lphillips521
#1 Posted : Thursday, June 8, 2017 12:38:56 PM(UTC)
lphillips521
Bosch AXXIS Washer WAS20160UC
The washer fills with water but will not agitate or spin out. When the spinning/agitation should happen a clicking sound is made in the upper front of the machine. The machine is draining fine and there is nothing blocking the drain.
The machine is plugged into the dryer and there is 124V + 124V going to the washer from the dryer, so there is 240V going to the dryer.
There are 7 blue wires going into the motor. Their Volt readings in order top to bottom are:
9
9
9
124
9
124
124
I don't know what else to check or what this all means! Thank you!!
Bosch washer not spinning out all the water (Washer Repair)
by gschvach 11/18/2013 1:59:02 PM(UTC)
