Discuss
No Hot or warm water
 in
Washer Repair
No hot or cold water. Changed temperature switch. No help. Changed water inlet and sensor just in case and no
Appliance Repair Forum > Appliance Repair Help > Washer Repair » No Hot or warm water
  #1 (permalink)
Old 06-16-2017, 08:56 AM
Junior Member
invader37 is on a distinguished road
Question No Hot or warm water
Model Number: 16852503   Brand: Kenmore   Age: More than 10 years
No hot or cold water. Changed temperature switch. No help. Changed water inlet and sensor just in case and no help. Get 120v at cold valve with switch set at "Cold", but only getting 2v at Hot valve when switch set at"Hot'. Checked resistance on Inlet assemblies and they are the same on both new and old. Is new switch bad the only option left?
Related Models
Hoover 168691
Magic Chef 16RA-3B RV RANGE- GAS
Magic Chef 16RA-3B-49 RV RANGE- GAS
Magic Chef 16RA-3BK RV RANGE- GAS
Magic Chef 16RA-3BKZ RV RANGE- GAS
Magic Chef 16RA-3BT RV RANGE- GAS
Magic Chef 16RA-3BT49 RV RANGE- GAS
Magic Chef 16RA-3BTZ RV RANGE- GAS
Magic Chef 16RA-3BZ RV RANGE- GAS
Magic Chef 16RA-4 RV RANGE- GAS
Magic Chef 16RA-4K RV RANGE- GAS
Magic Chef 16RA-4KZ RV RANGE- GAS
Magic Chef 16RA-4T RV RANGE- GAS
Magic Chef 16RA-4TZ RV RANGE- GAS
Magic Chef 16RA-4Z RV RANGE- GAS
Magic Chef 16RB-3B RV RANGE- GAS
Magic Chef 16RB-3BT RV RANGE- GAS
Magic Chef 16RB-3BTZ RV RANGE- GAS
Magic Chef 16RB-3BZ RV RANGE- GAS
Magic Chef 16RB-4 RV RANGE- GAS
Magic Chef 16RB-4KZ RV RANGE- GAS
Magic Chef 16RB-4TZ RV RANGE- GAS
Magic Chef 16RB-4Z RV RANGE- GAS
Magic Chef 16RS-4 RV RANGE- GAS
Magic Chef 16RS-4K RV RANGE- GAS
Magic Chef 16RS-4T RV RANGE- GAS
Magic Chef 16RS-4Z RV RANGE- GAS
Magic Chef 16RW-3B RV RANGE- GAS
Magic Chef 16RW-3B-49 RV RANGE- GAS
Magic Chef 16RW-3BK RV RANGE- GAS
Magic Chef 16RW-3BKZ RV RANGE- GAS
Magic Chef 16RW-3BT RV RANGE- GAS
Magic Chef 16RW-3BT49 RV RANGE- GAS
Magic Chef 16RW-3BTZ RV RANGE- GAS
Magic Chef 16RW-4 RV RANGE- GAS
Magic Chef 16RW-4K RV RANGE- GAS
Magic Chef 16RW-4KZ RV RANGE- GAS
Magic Chef 16RW-4T RV RANGE- GAS
Magic Chef 16RW-4TZ RV RANGE- GAS
Magic Chef 16RW-4Z RV RANGE- GAS
Magic Chef 16TA-3B-49 RV RANGE- GAS
Magic Chef 16TA-3BK49 RV RANGE- GAS
Magic Chef 16TA-3BZ RV RANGE- GAS
Magic Chef 16TA-4Z RV RANGE- GAS
Magic Chef 16TB-3B RV RANGE- GAS
Magic Chef 16TB-3BK RV RANGE- GAS
Magic Chef 16TB-3BZ RV RANGE- GAS
Magic Chef 16TB-4 RV RANGE- GAS
Magic Chef 16TW-3B RV RANGE- GAS
Magic Chef 16TW-3B-49 RV RANGE- GAS
Magic Chef 16TW-3BK RV RANGE- GAS
Magic Chef 16TW-3BK49 RV RANGE- GAS
Magic Chef 16TW-3BKE RV RANGE- GAS
Magic Chef 16TW-3BKZ RV RANGE- GAS
Magic Chef 16TW-3BZ RV RANGE- GAS
Magic Chef 16TW-4KZ RV RANGE- GAS
Thermador 1701
Amana 1708.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1708.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1709.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1709.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1718.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1718.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1720.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1736.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1736.001 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1739.001 MWAVE - FAMILY SIZE (60 HZ)
Whirlpool 1743W0A
Roper 1745*0A 30" GAS DOUBLE OVEN RANGE
Roper 1745W0A 30" GAS DOUBLE OVEN RANGE
Amana 1750.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.000 MWAVE - FAMILY SIZE (60 HZ)
Amana 1752.001 MWAVE - FAMILY SIZE (60 HZ)
Kenmore 17550125 GARBAGE DISPOSAL
Kenmore 17560101 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560102 DISPOSER
Kenmore 17560110 KENMORE DISPOSER
Kenmore 17560111 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560111X KENMORE DISPOSER
Kenmore 17560115 KENMORE DISPOSER
Kenmore 17560120 KENMORE DISPOSER
