Discuss
Noise during the fast spin cycle, but not slow spin cycle
 in
Washer Repair
The machine works fine until the spin cycle. When it is on the slow spin cycle (hang dry) there is
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Noise during the fast spin cycle, but not slow spin cycle
  #1 (permalink)
Old 06-17-2017, 11:18 AM
Junior Member
onthego4858 is on a distinguished road
Default Noise during the fast spin cycle, but not slow spin cycle
Model Number: 11026912691   Brand: Kenmore   Age: More than 10 years
The machine works fine until the spin cycle. When it is on the slow spin cycle (hang dry) there is no noise. When it is in the fast spin cycle (regular) , it makes a loud noise. Replaced the pump to be on the safe side- not the problem. The washer does it job other than the noise in that one speed when spinning out. It spins out fine even with the noise. Any help is appreciated.
Related Models
Kenmore 11026912691 AUTOMATIC WASHER
Kenmore 11026914690 WASHER
Kenmore 11026914691 AUTOMATIC WASHER
Kenmore 11026922500 WASHER
Kenmore 11026922501 WASHER
Kenmore 11026922502 WASHER
Kenmore 11026922503 RESIDENTIAL WASHERS
Kenmore 11026924500 WASHER
Kenmore 11026924501 WASHER
Kenmore 11026924502 WASHER
Kenmore 11026924503 RESIDENTIAL WASHERS
Kenmore 11026932690 Residential Washers
Kenmore 11026932691 Residential Washers
Kenmore 11026934690 Residential Washers
Kenmore 11026934691 Residential Washers
Kenmore 11026942500 WASHER
Kenmore 11026942501 WASHER
Kenmore 11026942502 WASHER
Kenmore 11026942503 RESIDENTIAL WASHERS
Kenmore 11026944500 WASHER
Kenmore 11026944501 WASHER
Kenmore 11026944502 WASHER
Kenmore 11026944503 RESIDENTIAL WASHERS
Kenmore 11026952690 AUTOMATIC WASHER
Kenmore 11026952691 AUTOMATIC WASHER
Kenmore 11026954690 AUTOMATIC WASHER
Kenmore 11026954691 AUTOMATIC WASHER
Kenmore 11026955690 AUTOMATIC WASHER
Kenmore 11026955691 AUTOMATIC WASHER
Kenmore 11026962500 WASHER
Kenmore 11026962501 WASHER
Kenmore 11026962502 WASHER
Kenmore 11026962503 RESIDENTIAL WASHERS
Kenmore 11026964500 WASHER
Kenmore 11026964501 RESIDENTIAL WASHER
Kenmore 11026964502 WASHER
Kenmore 11026964503 RESIDENTIAL WASHERS
Kenmore 11026966500 RESIDENTIAL WASHER
Kenmore 11027032600 WASHER
Kenmore 11027032601 AUTOMATIC WASHER
Kenmore 11027032602 RESIDENTIAL WASHER
Kenmore 11027032603 RESIDENTIAL WASHER
Kenmore 11027042600 WASHER
Kenmore 11027042601 RESIDENTIAL WASHERS
Kenmore 11027042602 RESIDENTIAL WASHER
Kenmore 11027042603 RESIDENTIAL WASHER
Kenmore 11027052600 RESIDENTIAL WASHERS
Kenmore 11027052601 RESIDENTIAL WASHER
Kenmore 11027052602 RESIDENTIAL WASHER
Kenmore 11027062600 WASHER
Kenmore 11027062601 RESIDENTIAL WASHER
Kenmore 11027062602 RESIDENTIAL WASHER
Kenmore 11027062603 RESIDENTIAL WASHER
