Discuss
Kenmore model 110 Won't spin or agitate
 in
Washer Repair
In the middle of a wash, I heard a rattling type noise from the washer. I opened the lid and
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Kenmore model 110 Won't spin or agitate
  #1 (permalink)
Old 06-07-2017, 12:27 AM
Junior Member
gibstuff is on a distinguished road
Default Kenmore model 110 Won't spin or agitate
Model Number: 11092585100   Brand: Kenmore   Age: More than 10 years
In the middle of a wash, I heard a rattling type noise from the washer. I opened the lid and all the water had drained, but the tub was not spinning.I checked the different cycles and noticed it won’t agitate either, but makes the same loud noise as it did in the spin cycle. Everything else seems to be working.
I pulled and checked the motor coupling. The part fit very loosely, as the rubber holes for the tabs were stretched, but nothing was broken.Is that okay?
If not, what else can I check?
Related Models
Kenmore 11092585100 WASHER
Kenmore 11092585110 WASHER
Kenmore 11092585800 WASHER
Kenmore 11092585810 WASHER
Kenmore 11092586200 WASHER
Kenmore 11092586210 WASHER
Kenmore 11092586400 WASHER
Kenmore 11092586410 WASHER
Kenmore 11092587200 WASHER
Kenmore 11092587210 AUTOMATIC WASHER
Kenmore 11092587400 WASHER
Kenmore 11092587410 AUTOMATIC WASHER
Kenmore 11092588200 WASHER
Kenmore 11092588210 WASHER
Kenmore 11092588400 WASHER
Kenmore 11092588410 WASHER
Kenmore 11092590100 AUTOMATIC WASHER
Kenmore 11092590110 WASHER
Kenmore 11092590120 WASHER
Kenmore 11092590800 AUTOMATIC WASHER
Kenmore 11092590810 WASHER
Kenmore 11092590820 WASHER
Kenmore 11092591200 WASHER
Kenmore 11092591210 WASHER
Kenmore 11092591220 WASHER
Kenmore 11092591230 WASHER
Kenmore 11092591400 WASHER
Kenmore 11092591410 WASHER
Kenmore 11092591420 WASHER
Kenmore 11092591430 WASHER
Kenmore 11092592200 WASHER
Kenmore 11092592400 WASHER
Kenmore 11092593200 WASHER
Kenmore 11092593210 WASHER
Kenmore 11092593220 Residential Washers
Kenmore 11092593400 WASHER
Kenmore 11092593410 WASHER
Kenmore 11092593420 Residential Washers
Kenmore 11092595200 Residential Washers
Kenmore 11092595210 Residential Washers
Kenmore 11092595400 WASHER
Kenmore 11092595410 Residential Washers
Kenmore 11092595500 Residential Washers
Kenmore 11092595510 Residential Washers
Kenmore 11092596100 WASHER
Kenmore 11092597200 AUTOMATIC WASHER
Kenmore 11092597210 AUTOMATIC WASHER
Kenmore 11092597400 AUTOMATIC WASHER
Kenmore 11092597410 AUTOMATIC WASHER
Kenmore 11092598200 Residential Washers
Kenmore 11092598400 Residential Washers
Kenmore 11092599200 Residential Washers
Kenmore 11092599400 Residential Washers
Kenmore 11092599500 Residential Washers
Kenmore 11092822100 GAS DRYER
Kenmore 11092822101 GAS DRYER
Kenmore 11092822102 GAS DRYER
Kenmore 11092822103 RESIDENTIAL DRYER
Kenmore 11092824100 GAS DRYER
Kenmore 11092824101 GAS DRYER
Kenmore 11092824102 GAS DRYER
Kenmore 11092824103 RESIDENTIAL DRYER
Kenmore 11092826100 GAS DRYER
Kenmore 11092826101 GAS DRYER
Kenmore 11092826102 GAS DRYER
Kenmore 11092826103 RESIDENTIAL DRYER
Kenmore 11092832100 DRYER
Kenmore 11092834100 DRYER
Kenmore 11092836100 DRYER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094762300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094821300 GAS DRYER
Kenmore 11094821301 RESIDENTIAL DRYER
Kenmore 11094831300 GAS DRYER
Kenmore 11094831301 RESIDENTIAL DRYER
Kenmore 11094832200 GAS DRYER
Kenmore 11094832201 GAS DRYER
Kenmore 11094834200 GAS DRYER
Kenmore 11094834201 GAS DRYER
Kenmore 11094836200 GAS DRYER
Kenmore 11094836201 GAS DRYER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11094962300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094964300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094966300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094972300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094974300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094976300 WASHER/DRYER LAUNDRY SYSTEM
  #2 (permalink)
Old 06-07-2017, 08:05 AM
Senior Member
brobriffin is on a distinguished road
Default
I imagine the noise you hear is the motor spinning.
What it sounds like is you have a broken coupler. If so it is cheap and easy to repair. Below is a link to that part which includes a how to video. Watch the video then check your unit to see if the coupler is what is broken.
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Keep in mind if the coupler is your problem there might be an underlying issue that caused it to fail. One of the biggest issues is the transmission not staying in neutral during drain.
Check out your coupler and let us know the results.
  #3 (permalink)
Old 06-07-2017, 12:28 PM
Junior Member
Default
Thanks for the reply.
I pulled and checked the motor coupling. The part fit very loosely, as the rubber holes for the tabs were stretched, but nothing was broken. Is that okay?
Thanks Tom
  #4 (permalink)
Old 06-07-2017, 01:03 PM
Senior Member
Default
Were the all of the tabs on both sides that fit into the rubber section intact? How about the holes in the center of each of the plastic portions, has one of them rounded out or is it cracked? The hole should have two distinct flat edges and no cracks or else the motor will spin and the coupler will remain still.
The motor must be working ok as you said the water does drain out.
So if the coupler is intact (loose holes shouldn't prevent it from working) then you might have a bad transmission. That would be my next area to look for seeing that you say it won't agitate or spin.
  #5 (permalink)
Old 06-07-2017, 08:07 PM
Junior Member
Default
Upon further inspection I did notice that the center of one of the pieces was rounded. I was able to spin it with some effort. So I think that the motor would do the same under load. I will order and replace it and let you know.
Thanks for the suggestions.
  #6 (permalink)
Old 06-10-2017, 07:53 PM
Junior Member
Default
I got the part and replaced it. It now agitates and spins. However, now there is a whine in those cycles that was not there before. Any ideas?
  #7 (permalink)
Old 06-11-2017, 11:56 AM
Senior Member
Default
Is the sound coming from the motor area? It may be the motor isn't lined up 100% or it might be something to do with the pump. Hard to say exactly without hearing it.
  #8 (permalink)
Old 06-11-2017, 12:11 PM
Junior Member
Default
Thanks for your help. No way to attach a file here that I can see.
I guess it is time to call in the repair man.
  #9 (permalink)
Old 06-11-2017, 05:33 PM
Senior Member
Default
Don't give up, you're so close. Perhaps you can make a video upload it to youtube and give us the link. That's what most people do.
  #10 (permalink)
Old 06-11-2017, 05:35 PM
Senior Member
Default
In the mean time pop the clips and remove the pump then try running it. That will rule out a pump issue.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool won't agitate or spin, but will drain-spin? Ultimate2 Washer Repair 6 02-04-2015 05:07 PM
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 11:13 AM
Kenmore no spin OR spin & agitate simultaneously Badtiming Washer Repair 0 10-13-2010 12:01 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 11:34 AM
No spin/agitate palmirage Washer Repair 1 02-24-2010 12:57 PM
