Discuss
Kenmore 500 Washer - No Warm (hot/cold work)
 in
Washer Repair
Hot fill works fine. Cold fill works fine. When warm is selected, the fill begins warm, but cycles to cold
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore 500 Washer - No Warm (hot/cold work)
  #1 (permalink)
Old 06-17-2017, 04:17 PM
Junior Member
Old&Slow is on a distinguished road
Default Kenmore 500 Washer - No Warm (hot/cold work)
Model Number: 110.29522801   Brand: Kenmore   Age: 5 - 10 years
Hot fill works fine. Cold fill works fine. When warm is selected, the fill begins warm, but cycles to cold after about 20 seconds, and never cycles back.
History: The fill valve stuttered badly, and was replaced. The temperature selector switch was also replaced.
This washer is pretty basic with no electronics or control board that I can see. I suspect the replacement fill valve may have a bad thermistor, but I cannot find any information on how to troubleshoot it. I would appreciate any thoughts on getting warm water to work. I know the machine is old, but it works fine, and I don't see replacing it right now.
Thanks for your thoughts.
Related Models
Hoover 1100
Kenmore 110088732791 WASHER/DRYER LAUNDRY SYSTEM
Magic Chef 1100PAA RANGE- F/S STD GAS
Magic Chef 1100PAW RANGE- F/S STD GAS
Magic Chef 1100PAW-K RANGE- F/S STD GAS
Magic Chef 1100PAW-KL RANGE- F/S STD GAS
Magic Chef 1100PAW-L RANGE- F/S STD GAS
Magic Chef 1100PRA RANGE- F/S STD GAS
Magic Chef 1100PRA-K RANGE- F/S STD GAS
Magic Chef 1100PRW RANGE- F/S STD GAS
Magic Chef 1100PRW-K RANGE- F/S STD GAS
Kenmore 11010202000 COMPACT WASHER
Kenmore 11010202001 WASHER
Kenmore 11010502990 AUTOMATIC WASHER
Kenmore 11010502991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11010852990 AUTOMATIC WASHER
Kenmore 11010852991 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012202100 WASHER
Kenmore 11012502100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11012852100 AUTOMATIC WASHER, COMPACT A/W
Kenmore 11013202200 WASHER
Kenmore 11013212200 AUTOMATIC WASHER
Kenmore 11014102300 AUTOMATIC WASHER
Kenmore 11014112300 AUTOMATIC WASHER
Kenmore 11014202300 AUTOMATIC WASHER
Kenmore 11014212200 AUTOMATIC WASHER
Kenmore 11014222300 AUTOMATIC WASHER
Kenmore 11014502300 AUTOMATIC WASHER
Kenmore 11014852300 AUTOMATIC WASHER
Kenmore 11015732400 WASHER
Kenmore 11015842400 WASHER
Kenmore 11015852400 WASHER
Kenmore 11015862400 WASHER
Kenmore 11015864400 WASHER
Kenmore 11015942400 RESIDENTIAL WASHER
Kenmore 11015942401 RESIDENTIAL WASHER
Kenmore 11015944400 RESIDENTIAL WASHER
Kenmore 11015944401 RESIDENTIAL WASHER
Kenmore 11015952400 RESIDENTIAL WASHER
Kenmore 11015952401 RESIDENTIAL WASHER
Kenmore 11015954400 RESIDENTIAL WASHER
Kenmore 11015954401 RESIDENTIAL WASHER
Kenmore 11015962400 RESIDENTIAL WASHER
Kenmore 11015962401 RESIDENTIAL WASHER
Kenmore 11015964400 RESIDENTIAL WASHER
Kenmore 11015964401 RESIDENTIAL WASHER
Kenmore 11016101690 AUTOMATIC WASHER
Kenmore 11016101691 AUTOMATIC WASHER
Kenmore 11016102500 WASHER
Kenmore 11016102501 RESIDENTIAL WASHER
Kenmore 11016102502 RESIDENTIAL WASHER
Kenmore 11016202690 WASHER
Kenmore 11016202691 AUTOMATIC WASHER
Kenmore 11016212500 WASHER
Kenmore 11016212501 WASHER
Kenmore 11016212502 RESIDENTIAL WASHER
Kenmore 11016212503 RESIDENTIAL WASHER
Kenmore 11016502690 WASHER
Kenmore 11016502691 AUTOMATIC WASHER
Kenmore 11016502692 AUTOMATIC WASHER
Kenmore 11016502693 AUTOMATIC WASHER
Kenmore 11016502694 AUTOMATIC WASHER
Kenmore 11016512690 WASHER
Kenmore 11016512691 AUTOMATIC WASHER
Kenmore 11016512692 AUTOMATIC WASHER
Kenmore 11016602690 AUTOMATIC WASHER
Kenmore 11016602691 AUTOMATIC WASHER
Kenmore 11016602692 AUTOMATIC WASHER
Kenmore 11016602693 AUTOMATIC WASHER
Kenmore 11016611690 AUTOMATIC WASHER
Kenmore 11016611691 AUTOMATIC WASHER
Kenmore 11016611692 AUTOMATIC WASHER
Kenmore 11016612690 AUTOMATIC WASHER
Kenmore 11016612691 AUTOMATIC WASHER
Kenmore 11016612692 AUTOMATIC WASHER
Kenmore 11016732500 WASHER
Kenmore 11016812500 WASHER
Kenmore 11016812501 WASHER
Kenmore 11016812502 RESIDENTIAL WASHER
Kenmore 11016812503 RESIDENTIAL WASHER
Kenmore 11016852500 WASHER
Kenmore 11016852501 WASHER
Kenmore 11016852502 WASHER
Kenmore 11016852503 WASHER
Kenmore 11016862500 RESIDENTIAL WASHER
Kenmore 11016862501 WASHER
Kenmore 11016862502 WASHER
Kenmore 11016862503 RESIDENTIAL WASHER
Kenmore 11016872690 WASHER
Kenmore 11016872691 AUTOMATIC WASHER
Kenmore 11016872692 AUTOMATIC WASHER
Kenmore 11016872693 AUTOMATIC WASHER
