeaaaah, fixed it. Broken wire connector at male motor connector
Kept messing with it most of afternoon, kept thinking that motor was just 'weak', not able to turn tub enough to make a complete rotation without help, especially if you had anything in it other than just water.�� Just started looking for anything that seemed out of place, took motor speed controller out, fuse checked ok, no obvious burn marks, etc. checked wiring harness from controller back to motor. Tugged and pushed lightly on wires on front (female) of motor plug, everything seemed ok...when I pushed on back side of motor plug, saw a small spark, and motor immediately got a burst of energy and turned drum a couple of complete rotations. Soon as I let off it slowed back down, and stopped. Turned off machine, unplugged, pulled back of motor plug connector (male) off and started checking the six wires. Was #1 (pink/white stripe) according to tech sheet wiring diagram. The wire was completely broken from the small "tube" connector still inside the male side of the plug, and came right out. I pushed the tube out using a small pop rivet, cut the broken piece off the end of the wire, re-stripped longer portion of the wire, inserted it back into the tube about 1/4 inch and and crimped. Inserted it back in plug, reconnected male to female plug. Plugged machine in, set timer, it immediately started turning, complete rotations went through complete cycle correctly, including final spin, at high speed. Did a full load after that, ran perfectly, full power. Spin cycle actually seems faster than it has been recently.
The wire harness at the motor did not seem to have enough play and the wire was zip tied somewhat stationary to the bottom frame of the washer, so if the motor/drum moved up and down much, it seemed to be almost bending the wires at the motor plug a tiny bit, which I guess eventually broke one. I made a little more play, and made it where the wire at the motor plug moved WITH the motor. Anyway, hope this helps someone else who may have this problem. I was thinking it was going to be the motor controller board - glad it wasn't. Looks like this wire goes directly to the motor winding which would explain the slow, weakness of motor. Sure was doing some weird things because of one little wire. Anyway, learned a whole lot about my machine from this forum, next time I'll be better prepared...��
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire Front Load washer won't agitate or spin ded Washer Repair 0 06-17-2016 09:16 AM
Frigidaire front load - no high speed spin - small load bobbyp66 Dishwasher Repair 0 02-28-2015 06:44 AM
GE Front Load won't agitate or spin Popi22 Washer Repair 2 07-02-2010 09:31 AM
Kenmore front load won't agitate or spin aimlessfixr Washer Repair 2 12-07-2009 03:37 AM
front load washer will not agitate or spin shadpch Washer Repair 1 11-08-2008 05:08 PM