Kenmore 11027062604 RESIDENTIAL WASHER
Kenmore 11027072600 WASHER
Kenmore 11027072601 RESIDENTIAL WASHER
Kenmore 11027072602 RESIDENTIAL WASHER
Kenmore 11027072603 RESIDENTIAL WASHER
Kenmore 11027072604 RESIDENTIAL WASHER
Kenmore 11027082600 RESIDENTIAL WASHER
Kenmore 11027082601 RESIDENTIAL WASHER
Kenmore 11027082602 RESIDENTIAL WASHER
Kenmore 11027082603 WASHER
Kenmore 11027082604 RESIDENTIAL WASHER
Kenmore 11027082605 RESIDENTIAL WASHER
Kenmore 11027086601 RESIDENTIAL WASHER
Kenmore 11027086602 RESIDENTIAL WASHER
Kenmore 11027086603 RESIDENTIAL WASHER
Kenmore 11027086604 RESIDENTIAL WASHER
Kenmore 11027086605 RESIDENTIAL WASHER
Kenmore 11027087600 RESIDENTIAL WASHER
Kenmore 11027087601 RESIDENTIAL WASHER
Kenmore 11027087602 RESIDENTIAL WASHER
Kenmore 11027087603 RESIDENTIAL WASHER
Kenmore 11027087604 RESIDENTIAL WASHER
Kenmore 11027087605 RESIDENTIAL WASHER
Kenmore 11027092600 WASHER
Kenmore 11027092601 RESIDENTIAL WASHER
Kenmore 11027092602 RESIDENTIAL WASHER
Kenmore 11027092603 RESIDENTIAL WASHER
Kenmore 11027112600 WASHER
Kenmore 11027152600 AUTOMATIC WASHER
Kenmore 11027152601 RESIDENTIAL WASHER
Kenmore 11027152602 RESIDENTIAL WASHER
Kenmore 11027172600 WASHER
Kenmore 11027222600 RESIDENTIAL WASHERS
Kenmore 11027224600 RESIDENTIAL WASHERS
Kenmore 11027272600 WASHER
Kenmore 11027322600 RESIDENTIAL WASHERS
Kenmore 11027332600 RESIDENTIAL WASHERS
Kenmore 11027342600 RESIDENTIAL WASHERS
Kenmore 11027422600 RESIDENTIAL WASHERS
Kenmore 11027432600 RESIDENTIAL WASHERS
Kenmore 11027442600 RESIDENTIAL WASHER
Kenmore 11027522600 RESIDENTIAL WASHERS
Kenmore 11027532600 RESIDENTIAL WASHERS
Kenmore 11027542600 RESIDENTIAL WASHER
Kenmore 11027612600 RESIDENTIAL WASHERS
Kenmore 11027622790 AUTOMATIC WASHER
Kenmore 11027622791 AUTOMATIC WASHER
Kenmore 11027632600 RESIDENTIAL WASHERS
Kenmore 11027642600 RESIDENTIAL WASHERS
Kenmore 11027721600 RESIDENTIAL WASHER
Kenmore 11027731600 RESIDENTIAL WASHERS
Kenmore 11027741600 RESIDENTIAL WASHERS
Kenmore 11027751700 RESIDENTIAL WASHER
Kenmore 11027761700 RESIDENTIAL WASHER
Kenmore 11027782700 RESIDENTIAL WASHER
Kenmore 11027802690 AUTOMATIC WASHER
Kenmore 11027802691 AUTOMATIC WASHER
Kenmore 11027812690 AUTOMATIC WASHER
Kenmore 11027812691 AUTOMATIC WASHER
Kenmore 11027812692 AUTOMATIC WASHER
Kenmore 11027822790 AUTOMATIC WASHER
Kenmore 11027824790 AUTOMATIC WASHER
Kenmore 11027831600 RESIDENTIAL WASHER
Kenmore 11027841600 RESIDENTIAL WASHERS
Kenmore 11027852790 AUTOMATIC WASHER
Kenmore 11027852791 AUTOMATIC WASHER
Kenmore 11027862790 AUTOMATIC WASHER
  #2 (permalink)
Old 06-18-2017, 06:31 PM
Senior Member
brobriffin is on a distinguished road
Default
Its hard to say without actually hearing the sound and where it comes from.
