hi, i got a ge adora washer front load machine, the washer stop working after a power breakdown. the electric board doesn't work, i replaced with the correct part, the part number is WH12X22115 laundry PCB IMC assembly, it was installed correctly but the washer doesn't work properly, just lock the door and fill the water but the tumble doesn't move, it drains the water if i turn off, nothing else, it doesn't show any error message in the front panel. i think i need a setting code or reset code for the new board, i don't have it and in venezuela where i live theres no technician that can fix the problem, i got the washer in the usa, and imported to my country 2 years ago, and that model doesn't exist in here. if anybody can help me and guide me in how to fix this i appreciate. thanks
