Discuss
Spins fine, couple days later about 2" of water in drum
 in
Washer Repair
GE Washer Model WPRE6100G0WT. everything works fine except after sitting a day or 2 there is about 2 inches of
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Spins fine, couple days later about 2" of water in drum
  #1 (permalink)
Old 06-17-2017, 09:42 AM
Junior Member
robert317 is on a distinguished road
Default Spins fine, couple days later about 2" of water in drum
Brand: GE   Age: 5 - 10 years
GE Washer Model WPRE6100G0WT. everything works fine except after sitting a day or 2 there is about 2 inches of water in the tub. Forums seem to point to pump but those are usually for no draining at all.
  #2 (permalink)
Old 06-17-2017, 10:56 AM
Senior Member
brobriffin is on a distinguished road
Default
Are you saying that after you have finished a load and it has spun and drained properly you go back after not using the machine for two days and find water in it?
If this is the case it sounds as though your water inlet valve (either hot or cold) is stuck partially open or has debris in the seal allowing water to seep by.
They are cheap enough to replace.
GE WH13X10024 Washer Water Inlet Valve - AppliancePartsPros.com
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Once every couple of days, water found on the floor Joe X. Refrigerator & Freezer Repair 0 08-11-2013 02:46 PM
Tub spins fine but does not stabilize, or "center" itself Richard H Washer Repair 1 04-18-2011 12:06 PM
Bosch Nexxt stopped spinning the water out. Drum turns fine. nbreyes2003 Washer Repair 1 01-09-2010 10:05 PM
Washer is "dancing" more these days gustavio Washer Repair 6 04-05-2008 05:35 AM