Kenmore 17560121 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560122 KENMORE DISPOSER
Kenmore 17560130 KENMORE DISPOSER
Kenmore 17560131 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560135 KENMORE DISPOSER
Kenmore 17560200 FOOD WASTE DISPOSER
Kenmore 17560300 KENMORE DISPOSER
Kenmore 17560350 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560351X KENMORE DISPOSER
Kenmore 17560400 KENMORE DISPOSER
Kenmore 17560400A KENMORE DISPOSER
Kenmore 17560401 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560450 DISPOSER
Kenmore 17560451 DISPOSER
Kenmore 17560452 DISPOSER
Kenmore 17560500 KENMORE DISPOSER
Kenmore 17560500A KENMORE DISPOSER
Kenmore 17560500X KENMORE DISPOSER
Kenmore 17560501 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560503 KENMORE DISPOSER
Kenmore 17560504 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560504X KENMORE DISPOSER
Kenmore 175605090 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560510 KENMORE DISPOSER
Kenmore 17560510A KENMORE DISPOSER
Kenmore 17560511 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605140 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605150 DISPOSER (IN-SINK-ERATOR)
Kenmore 175605160 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560517X KENMORE DISPOSER
Kenmore 175605250 DISPOSER (IN-SINK-ERATOR)
Kenmore 17560542 KENMORE HOT WATER DISPENSER
Kenmore 175605520 DISPOSER
Kenmore 17560552CE DISPOSER
Kenmore 175605530 DISPOSER
Kenmore 175605540 DISPOSER
Kenmore 17560554CE DISPOSER
  #2 (permalink)
Old 06-16-2017, 09:00 AM
Junior Member
Default
Quote:
Question should read no Hot or warm water.
  #3 (permalink)
Old 06-16-2017, 09:01 AM
Junior Member
Default
No hot or warm water. Changed temperature switch. No help. Changed water inlet and sensor just in case and no help. Get 120v at cold valve with switch set at "Cold", but only getting 2v at Hot valve when switch set at"Hot'. Checked resistance on Inlet assemblies and they are the same on both new and old. Is new switch bad the only option left?
  #4 (permalink)
Old 06-16-2017, 12:59 PM
Senior Member
brobriffin is on a distinguished road
Default
First rule out bad hot valve.
change the wires from the cold valve to the hot valve. run a cold cycle and see if hot valve opens.
  #5 (permalink)
Old 06-16-2017, 02:35 PM
Junior Member
Question invader
I had actually switched the hot and cold inputs before installing the new switch. Not having a wiring diagram. I changed the valve assembly thinking maybe the sensor might be able to shut off the hot if the sensor was bad,
  #6 (permalink)
Old 06-16-2017, 05:34 PM
Senior Member
Default
this model does not appear to have an actual temp sensor
it is controlled by the water temp switch
ok so when you had the wiring backwards did the hot water work?
  #7 (permalink)
Old 06-16-2017, 06:34 PM
Junior Member
Default invader
Yes, I had hot water with the cold line connected to hot valve input
  #8 (permalink)
Old 06-17-2017, 09:18 AM
Senior Member
Default
Ok so the valve is not the issue.
Like you said you were only getting 2 volts to the hot water side.
Therefore your water temp switch is likely the culprit here.
Now for the bad news, whirlpool has discontinued this part.
It may be available with a search thru the web or other secondary aftermarkets.
The part number you will nee to look for is 8571735
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Cold Or Warm Water, Only Hot Water Tulsi Washer Repair 4 09-03-2016 08:09 PM
Cold water dispenser produces warm water Thumbzup Refrigerator & Freezer Repair 1 04-12-2015 08:05 PM
warm wash water mgcvitak Washer Repair 1 06-21-2011 07:07 PM
Cold water in warm water settings Douglas Doty Washer Repair 1 06-03-2008 09:12 AM
Whirlpool LA5300XM Cold water trickles, warm water flows properly ajaysheetal Washer Repair 2 02-14-2008 04:49 PM