Kenmore 11016882500 RESIDENTIAL WASHER
Kenmore 11016882501 WASHER
Kenmore 11016882502 WASHER
Kenmore 11016882503 RESIDENTIAL WASHER
Kenmore 11016922500 WASHER
Kenmore 11016922501 RESIDENTIAL WASHER
Kenmore 11016922502 WASHER
Kenmore 11016922503 WASHER
Kenmore 11016922504 RESIDENTIAL WASHER
Kenmore 11016942500 WASHER
Kenmore 11016942501 WASHER
Kenmore 11016942502 WASHER
Kenmore 11016942503 RESIDENTIAL WASHERS
Kenmore 11016962500 WASHER
Kenmore 11016962501 WASHER
Kenmore 11016962502 WASHER
Kenmore 11016962503 RESIDENTIAL WASHERS
Kenmore 11016964500 WASHER
Kenmore 11016964501 WASHER
Kenmore 11016964502 WASHER
Kenmore 11016964503 RESIDENTIAL WASHERS
Kenmore 11016972500 WASHER
Kenmore 11016982500 WASHER
Kenmore 11016984500 WASHER
Kenmore 11016986500 WASHER
Kenmore 11017102700 RESIDENTIAL WASHER
Kenmore 11017122700 RESIDENTIAL WASHER
Kenmore 11017132700 RESIDENTIAL WASHER
  #2 (permalink)
Old 06-18-2017, 06:59 AM
Senior Member
brobriffin is on a distinguished road
Default
Keep in mind the temp selector switch might be at fault. If you still have the old one try it.
  #3 (permalink)
Old 06-18-2017, 03:44 PM
Junior Member
Default
Thank you for the reply, brobriffin. Neither the original nor the replacement temperature selector switch affects the issue. When set to warm, I initially get warm water, but after about 20 seconds, the hot shuts off and does not cycle back on.
Is it possible to test the thermistor or otherwise troubleshoot this issue? I truly hate to throw parts at a problem.
Thanks!
  #4 (permalink)
Old 06-18-2017, 07:25 PM
Senior Member
Default
When you say you initially get warm is it actually warm to the touch, is your hot water tank so close that it comes through the line within 20 seconds?
You said in original post 'hot fill works fine' and 'cold fill works fine'
is there any chance the hot and cold lines are on backwards?
If the temperature selector switch is good and the water lines are connected properly it is very likely the thermistor isn't functioning properly.
You can test the thermistor however after researching I can not find what the resistance in ohms should read.
Although your other valves shuttered perhaps its thermister is good, try taking a reading from both your old and new then compare the readings. The resistance reading should decrease as the temperature increases.
  #5 (permalink)
Old 06-19-2017, 05:26 AM
Junior Member
Default
Thanks again for the quick response!
When set to hot, the water is hot. Same for cold. This tells me the temperature selector is working correctly and the lines are not reversed.
The water heater is adjacent to the washer, and hot is very quick. It is a large gas heater with plenty of reserve. The lines are connected correctly and the filters are clean. Flow from both hot and cold are strong.
To date I have replaced the fill valve, the temperature selector switch, checked the hoses for proper connection, and inspected all connections and wires for a possible break. The problem continues to be the same:
When set to warm, the water is initially mixed and warm water is provided. After a period of time, the hot valve shuts off, and only cold is delivered, resulting in a cold wash.
My issue does not seem to be typical. Unfortunately, I do not have the old fill valve or another one to compare resistance. I will try to find a schematic for the machine to see if there could be any other reasons for this. The old paper schematic is gone.
Thanks!
  #6 (permalink)
Old 06-19-2017, 07:20 AM
Senior Member
Default
I found the wiring diagram. Unfortunately it doesn't show the resistance rating of the thermistor.
File Type: pdf Service-and-Wiring-W10183468-Rev-C - Copy.pdf (258.7 KB, 2 views)
  #7 (permalink)
Old 06-19-2017, 01:25 PM
Junior Member
Default
Thank you for the wiring diagram. It pretty much assures me there is nothing else in the circuit that could cause this issue. I appreciate the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore fridge warm freezer cold jmillsone50 Refrigerator & Freezer Repair 0 04-03-2017 09:27 AM
Kenmore Freezer cold/ fridge warm dsandwich123 Refrigerator & Freezer Repair 4 09-26-2012 12:33 AM
Kenmore Freezer Cold-Refrig Warm compustar Refrigerator & Freezer Repair 0 09-27-2011 05:20 AM
Kenmore - Freezer Cold / Fridge warm Rush2112 Refrigerator & Freezer Repair 1 09-30-2009 09:37 AM
Kenmore Freezer Cold, Refrigerator Warm Mark001 Refrigerator & Freezer Repair 2 04-11-2008 10:43 PM