Is there any way you could take a video when its fast spinning to show us the noise.
shoot the video from the front, from the top, from the top with the lid open, and although we won't see anything shoot from the bottom
then give us a link to your you tube posting so we can see and hear what you hear.
  #3 (permalink)
Old 06-19-2017, 04:20 PM
Junior Member
Default
Did another load of laundry- story of my life. The noise is starting between the end of the wash cycle when the rinse begins. When the water starts to drain out, the noise starts on either speed. The noise will stop when it spins in slow and is still present in fast. The same thing in the second rinse cycle.
I will have to have my kids help me with the YouTube posting of the video and let you know the link. Thank you for your reply.
  #4 (permalink)
Old 06-27-2017, 06:21 PM
Junior Member
Default
https://youtu.be/1jhCwp5K7AY
  #5 (permalink)
Old 06-28-2017, 05:13 AM
Senior Member
Default
Does the basket actually spin while it is making this noise?
Do the clothes get spun dry or are they still soaking wet after the load is done?
If the basket does spin then I suspect that sound is a bearing in the motor going bad. It is the same sound my well pump made just before the bearings disintegrated.
If that is true life is not over as this is a relatively cheap repair these machines are workhorses and can last 25 plus years with a little maintenance.
See part #
Whirlpool WP3352287 Motor-Drive - AppliancePartsPros.com
Also watch the video with this link (coupler but not your issue) to see how to remove and replace the motor, pretty simple I'd say.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
  #6 (permalink)
Old 06-28-2017, 06:07 PM
Junior Member
Default
The basket spins during the rinse and spin cycle. The clothes spin dry. The only time the noise goes away is during the second half of the rinse cycle when it spins out on the slow speed. The motor is about the only thing that has not been replaced on this machine. I appreciate your help.
  #7 (permalink)
Junior Member
Default
  #8 (permalink)
Old 06-29-2017, 10:39 AM
Junior Member
Default
Just wondering why you thought it was the motor. Would it cause it make noise in the rinse and spin cycle , but not the agitation phase? I like to try to understand these things. Talking to a friend about my washer and he mentioned the washer drive basket. Any thoughts?
  #9 (permalink)
Old 06-29-2017, 03:30 PM
Senior Member
Default
I believe if it were the basket we would hear the noise but at a different level when spinning in slow speed.
The motor spins ccw in agitation mode and slower than when in fast spin mode and spins cw to drain and spin. Now if a bearing is going bad it makes sense that we hear the sound when the motor is spinning the fastest in (fast spin cycle) but not when in slower speed. I would imagine as the bearing gets worse you might pick up the sound even in slow speed and in agitation as well.
Secondly I recognize that same sound when the bearing was going bad in my shallow well pump motor.
Again I am not there and as I said I suspect that is it.
To see try removing the motor put some good lubricant (like 3 n 1 oil) on each bearing and retry fast spin. If the noise is diminished or gone you have verified bad bearings.
  #10 (permalink)
Old 06-29-2017, 06:07 PM
Junior Member
Default
I understand what you are saying about the motor. Thanks for explaining.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Noise during the fast spin cycle, but not slow spin cycle onthego4858 Washer Repair 0 06-17-2017 11:15 AM
Wont complete drain cycle Spin cycle slow TimMulvihill15 Washer Repair 0 08-17-2015 05:33 PM
Washer won't spin fast in the spin cycle to wring clothes Gborrayo Washer Repair 0 02-10-2014 06:15 PM
whirlpool cabrio wtw6400sw2 skips rinse cycle doesn't spin fast in wash cycle jwilman Washer Repair 0 09-13-2012 04:45 PM
Washer makes loud noise when agitating & spin cycle is very slow PBR61 Washer Repair 1 03-11-2011 07:31 AM
